New and growing well-documented, feature-complete I2C device library
retrolefty:
Thanks Jeff; Unfortunately the results appear to remain the same.
Drat. But I have good news! The results of successful readBytes() and unsuccessful readWords(), now that I've thought about the info staring me in the face, changed my assumption about always requesting the number of bytes needed, even when working with 16-bit registers. The readWords() method was requesting one byte (because I thought "one" on that hardware would actually mean one word), and therefore failing because it was only ever receiving one byte. I've adjusted that call to request length * 2 bytes and pushed the changes up. Try it now.
(Incidentally, if this doesn't work, I won't be able to try another fix until tomorrow...almost 2am here, heh.)
Jeff
Don't knock yourself out, I'm sure you have a day job to deal with. Don't try to keep up with the hours us old retired guys can keep. :wink:
The latest changes results in compiler errors:
C:\Documents and Settings\Primary Windows User\My Documents\Arduino\libraries\ADS1115\I2Cdev.cpp: In static member function 'static int8_t I2Cdev::readWords(uint8_t, uint8_t, uint8_t, uint16_t*, uint16_t)':
C:\Documents and Settings\Primary Windows User\My Documents\Arduino\libraries\ADS1115\I2Cdev.cpp:225: error: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
C:\Documents and Settings\Primary Windows User\My Documents\My Programs\Arduino\arduino-0022\libraries\Wire/Wire.h:53: note: candidate 1: uint8_t TwoWire::requestFrom(int, int)
C:\Documents and Settings\Primary Windows User\My Documents\My Programs\Arduino\arduino-0022\libraries\Wire/Wire.h:52: note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t)
Thanks once again, I wish I was more competent with C++ classes and such.;
Lefty
Well progress it seems. I didn't really know what I was doing but your last change (the lenght * 2) did seem to be the source of the compiler errors, so I changed your latest change to this:
    Wire.beginTransmission(devAddr);
    //Wire.requestFrom(devAddr, length * 2); // length=words, this wants bytes, but length * 2 bombs
                                                              // compiler with strange geek errors
    length = length * 2;                               // so put it on it's own line
    Wire.requestFrom(devAddr,length); // length=words, this wants bytes, and changed back to this, seems
                                                     //to work!
And now when run it displays this:
Initializing I2C devices...
Testing device connections...
I2C (0x48) reading 1 words from 0x0...0 . Done (1 read).
ADS1115 connection successful
I2C (0x48) reading 1 words from 0x1...8583 . Done (1 read).
1
I2C (0x48) reading 2 bytes from 0x1...85 83 . Done (2 read).
2
So I'll try and use the higher order functions tomorrow and see if I can actually do some A/D conversions.
Thanks a million;
Lefty
retrolefty:
Well progress it seems. I didn't really know what I was doing but your last change (the lenght * 2) did seem to be the source of the compiler errors...
Eureka! Good call on that fix, and I'm glad you have something to work with now. I did compile it in my avr-gcc-based project, which currently has an incomplete TwoWire implementation hacked together. It worked fine there, but I didn't test it in the Arduino sketch until this morning, at which point the error you mentioned showed up. The problem was that the TwoWire::requestFrom() method has at least two unique parameter lists (a.k.a. it's overloaded), which are:
TwoWire::requestFrom(uint8_t, uint8_t);
TwoWire::requestFrom(int, int);
I believe that second (int, int) one is equivalent to (int16_t, int16_t) using C99 types. Basically, one uses unsigned 8-bit integer, and one uses signed 16-bit integers. The call I have in the I2Cdev::readWords() method uses a specifically declared uint8_t length variable, which was fine up until I added that inline "length * 2" as an argument. If you take an 8-bit integer and multiply it by two, you might end up with a 9-bit value, which would need to be stored in a 16-bit integer container (since the only viable options are 8-bit and 16-bit, and it obviously won't fit in an 8-bit one). Once this potential data type conversion takes place, the function is called like this:
TwoWire::requestFrom(uint8_t, int);
...which is not one of the candidates, and requires another conversion of the first parameter to make it work. It could go in either direction, trying to fit (and potentially clip) a 9-bit unsigned integer into an 8-bit unsigned container (uint8_t, uint8_t), or it could expand the unsigned 8-bit first parameter into a larger signed 16-bit container (int, int). Apparently ISO C++ doesn't like to make such a choice arbitrarily.
So, because the length variable is really supposed to contain the number of words that you want, and your fix changes it permanently to the number of bytes, I left it the way I had it and typecast it back into an unsigned 8-bit value:
Wire.requestFrom(devAddr, (uint8_t)(length * 2)); // length=words, this wants bytes
Problem solved, and pushed to the repository. The only caveat here is that you can't request more than 127 words at a time. I have no idea whether this is a legitimate concern, but with the devices in the library so far, it isn't even remotely close to being a problem.
Jeff
Thanks Jeff for the great explanation, and of course your latest 'fix' compiles and runs fine. I'm looking forward to playing with this new device and your library over the weekend (playing with the grandkids today mostly). Not sure I will be able to validate all the features, the Comparator modes are not real clear to me with it's:
COMP_MODE: Comparator mode (ADS1114 and ADS1115 only)
This bit controls the comparator mode of operation. It changes whether the comparator is implemented as a traditional comparator (COMP_MODE = '0') or as a window comparator (COMP_MODE = '1'). It serves no
function on the ADS1113.
0 : Traditional comparator with hysteresis (default)
1 : Window comparator
and it's:
0 : Non-latching comparator (default)
1 : Latching comparator
Lefty
mem:
I think having a one second default is a better idea. It won't block unless the device doesn't respond and in that case does it matter if the error is returned in one second rather than 250ms? (in the previous code, the error condition would cause it to block indefinitely)
The advantage of a longer default time-out is that inexperienced users won't get false errors when using devices that do take longer than 250ms. Experienced users can increase or decrease the time-out if they want, but it seems more friendly to have a default that minimizes the chance that errors could be reported even when the system if functioning correctly. The longer default time-out has no impact on performance on systems where the I2C devices are responding correctly.
Your last statement here (longer timeout values have no impact on working systems) is definitely true, and it means that I don't have a huge reason not to increase the default timeout to 1 sec. But let me elaborate on my interpretation of the situation in one last effort to stomp my proverbial foot like a spoiled three-year-old so I can still get my own way: (kidding)
The I2Cdev class is the convenience layer between actual device libraries and the TwoWire I2C implementation library (or alternative implementation in the future). This is where the default timeout of 250ms is defined currently, and it's the I2Cdev's read* methods that allow for alternate timeout values as part of their arguments. The I2Cdev object itself is not intended to be used by itself in your projects (though you could if you really wanted to). Instead, it's designed to be used by device libraries like the ADXL345 class or ITG3200 class. These classes wrap the I2C communication into more intelligible methods, like "getAcceleration(x, y, z)" or "getRotation(x, y, z)". The implementations of these functions, per device and per class method, can individually set their own timeouts.
The important bit here is that all of the I2Cdev calls and which device operations require which timeouts should be entirely transparent to the person implementing any particular device class in a project, a.k.a. the "inexperienced users" who would likely make a mistake with the timeout setting. The only time anyone has to worry about specific timeout settings is if they are actually writing a new device class, in which case it seems very likely that they would know to specify an extra long timeout value in their "observeTortoiseMarathonPath()" method.
For this reason, it seems more useful overall to have a legitimate failure come back faster rather than slower. But honestly, I'm willing to change it to 1 sec if you would still recommend it in light of the viewpoint I laid out above (and maybe you clearly understood all of that before and my explanation was redundant anyway). No hard feelings in either case; I'm just trying to be diligent.
retrolefty:
Thanks Jeff for the great explanation, and of course your latest 'fix' compiles and runs fine. I'm looking forward to playing with this new device and your library over the weekend (playing with the grandkids today mostly). Not sure I will be able to validate all the features, the Comparator modes are not real clear to me...
Lefty, this page has some very good info on typical comparator features, including hysteresis and latching:
Some of it is kind of hard for me to parse through since I'm still more of a software guy than a hardware guy, but if I understand correctly, the nutshell version is that using hysteresis instead of a pure window mode helps reduce the effects of noise and prevents rapid negative/positive output "bouncing" near 0V levels, and latching mode will cause the ALERT_RDY pin to remain high until the data is read even if the actual state changes before it is read. I could be wrong about either of these points, and I welcome clarification from anyone who actually knows what they are talking about.
Don't worry about testing every bit of functionality unless you actually want to; as long as the basic I/O and core functions work for you, that's the important part, and it's a good indication that the rest of the library should work as defined (unless I made a typo, which has happened on numerous previous occasions).
Jeff
I put together a 'testing sketch' for my ADS1115 A/D converter using your I2C libraries and so far I'm pleased with the results of the hardware and have not yet found a problem with your libraries.
/* Basic testing and check out sketch for a TI ADS1115 4 channel,16 bit, I2C, analog to digital converter chip
   Leftyretro 08/06/11
   With thanks to Jeff Rowberg for the development of the ADS1115 and I2Cdev I2C libraries
#include <Wire.h>
#include "ADS1115.h"
#include "I2Cdev.h"
ADS1115 adc;
    Wire.begin();  // join I2C bus
    Serial.begin(38400); // initialize serial communication
    Serial.println("Initializing I2C devices...");
    adc.initialize(); // initialize ADS1115 16 bit A/D chip
    Serial.println("Testing device connections...");
    Serial.println(adc.testConnection() ? "ADS1115 connection successful" : "ADS1115 connection failed");
    Serial.println("   ");
//  select desired conversion method
    adc.setMode(ADS1115_MODE_CONTINUOUS); // free running conversion
    // adc.setMode(ADS1115_MODE_SINGLESHOT); // single conversion
// select desired measurement range
    adc.setGain(ADS1115_PGA_6P144);  // +/- 6.144 range, .0001875 volts/step
    // adc.setGain(ADS1115_PGA_4P096);  // +/- 4.096 range, .000125 volts/step
    // adc.setGain(ADS1115_PGA_2P048);  // +/- 2.048 range, .0000625 volts/step
    // adc.setGain(ADS1115_PGA_1P024);  // +/- 1.024 range, .00003125 volts/step
    // adc.setGain(ADS1115_PGA_0P512);  // +/-  .512 range, .000015625 volts/step
    // adc.setGain(ADS1115_PGA_0P256);  // +/-  .256 range, .000007813 volts/step
//  Select desired sample speed
    // adc.setRate(ADS1115_RATE_8);    //   8 samples per second
    // adc.setRate(ADS1115_RATE_16);
    // adc.setRate(ADS1115_RATE_32);
    // adc.setRate(ADS1115_RATE_64);
    // adc.setRate(ADS1115_RATE_128);
    // adc.setRate(ADS1115_RATE_250);
    // adc.setRate(ADS1115_RATE_475);
    adc.setRate(ADS1115_RATE_860);  // 860 samples per second
    adc.setMultiplexer(ADS1115_MUX_P0_N1);  // AN0+ Vs AN1-
    // adc.setMultiplexer(ADS1115_MUX_P0_NG);  // AN0+ Vs ground
    int   rawValue; // holds 16 bit result read from A/D device
    float scaledValue; // used for voltage scaling
    byte incomingByte;
    Serial.print("Analog input #1 counts =  ");
    rawValue = adc.getDifferential();  // read current A/D value
    Serial.print(rawValue);
    Serial.print("  Voltage =  ");
    scaledValue = rawValue * .0001875; // scale it to a voltage, note: use proper constant per range used
    Serial.print(scaledValue,6);
    Serial.println("     Hit any key to continue");
    while(Serial.available() < 1) {}   // wait for user keystroke
    while(Serial.available() > 0) {incomingByte = Serial.read();} //read keystrokes then back to loop
And the output results:
Analog input #1 counts = 26719 Voltage = 5.009812 Hit any key to continue
Analog input #1 counts = 26718 Voltage = 5.009625 Hit any key to continue
Thanks again for you help.
Lefty
retrolefty:
I put together a 'testing sketch' for my ADS1115 A/D converter using your I2C libraries and so far I'm pleased with the results of the hardware and have not yet found a problem with your libraries. Thanks again for your help.
That's awesome! And you're very welcome. Not that it makes any real difference, but you should be able to get away with including only the device class header "ADS1115.h" in your main sketch and not the "I2Cdev.h" header, because ADS1115.h automatically includes I2Cdev.h. All the headers have the typical "#ifdef ... #endif" block surrounding them though, so the compiled result will be the same either way. It's just a tiny bit cleaner in the code.
Jeff
Certainly no hard feelings, its your library so no-one should begrudge your right to choose the default values you prefer. But I still think a longer default timeout is better.
(Hopefully) good coders will read the datasheet and determine and set the appropriate timeout. It's the less diligent people using this code on some otherwise unsupported device that can come unstuck. And if they are not careful enough to check that the default value is set correctly they may not be diligent enough to handle the false error if it does timeout. But go with your instinct on this, I am sure you have more important things to do than debate this point.
Michael
Update on the I2C Device Library repository!
I've been hard at work on the MPU6050 library for the powerful new MEMS chip from InvenSense, and the core functionality is 99% there. I say 99% because everything looks like it should work, and the code is all there, and everything appears to do what it's supposed to and alter or return settings predictably, except...all of my sensor data reads are coming back as zero (which should never be the case, ever, since half the device is an accelerometer). I'm currently trying to nail down why that's happening, but in the mean time, I posted the rest of the code. Once I get it fixed, I'll move on to attempting to support the awesome Motion Fusion stuff that the device can also do, though that will depend on some more documentation from InvenSense.
Also, Andrew Schamp forked the project and added the beginnings of a library for the MPR121 capacitive touch sensor device, which I have just now merged into the master branch. It's not totally complete yet, but it works, and I'll round out the missing bits after I finish the MPU6050 library. Thanks, Andrew!
Back to work...
Jeff
Another new device just added: the Honeywell HMC5843 3-axis magnetometer.
I had the HMC5883L already, but the HMC5843 is its predecessor and still widely used. I think it's pin-compatible, but the registers and constants are ever-so-slightly different. You could probably use the HMC5883L code with marginal success, but since they are so similar, I decided to take 20 minutes and create a perfectly accurate and specific library for the HMC5843. Main differences in functionality are:
  • 5843 has no sample averaging, while 5883L does
  • 5843 max official data rate is 50Hz, while 5883L is 75Hz
  • 5843 maximum magnetic field gain is +/- 6.8 Ga, while 5883L maximum is +/- 8.1
  • 5843 has Regulator Enabled status detection, while 5883L does not
In short, the 5883L is better all around with the exception of the Regulator Enabled status detection, but I'm not really sure why that feature would be important anyway.
Enjoy, all you HMC5843 users!
Jeff
[quote author=Jeff Rowberg link=topic=68210.msg518925#msg518925 date=1313898207]
I say 99% there because everything looks like it should work, and the code is all there, and everything appears to do what it's supposed to and alter or return settings predictably, except...all of my sensor data reads are coming back as zero (which should never be the case, ever, since half the device is an accelerometer). I'm currently trying to nail down why that's happening.[/quote]
Success! Thanks to a message through GitHub from someone who mentioned that the device starts up in sleep mode, I tried adding an explicit "disable sleep" call in the initialization routine. Bingo! Now it's reporting accel/gyro data. No 9-axis stuff, and none of that powerful MotionFusion yet, but the basic 6-axis raw data is there and quite functional.
MPU6050 library <- Enjoy! (partially complete)
I still need to finish the 9-axis support and a whole lot of Doxygen comments (which are mostly not there, and the ones that are I just kept from the ITG3200 library that I copied over to get started on the MPU6050. So it isn't done by any means--keep that in mind.
Jeff
Greetings, Jeff, and all,
I've posted about a Non-Blocking version of the Wire library, here:
http://arduino.cc/forum/index.php/topic,70705.0.html
If you'd like to integrate any part of this into your own work, let me know:
Gene@Telobot.com
Thumbs Up!
Gene Knight
mem:
[quote author=Jeff Rowberg link=topic=68210.msg505842#msg505842 date=1312571096]
mem:
The I2Cdev class is ...is designed to be used by device libraries like the ADXL345 class or ITG3200 class. ...The only time anyone has to worry about specific timeout settings is if they are actually writing a new device class, in which case it seems very likely that they would know to specify an extra long timeout value in their "observeTortoiseMarathonPath()" method.
Jeff
Michael
[/quote]
Unfortunately it doesn't make a difference if you set timeout to 1 microsecond or 3 hours because Wire.requestFrom() is blocking.
    Wire.requestFrom(devAddr, length);
    uint32_t t1 = millis();
    for (; Wire.available() && (timeout == 0 || millis() - t1 < timeout); count++) {
Whew! Glad I found this thread. I was beginning to wonder whether I would have to write everything from scratch, as a number of my devices were not responding with conventional Wire requests. I am currently working on a large project that includes numerous sensors as well as more conventional EEPROM storage. I will be happy to contribute drivers as I can get things working.
Any chance you could take a poke at the Lascar PanelPilot meter? The I2C datasheet was rather challenging to find on their site, but it looks straightforward enough. However, I have so far been unsuccessful in getting the meter to respond.
Datasheet:
Maybe download the SW and put a sniffer on the line to see what is sent?
The software is designed solely to program the meter, and is connected via USB. You can set the meter's I2C address between 10 and EF.
I talked to one of Lascar's engineers the other day and it looks like the I2C support is rather limited, and its communications protocol is entirely found on that sheet. For the future, they plan to expand and offer additional, more advanced meters, but for now, the meter is rather basic. It is limited by its onboard memory and processing capabilities. What you see is what you get.
gknight4:
Thanks, Gene! That is a very interesting project. The blocking reads are a bit of a problem with the current TwoWire class, as wayneft pointed out. The new Arduino 1.0 version in development is possibly supposed to address this, but from what I've seen of the code so far, it doesn't look like it does. A non-blocking library could be very useful.
I looked through the examples you wrote (good demos by the way), and I'm not sure how best to implement a fully event-driven approach with the simple I2Cdev layer with reading and writing data. I think it could be done in such a way that the event-driven style is invisible to the device libraries, which would be necessary to keep them simple. It would basically be re-implemented into a library that was blocking except for timeout support...in which case, maybe I should see if I can just do that with your code.
Obviously your name would stay on it if I implement it, but are you fine with releasing it under an MIT (or less restrictive) license? One of my goals with this whole I2Cdev library is to keep everything MIT or better ("better" meaning less restrictive).
thesaur:
Thanks! That would be awesome.
thesaur:
That device does look pretty simple from a protocol standpoint. It appears to be write-only, which I guess is how they can get away with allowing I2C addresses all the way up to 0xEF (since typically they only go up to 0x7F, with the 0x80 bit used to indicate reads). I'll see if I can get a quick device library together for you, though it might not be until a little later this weekend.
Jeff
You're welcome to use any of my code as you wish. If there's more or different functionality that you'd like, just let me know.
Thumbs Up!
Gene Knight
Great! I'll be watching your github and trying to develop additional drivers. Non-blocking support would be absolutely amazing.
As I said, I am developing a project with a broad range of sensors (temp, voltage, current, light, etc.) as well as EEPROM and the panel meter mentioned above.
I'll also be happy to contribute some documentation (example code) to help people along. I strongly appreciate the fact that this code is under the MIT license. Thanks for the time and effort you are putting into this!
