Loading...
Pages: [1]   Go Down
Author Topic: 4 Digit 7 Segment Display  (Read 1495 times)
CT, USA
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
Hi All,
I just built a 4 digit 7 segment display along with the code library to display different letters/digits, etc. here is it in action:
Detailed schematics and code can be found at http://www.kerrywong.com/2010/04/10/4-digit-7-segment-display-using-arduino/
Enjoy!
Logged
Australia
Offline Offline
Full Member
AVR Microcontrollers
View Profile
Very nice.
I like that you have precoded the display characters.
With mine the user has to work out his own code for character display.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1266454689/0#0
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Boolean conditions for the decimal point lovely touch. Nice one. Thanks for sharing.
Logged
0
Offline Offline
Sr. Member
View Profile
4 DIGIT DISPLAY FROM AN ALARM CLOCK:
I did something similar, but I didn't need any resistors or shift registers.
I bought an alarm clock at a thrift store and took out the LED display.  There were 15 wires coming out the back.  By using a 5v wire and a Ground wire I was able to figure out the High/Low combinations on the different wires that would turn on different segments.  It turns out that setting 1 HIGH and 2 LOW will allow half of the segments to be lit by setting other pins high, then doing the opposite and setting 1 LOW and 2 HIGH will allow the other half to be illuminated.
Then I connected each wire directly to an arduino pin and turned it into a countdown timer.
Code:
// Press a button to increase the starting minutes, then wait for
// 5 seconds and the countdown begins
int i=0;
int seconds=0;
int minutes=8;
int tens;
int ones;
int go=0;
char var=0;
int state;
int lastState;
int single;
int minutes1;
long now;
unsigned long then;
long timer=360000;
void setup()   {
pinMode(2,INPUT);
pinMode(4,OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13,OUTPUT);
pinMode(14, OUTPUT);
pinMode(15, OUTPUT);
pinMode(16, OUTPUT);
pinMode(17, OUTPUT);
pinMode(18,OUTPUT);
pinMode(19, OUTPUT);
// Using Serial.begin(9600) makes pin 1 stay HIGH for some reason
//Serial.begin(9600);
  // This part starts the timer after a button press
  if(go==0){
    now=millis();
  state=digitalRead(2);
  if(state==0 && state != lastState){
   minutes++;  //increase starting minutes every time it's pressed
  timer=now;
  lastState=state;
  if(now - timer > 4000){
   go=1;  // START THE COUNTDOWN
  // This counts the seconds and minutes
 if (go==1)
  now=millis();
   if(now-then > 1000){
 seconds--; //count down the seconds
 then=now;
 Serial.print("Seconds: ");
 Serial.println(seconds);
  Serial.print("Minutes: ");
Serial.println(minutes);
Serial.print("tens: ");
Serial.println(tens);
Serial.print("Ones: ");
Serial.println(ones);
if(seconds<0){
 minutes--;
seconds=59;
if(minutes<0){
 seconds=0;
if(minutes>10){
 single=1;
minutes1=minutes-10;
} else{
 single=0;
 minutes1=minutes;
tens= seconds/10; //This gives the 10's digit
ones= seconds-(tens*10);  //The last digit
//FIRST NUMERAL ON THE DISPLAY
BlueFunction();
delay(5);
RedFunction();
delay(5);
// THIS LIGHTS UP THE DISPLAY BY SETTING DIFFERENT PINS
// HIGH OR LOW
void BlueFunction(){
  digitalWrite(19,LOW);   //SET ALL TWOS LOW (RED)
 digitalWrite(18,HIGH);
  digitalWrite(17,LOW);
  digitalWrite(16,LOW);
  digitalWrite(13,LOW);
  digitalWrite(15,LOW);
 digitalWrite(14,LOW);
 digitalWrite(12,LOW);
  digitalWrite(11,LOW);
  digitalWrite(10,LOW);
  digitalWrite(9,LOW);
  digitalWrite(5,LOW);
 digitalWrite(6,LOW);
digitalWrite(4,LOW);
  digitalWrite(7,HIGH);  //Colon :      ??????????
//NOW LIGHT UP THE BLUES
//  digitalWrite(8,HIGH); // Colon :   ??????????????
  if(minutes1==10){
  digitalWrite(13,HIGH);   //0
  digitalWrite(14,HIGH);
 digitalWrite(16,HIGH);
 } else if(minutes1==9){
  digitalWrite(15,HIGH);
  } else if(minutes1==8){
      } else if(minutes1==6){
        } else if(minutes1==5){
          } else if(minutes1==4){
            } else if(minutes1==3){
              } else if(minutes1==2){
  if(tens==0){                     //BLUES
    digitalWrite(11,HIGH);
    digitalWrite(10,HIGH);
    digitalWrite(12,HIGH);
  }else if(tens==9){
    }else if(tens==8){
      }else if(tens==7){
        }else if(tens==6){
          }else if(tens==5){
            }else if(tens==4){
              }else if(tens==3){
                }else if(tens==2){
                  }else if(tens==1){
if(ones==9){
  digitalWrite(6,HIGH);
  digitalWrite(4,HIGH);
}else if(ones==8){
  digitalWrite(9,HIGH);
  digitalWrite(5,HIGH);
    }else if(ones==6){
      }else if(ones==5){
        }else if(ones==4){
          }else if(ones==3){
            }else if(ones==2){
                }else if(ones==0){
void RedFunction(){
  digitalWrite(18,LOW);  //set it to RED
  digitalWrite(19,HIGH);
  digitalWrite(7,LOW);      //set Colon : Low
  digitalWrite(13,LOW);        //set blues low
  if (single==1){
  digitalWrite(17,HIGH);
  if (minutes1==10){
  } else if (minutes1==9){
    } else if (minutes1==8){
      } else if (minutes1==7){
        } else if (minutes1==6){
          } else if (minutes1==5){
            } else if (minutes1==4){
              } else if (minutes1==3){
                } else if (minutes1==2){
                  } else if (minutes1==1){
  if(tens==0){
  }else if(tens==9){
    }else if(tens==8){
        }else if(tens==6){
          }else if(tens==5){
            }else if(tens==4){
              }else if(tens==3){
                }else if(tens==2){
  if (ones==0){
  } else if (ones==9){
     } else if (ones==8){
        } else if (ones==7){
  There's no room for the rest of the code, but hopefully you get the gist
« Last Edit: December 16, 2010, 07:33:43 pm by Big_Oil » Logged
Pages: [1]   Go Up
Print
Jump to:
