Loading...
Pages: 1 2 3 [4]   Go Down
Author Topic: Measuring Pulse Width  (Read 3153 times)
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
This is strange. Seems like it is triggered around the time the timer overflows. Can't explain it yet
Can you tell more about how you connected things?
which function generator you use ?
Did you use a pull down/up resistor?
Connected gnd's?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Jr. Member
View Profile
@ Rob
I am using a simple function generator and giving the pulses from it and yes I have connected both the grounds of the arduino board. I am applying the pulses to the BNC connector and from there I am giving the pulses to the digital pin 3 (D3) and I am not using pull down/up resistor. But did you also check the code output? Can you too check the output and then make the comparison with mine?
Thanks
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Not using a pull down resistor can cause that the line keeps high for a longer period than the pulselength (RC effect ?) giving you results you would not expect.
No time to dive into it as one of my own experiments is not working now smiley-sad
Logged
Rob Tillaart
Offline Offline
Jr. Member
View Profile
@ Rob
I have made few changes in the code and now the code is working fine smiley check it out but it only misses out 1 count I don't know how we can improve that? I mean for 1 microsecond pulse it is doing 15 counts (theoretically 16) can we give a external high clock to the timer of the arduino? The code is given below
Code:
#include <avr/io.h>
#include <avr/interrupt.h>
volatile uint16_t cnt = 0;
unsigned int pulse_counts = 0;
  Serial.println("PulseWidthMeter (timer1) 0.1");
  pinMode(3, INPUT);
  // initialize Timer1
  cli();
  // reset counters
  cnt = 0;
  TCNT1 = 0;
  // reset registers
  TCCR1A = 0;
  TCCR1B = 0;
  pulse_counts++;
  // wait for HIGH
  while ((PIND & B00001000) == B00000000);
  // Set CS10 bit so timer runs at clock speed: 16 MHz
  TCCR1B |= (1 << CS10);
  // enable Timer1 overflow interrupt:
  TIMSK1 = (1 << TOIE1);
  // enable global interrupts:
//  sei();
  // keep counting until LOW
  while ((PIND & B00001000) == B00001000);
  // stop IRQ's
  TIMSK1 = 0;
  TCCR1B = 0;
 // cli();
    // Read the counters and convert to long
  uint16_t x = TCNT1;  // work copy
  uint32_t total = (uint32_t)cnt  + (uint32_t)x;
  float usec = (1.0 * total) / 16;
  // Display values
  Serial.print(x, DEC);
  Serial.print(" \t ");
  Serial.print(usec, 2);
  Serial.print("Count = ");
  Serial.println(pulse_counts);
  // Wait a while
//  delay(1000);
// count the overflows in IRQ
ISR(TIMER1_OVF_vect)
  cnt++;
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Good to hear that it works, see you removed the cli()/sei() flags. They are not needed as the TCCR1B starts/stops the timer1. They were a leftovers of my experiments, sorry.
In the first microsecond Timer1 misses a few cpu ticks before it is started as the starting of Timer1 itself takes at least one instruction. That can be added in the formula later. Furthermore the 65535L should be 65536L. This results in the following code:
Code:
//    FILE: PulseWidthMeter.pde
//  AUTHOR: Rob Tillaart
//    DATE: 2012-apr-01
//    LINK: http://arduino.cc/forum/index.php?action=post;topic=96971.0
#include <avr/io.h>
volatile unsigned int count = 0;
unsigned int pulseCounter = 0;
  Serial.begin(38400);
  Serial.println("PulseWidthMeter (timer1) 0.2");
  pinMode(3, INPUT);
  // reset Timer1 registers and the counters (timer must be stopped before reset of counters!.
  TCCR1A = 0;
  TCCR1B = 0;
  count = 0;
  TCNT1 = 0;
  TIMSK1 = (1 << TOIE1);                      // enable Timer1 overflow interrupt:
  while ((PIND & B00001000) == B00000000);    // wait for HIGH
  TCCR1B |= (1 << CS10);                      // Set CS10 bit so timer runs at clock speed: 16 MHz
  while ((PIND & B00001000) == B00001000);    // wait for low
  TCCR1B = 0;                                 // stop counting
  pulseCounter ++;
  unsigned long total = count * 65536L + TCNT1;  // Might need a +1 to correct start/stop calibration.
  // Display values
  Serial.print(total, DEC);
  Serial.println(usec, 1);
  Serial.print("pulses: ");
  Serial.println(pulseCounter);
  count++;
Maybe move these statements from loop to setup, to make it absolutely minimal
  TCCR1A = 0;
  TCCR1B = 0;
« Last Edit: April 01, 2012, 12:23:31 pm by robtillaart » Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
Is it possible to use this sketch to measure two signals at this same time?
Both signals start in the same moment but they have different period.
Logged
Pages: 1 2 3 [4]   Go Up
Print
Jump to:
