Offline
Full Member
« on: May 21, 2011, 12:35:37 pm » |
Bonjour,
Sauriez-vous m'indiquer ou trouver l'impédance d'entrée du convertisseur A/D d'un ARDUINO? Ont-ils tous les même impédances?
Merci par avance ;-)
« Last Edit: May 21, 2011, 02:37:55 pm by ojal »
Logged
Cergy
Offline
Full Member
« Reply #1 on: May 21, 2011, 01:21:37 pm » |
Convertisseur A/D plutôt ... Pour l'impédance je dois dire que je ne sais pas trop ... plusieurs Mohms
Logged
Biganos
Offline
Full Member
« Reply #2 on: May 21, 2011, 02:03:04 pm » |
Bonsoir Sur le data Atmel les entrées convertiseurs 100 Mégohms  Il faut lire les data !! 445 pages  @micalement Chabot380
Logged
ORDINAUSORE 2Ghz AMD64 QUI S'ALLUME EN 48 SECONDES AVEC UBUNTU 12.04 ARDUINO UNO / Shield Ethernet / RTC DS1307 Programmation Python et j'apprends le C Technicien Télé Vidéo à la retraite.
Offline
Full Member
« Reply #3 on: May 21, 2011, 02:55:28 pm » |
Merci chabot380, Si je comprends bien c'est ce que je viens de trouver ici : RAIN Analog Input Resistance 100 MΩ En page 329/558 Il y a aussi cela d'indiqué 24.6.1 Analog Input Circuitry The analog input circuitry for single ended channels is illustrated in Figure 24-8. An analog source applied to ADCn is subjected to the pin capacitance and input leakage of that pin, regardless of whether that channel is selected as input for the ADC. When the channel is selected, the source must drive the S/H capacitor through the series resistance (combined resistance in the input path). The ADC is optimized for analog signals with an output impedance of approximately 10 kΩ or less. If such a source is used, the sampling time will be negligible. If a source with higher impedance is used, the sampling time will depend on how long time the source needs to charge the S/H capacitor, with can vary widely. The user is recommended to only use low impedance sources with slowly varying signals, since this minimizes the required charge transfer to the S/H capacitor. Signal components higher than the Nyquist frequency (fADC/2) should not be present for either kind of channels, to avoid distortion from unpredictable signal convolution. The user is advised to remove high frequency components with a low-pass filter before applying the signals as inputs to the ADC. je ne sais pas trop comment l’interpréter... L’impédance de l'ANC de l'ARDUINO est donc de 100 MΩ. Pourquoi dit-on que cette impédance est faible par rapport à celle d'un voltmètre?
Logged
Biganos
Offline
Full Member
« Reply #4 on: May 22, 2011, 01:27:11 am » |
Bonjour Le plus simple est de nous dire ce que tu veux faire comme montage et pour quelle aplication !  @micalement Chabot380
Logged
Offline
Full Member
« Reply #5 on: May 22, 2011, 04:53:59 am » |
Bonjour Le plus simple est de nous dire ce que tu veux faire comme montage et pour quelle aplication !  @micalement Chabot380 Bonjour, Je me pose cette question suite au 'problème' que j'ai rencontré pour la mesure d'une tension. On en a parlé dans ce topic : http://arduino.cc/forum/index.php/topic,60411.0.htmlJe ne sais pas encore les applications que je vais réaliser avec l'ARDUINO, aussi c'est pour cela que j'essayais de comprendre le fonctionnement de façon assez générale au niveau du convertisseur A/N...
Logged
Biganos
Offline
Full Member
« Reply #6 on: May 24, 2011, 10:21:31 am » |
Salut J'ai lu ton post sur la LED. Avec quoi éclaires-tu ta LED ? Si c'est avec une ampoule à incandescence, fluocompacte ou spot led alimenté en 220, la rension au borne de la LED variera ! Si tu l'éclaire avec une LED alimentée en courant continu ( ou au soleil c'est pas ce qui manque en ce moment.  )tu auras une tension stable. Je viens de faire l'essai avec une LED blanche branchée sur un oscillo et plusieurs sortes d'éclairage. @micalement Chanbot380
Logged
Offline
Full Member
« Reply #7 on: May 24, 2011, 03:15:28 pm » |
J'ai fait des tests avec lumière du soleil, éclairage par led. J'ai aussi essayé avec ampoule incandescente et je n'ai pas remarque plus de variations quelque soit la source...?
Logged
Biganos
Offline
Full Member
« Reply #8 on: May 25, 2011, 04:54:30 am » |
Salut Si tu fais tes mesures avec un multimètre tu vas mesurer une tension moyenne, mais si tu fais tes mesures avec un oscilloscope là tu verras la différence !  Donc l'Arduino va te faire une conversion avec des hauts et des bas si tu éclaires la LED avec une ampoule à filament. Fait l'essai et tu verras. Si tu habites dans ma région (Bassin d'Arcachon) je te ferais la demo ! @micalement Chabot380
Logged
Offline
Full Member
« Reply #9 on: May 25, 2011, 06:11:34 am » |
Je vais refaire des essais, mais je note une bonne stabilité lors d'un éclairage fort et une totale instabilité lors d'éclairage plus faible... Un peu l'impression que l'entrée de l'ARDUINO 'flotte'... On obtient des résultats similaires si on mesure une entrée analogique sur laquelle on ne branche rien par exemple... Si tu as l'occasion de filmer ton expérience, je suis preneur de la regarder avec attention  . Habitant sur LYON, le déplacement serait agréable, mais un peu éloigné tout de même. Merci en tous cas
Logged
Offline
Newbie
« Reply #10 on: February 13, 2012, 05:19:33 am » |
Bonjour Chabot380, Je suis sur le bassin d'arcachon et je souhaite me mettre à l'arduino. J'ai un projet précis. Je souhaite rencontrer des personnes qui pratiquent l'arduino avant de me lancer. Olivier TERLEZ http://www.monfilmvideo.com
Logged
France S-O ou exil en IDF
Offline
Edison Member
« Reply #11 on: February 13, 2012, 08:48:41 am » |
je ne sais pas trop comment l’interpréter... Deux points à noter qui n'ont aucune relation entre eux : 1) les 100 MOhms d'entrée sont donnés à +/-50%, c'est selon le lot de fabrication, c'est testé par le fabricant mais tant que ça rentre dans les +/-50% ce n'est pas géré donc impossible de le voir sur un quelconque numéro de série. 2) Ce qui est important pour la conversion analogique/digitale c'est l'indication sur l'impédance maximale de la source c'est à dire ce que tu branche sur les entrées analogique du micro. Cette valeur ne doit pas dépasser 10 kOhms Si comme Chabot te l'a conseillé tu consulte la datasheet de l'atmega 328p (pour les données électriques ignores tout ce qui vient de www.arduino.cc, seules les données Atmel sont sures à 100%). Tu comprendra les raisons de cette limite haute de 10kohms : la conversion analogique/digitale est basée sur des charges et décharges de condensateur et si la résistance de source est trop élevée le condensateur interne au micro ne peut pas se charger.
Logged
Aides toi et la communauté t'aidera
Brazil
Offline
Newbie
Electrical engineering student
« Reply #12 on: February 15, 2012, 08:05:59 pm » |
J'ai lu le datasheet du Atmega 328.
Une chose que n'est pas claire pour moi est la frequence du convertisseur.
A la page 27 est possible regarder que c'est possible de choisir la source de clock. Au cas du Arduino Duemilanove et Arduino Uno la source est le crystal de 16Mhz.
Cette page motre que il ya le "AVR clock controll unit" qui est la source de plusieurs signals de clock qui seront utilisé par les sub systemes du microcontrolateur. Ce n'est pas claire quel est la frequence du convertisseur.
A la page 255 il ya un signal qui s'apelle ck. Cet signal va entrer au prescaller, et du prescaller nous aurons le signal clk/adc. Quel signal est ck et quel est sa frequence ? Je ne sais pas.
C'est une chose trés importante savoir cette frequence pour rechercher si est possible d'utilisé le Arduino dans quelques aplications de traitement numerique du signal.
Logged
Offline
Edison Member
« Reply #13 on: February 16, 2012, 02:35:43 am » |
J'ai lu le datasheet du Atmega 328. Pas completement il semble, le résumé page 250 indique : 23. Analog-to-Digital Converter 23.1 Features 10-bit Resolution 0.5 LSB Integral Non-linearity ± 2 LSB Absolute Accuracy 13 - 260 µs Conversion Time Up to 76.9 kSPS (Up to 15 kSPS at Maximum Resolution) 6 Multiplexed Single Ended Input Channels 2 Additional Multiplexed Single Ended Input Channels (TQFP and QFN/MLF Package only) Temperature Sensor Input Channel Optional Left Adjustment for ADC Result Readout 0 - VCC ADC Input Voltage Range Selectable 1.1V ADC Reference Voltage Free Running or Single Conversion Mode Interrupt on ADC Conversion Complete Sleep Mode Noise Canceler
ksps = kilo samples per seconde -> en français : fréquence d'échantillonage
Logged
Brazil
Offline
Newbie
« Reply #14 on: February 16, 2012, 02:50:05 pm » |
Merci
Mais le résumé ne dis pas comme choisir la frequence et si pour l'utilisé la frequence maxime je dois utilisé une source externe de clock.
Logged
