Dallas
Online
Shannon Member
« Reply #45 on: September 06, 2011, 05:33:04 pm » |
Thanks. That was an interesting read.
nr Bundaberg, Australia
« Reply #46 on: September 06, 2011, 07:05:00 pm » |
Interesting technique, I wonder if they'll spin it off to a 3-pin chip anyone can use?
_____ Rob
Dallas
Online
Shannon Member
« Reply #47 on: September 06, 2011, 07:46:09 pm » |
The big difference that Intel brings to the table is generation rate. In the article, the author claims a raw bit rate of 3 gigabits per second. That just cries out "simulation". I suspect that is the market they are targeting. Which means the generator, at least initially, will always be coupled with a processor capable of doing useful things with all that random data.
In other words, until they develop a 3-pin i7, I think we're out of luck.
CO, USA
« Reply #48 on: September 06, 2011, 09:13:40 pm » |
Well, that's interesting. I hadn't known that Intel was including a hardware RNG. In Linux, the kernel still gathers entropy: The random number generator gathers environmental noise from device drivers and other sources into an entropy pool. The generator also keeps an estimate of the number of bits of noise in the entropy pool. From this entropy pool random numbers are created. (from man random)
Probably some reason for doing it. Maybe, for some purposes, only a few hundred kilobits of random numbers a second isn't enough? I have no idea. Looking at the simplified drawing (without knowing it was that) I thought, hey, I have inverter ICs, I could try that. But then comes the rub: To keep the inverters in balance, we built a feedback loop into the new hardware. The circuitry in that loop performs some targeted fiddling until the two possible output values, 0 and 1, each occur roughly half the time. And they're using IGFETS -- maybe I could subsitute MOSFETs, or something else, as long as I don't care about how fast the switching is. I don't have the knowledge to know whether there's some reason an insulated gate FET is needed here. And, even without the feedback loop, there's more to it than drawn -- VCC and ground, e.g.
... it is poor civic hygiene to install technologies that could someday facilitate a police state. -- Bruce Schneier
Guildford, UK
« Reply #49 on: September 07, 2011, 01:39:04 am » |
Very interesting article. The big difference that Intel brings to the table is generation rate. In the article, the author claims a raw bit rate of 3 gigabits per second. That just cries out "simulation". I suspect that is the market they are targeting. Which means the generator, at least initially, will always be coupled with a processor capable of doing useful things with all that random data.
In other words, until they develop a 3-pin i7, I think we're out of luck. I wonder if anyone has made a chip of their initial analogue approach http://www.cryptography.com/public/pdf/IntelRNG.pdf (Block diagram is on Page 3 of the link). This still has a digital corrector and I'm guessing they're not interesting in making one themselves. Iain
CO, USA
« Reply #50 on: September 07, 2011, 05:07:29 pm » |
I wonder if anyone has made a chip of their initial analogue approach http://www.cryptography.com/public/pdf/IntelRNG.pdf (Block diagram is on Page 3 of the link). This still has a digital corrector and I'm guessing they're not interesting in making one themselves. Well, my first question would be what the signal level is from an undriven resistor.
Grand Blanc, MI, USA
"We're a proud service of the Lost Electricity Reclamation Agency"
« Reply #51 on: September 08, 2011, 10:24:19 am » |
I happened across that the other day as well, the September issue of IEEE Spectrum just arrived, it's the cover story!
Dallas
Online
Shannon Member
« Reply #52 on: September 10, 2011, 12:56:59 am » |
The latest version... /*============================================================================== Call reseedRandom once in setup to start random on a new sequence. Uses four bytes of EEPROM. ==============================================================================*/
void reseedRandom( uint32_t* address ) { static const uint32_t HappyPrime = 937; uint32_t raw; unsigned long seed;
// Read the previous raw value from EEPROM raw = eeprom_read_dword( address );
// Loop until a seed within the valid range is found do { // Incrementing by a prime (except 2) every possible raw value is visited raw += HappyPrime;
// Park-Miller is only 31 bits so ignore the most significant bit seed = raw & 0x7FFFFFFF; } while ( (seed < 1) || (seed > 2147483646) );
// Seed the random number generator with the next value in the sequence srandom( seed );
// Save the new raw value for next time eeprom_write_dword( address, raw ); }
inline void reseedRandom( unsigned short address ) { reseedRandom( (uint32_t*)(address) ); }
/*============================================================================== So the reseedRandom raw value can be initialized allowing different applications or instances to have different random sequences.
Generate initial raw values...
https://www.random.org/cgi-bin/randbyte?nbytes=4&format=h https://www.fourmilab.ch/cgi-bin/Hotbits?nbytes=4&fmt=c&npass=1&lpass=8&pwtype=3
void reseedRandomInit( uint32_t* address, uint32_t value ) { eeprom_write_dword( address, value ); }
inline void reseedRandomInit( unsigned short address, uint32_t value ) { reseedRandomInit( (uint32_t*)(address), value ); }
uint32_t reseedRandomSeed EEMEM = 0xFFFFFFFF;
void setup( void ) { reseedRandomInit( &reseedRandomSeed, 42 ); reseedRandom( &reseedRandomSeed );
reseedRandomInit( (unsigned short) 0, 42 ); reseedRandom( (unsigned short) 0 ); }
void loop( void ) { }
Netherlands
« Reply #53 on: September 10, 2011, 01:50:38 am » |
Thanks, If I see correctly the code is essentially the same, mostly the reseeding improved Do you have performance numbers / footprint numbers ? Time to make a class of it ? => multiple (pseudo)random sequences side by side
Dallas
Online
Shannon Member
« Reply #54 on: September 10, 2011, 03:50:58 am » |
If I see correctly the code is essentially the same, mostly the reseeding improved I simplified it a bit and added some comments. The code is basically the same as the first version. Do you have performance numbers / footprint numbers ? At the very most, the do-while executes twice so it should be faster than generating a random number. I'll check the size tomorrow. Time to make a class of it ? => multiple (pseudo)random sequences side by side   I think I've spent enough time on it. I have an ATtiny84 that has been begging to play with my three new thermistors.
Dallas
Online
Shannon Member
« Reply #55 on: December 22, 2011, 01:28:45 am » |
Left Coast, CA (USA)
Measurement changes behavior
« Reply #56 on: December 22, 2011, 09:16:40 am » |
As I recall this doesn't disagree with the general conclusions of our rather long posted threads on the same subject. As I recall we were still in search of a more 'perfect' initialization of the seed function? Lefty
CO, USA
« Reply #57 on: December 22, 2011, 08:05:17 pm » |
Bletcherous Scribd. Anyone have a direct link to a PDF? I'd like to read that. As I recall this doesn't disagree with the general conclusions of our rather long posted threads on the same subject. As I recall we were still in search of a more 'perfect' initialization of the seed function?
Well, I was not really getting anywhere with that. But I'd like to. However, I'm at a point where I think I really need an o-scope. If not for my decrepit Volvo finally reaching the point where I decided to replace it, I might have picked one up this month. And I probably need some other dual op-amp ICs to try out. I was sorta eyeballing a Tektronix 2336 YA -- portable, 100mhz, dual trace. Appeal for me is the ability to close the case, thus protecting the front panel. With all the junk I have around, that's a big plus.
« Reply #58 on: December 22, 2011, 08:59:15 pm » |
Yes, Blecherous Scribd indeed (I'm the author of this paper). You can find a normal PDF on http://benedikt.sudo.is/ardrand.pdf.
Dallas
Online
Shannon Member
« Reply #59 on: December 22, 2011, 09:19:57 pm » |
As I recall this doesn't disagree with the general conclusions of our rather long posted threads on the same subject. That's my recollection as well. As I recall we were still in search of a more 'perfect' initialization of the seed function? Yup. Well, reseedRandom may not be perfect but it is a reasonable choice.  @benediktkr: Thank for the research and the paper.
