Offline
Newbie
« on: April 27, 2011, 04:54:36 pm » |
Hi I am attempting to get my ATMEGA328P to work at low voltage (around 2.6V for 2x AA batteries). It works fine at 3.3V using the blink sketch, but at 2.6V it does not work. I am using it together with a crystal and two capacitors for the clock, and programming the chip on my Duemilanove and extracting it when programmed and putting it on my breadboard. I've read about fuses, and tried various settings using the fuse calculator http://www.engbedded.com/fusecalc. I did this by editing boards.txt and adding a new board definition, and changing the fuses settings. I attempted to set the brownout fuse to 1.8V, and the clock to a lower setting as I understand at 1.8V the maximum possible is 4Mhz(?). I used these settings: atmega328lowpower.name=Arduino Duemilanove Low Power
atmega328lowpower.upload.protocol=stk500 atmega328lowpower.upload.maximum_size=30720 atmega328lowpower.upload.speed=57600
atmega328lowpower.bootloader.low_fuses=0x7F atmega328lowpower.bootloader.high_fuses=0xD9 atmega328lowpower.bootloader.extended_fuses=0xFE atmega328lowpower.bootloader.path=atmega atmega328lowpower.bootloader.file=ATmegaBOOT_168_atmega328.hex atmega328lowpower.bootloader.unlock_bits=0x3F atmega328lowpower.bootloader.lock_bits=0x0F
atmega328lowpower.build.mcu=atmega328p atmega328lowpower.build.f_cpu=1000000L atmega328lowpower.build.core=arduino However, I get this error when burning the bootloader via w/ Arduino as ISP; ****failed; avrdude: verification error, first mismatch at byte 0x000 0xff != 0x07 avrdude: verification error; content mismatch Any help is very much appreciated, I am desperate now  P.S. Burning the normal settings as bootloader worked fine, so my programmer appears to be fine.
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #1 on: April 27, 2011, 06:36:03 pm » |
Looks like the data sheet says 2.7 Volts is the minimum to get 10 MHz operation. At 1.8 Volts you have to drop down to 4 MHz so I would recommend trying something more like 8 MHz at 2.6 Volts.
I have also read somewhere that the Arduino bootloader can only deal with clock frequencies in powers of 2 (2 MHz, 4 MHz, 8 MHz, 16 MHz) to keep the calculation of buad rates reasonable. Not sure how true that is and what the implications are.
Logged
Offline
Newbie
« Reply #2 on: April 28, 2011, 03:17:46 pm » |
Do you think I can use the 16MHz crystal to run the chip at 4MHz, should I be using the 128KHz internal clock source?
Logged
'round the world...
Offline
Edison Member
« Reply #3 on: April 28, 2011, 04:07:38 pm » |
Try looking into the prescaler fuse bits. I'm not sure about the 328, but other chips have a prescaler on the fuses... that may allow you to keep the crystal.
Logged
Eu não sou o teu criado. Se respondo no fórum é para ajudar todos mediante a minha disponibilidade e disposição. Responder por mensagem pessoal iria contra o propósito do fórum e por isso evito-o. Se realmente pretendes que eu te ajude por mensagem pessoal, então podemos chegar a um acordo e contrato onde me pagas pela ajuda que eu fornecer e poderás então definir os termos de confidencialidade do meu serviço. De forma contrária toda e qualquer ajuda que eu der tem de ser visível a todos os participantes do fórum (será boa ideia, veres o significado da palavra fórum). Nota também que eu não me responsabilizo por parvoíces escritas neste espaço pelo que se vais seguir algo dito por mim, entende que o farás por tua conta e risco.
Dito isto, mensagens pessoais só se forem pessoais, ou seja, se já interagimos de alguma forma no passado ou se me pretendes convidar para uma churrascada com cerveja (paga por ti, obviamente).
Offline
Newbie
« Reply #4 on: April 28, 2011, 04:28:18 pm » |
Prescaler... like the 'divide clock by 8' flag?
Logged
Portugal
Offline
God Member
« Reply #5 on: April 28, 2011, 04:42:12 pm » |
Atmega328 as the single option to divide or not the input frequency by 8, it has no PLL or anything else to play with the clock source, you can either enable that fuse, replace the crystal, or use the internal RC oscilator but that one is a bit risky if you want to use serial coms.
Logged
Offline
Newbie
« Reply #6 on: April 28, 2011, 06:08:34 pm » |
Burning the bootloader with the default settings works fine, and the chip is programmable afterward.
However, changing just one setting, e.g. setting Extended to FF to disable brownout detection, causes that error message and the chip is unprogrammable.
Ideally I'd want the clock to be divided by 8 to get 2MHz, and brownout detection disabled, and use the external crystal.
If anyone knows how to do this, I would appreciate it very much as I am close to 'laming out' and doing something much less elegant to get a job done.
Logged
Manchester (England England)
Online
Brattain Member
Solder is electric glue
« Reply #7 on: April 28, 2011, 06:26:48 pm » |
Do you think I can use the 16MHz crystal to run the chip at 4MHz No.
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #8 on: April 28, 2011, 06:46:05 pm » |
Trying to set the Extended byte to 0xFF won't work because when avrdude reads back the value (to verify it) the "don't care" bits read as 0. You have to say 0x07 to set the bottom three bits to disable BOD. Note: the CKDIV8 bit just pre-sets the Clock Pre-scale Register (CLKPR). You set that register at run time to set the system clock divider to any power of two between 1 (2^0) and 256 (2^8). Use the 16 MHz crystal and set the CKDIV8 fuse to start the CPU at 2MHz, then change the CLKPR register to run the processor up to 8MHz at run time.
Logged
Offline
Newbie
« Reply #9 on: April 28, 2011, 07:55:59 pm » |
Thank you so much. I see the problem, perhaps a bug in the Calculator web page. With that setting I was able to power the chip from 2.6V and it worked fine. The next step is lowering the clock speed, ideally to about 4MHz to suit the rating graph:  I ticked the CKDIV8, resulting in: 7F DA 07 And changed CPU speed to 8MHz: atmega328.build.f_cpu=8000000L The bootloader burnt OK, but when I replaced the chip back into my Duemilanove, I get stk500 sync errors. Any ideas? If there are any insights on how to use the internal clock too, that would be useful. I already have the crystal so I don't need it this time, but it might be useful for other people to see. Thanks.
« Last Edit: April 28, 2011, 08:02:40 pm by jonny5alive »
Logged
Portugal
Offline
God Member
« Reply #10 on: April 28, 2011, 09:19:10 pm » |
But your duemilanove board as an 16Mhz crystal in it...
Logged
Offline
Newbie
« Reply #11 on: April 28, 2011, 09:22:19 pm » |
Should I use 2000000 instead? (16000000 /
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #12 on: April 28, 2011, 09:32:59 pm » |
Maybe you should look at using a charge pump setup to get the voltage up.
Logged
SF Bay Area (USA)
Offline
Faraday Member
Strongly opinionated, but not official!
« Reply #13 on: April 29, 2011, 01:39:23 am » |
atmega328lowpower.upload.speed=57600 : atmega328lowpower.build.f_cpu=1000000L I don't think you can run 57600bps at 1MHz clock rate. In fact, 1MHz seems to be a particularly LOUSY speed for serial comm purposes. See http://www.wormfood.net/avrbaudcalc.phpAssuming you want a crystal, you probably need an actual slower crystal rather than using the internal divider to generate the lower clock rate from a high-speed crystal. I don't recall seeing anything in the datasheet that says that the crystal oscillator is capable of operating at high frequencies even when the voltage is low; you shouldn't assume anything other than the oscillator following the same section 23.8 graph...
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #14 on: April 29, 2011, 08:31:57 am » |
If you use a 16 MHz crystal and turn on CKDIV8 to get an initial 2 MHz clock, that is what the bootloader will run at. If you later change the CLKPR register in your sketch to bring the speed up to 4 or 8 MHz then your sketch will be running at a different rate.
I think you should put the final clock rate in the boards.txt entry so millis() and such will work in your sketch. That will mean the baud rate used by the bootloader will be much lower. For example if you start at 2 MHz, boost up to 8 MHz later, and the bootloader normally runs at 9600, put:
atmega328lowpower.upload.speed=2400 : atmega328lowpower.build.f_cpu=8000000L
Logged
