Topic: communicate between matlab and arudiono mega2560 (Read 5029 times) previous topic - next topic
faiz
what problem actually i don't know...i already put the file outside of the matlab folder installation but same thing happend...plizz somebdy help......
Your current working folder is:
C:\Program Files\MATLAB\R2012a\bin
Simulink does not permit you to build programs in the
MATLAB installation area. Please change to a working folder that
is not in the MATLAB installation area.
faiz
another prob@error
"Current code generation target for model 'LED1' is either not configured for or does not support external mode. In the Code Generation > Interface pane of Configuration Parameters dialog, select Interface option to be "External Mode" to enable external mode for targets that support it"
plizz help me
echostar7
I know this post is as old as time itself but I just wasted at least an hour or two on the same problem  so I wanted to post what worked for me.
in the Simulink preferences you need to make sure the simulation cache folder and code generation folder are not set to the matlab installation area (C:\Program Files\MATLAB\R2012a\bin) which of course it is by default, also make sure your working directory is not the install folder but that should be obvious.
darshu268
hi
i am facing the same problem...
but had one more error
Error creating folder 'C:\Program Files\ardunio support\slprj\realtime\dsp1\tmwinternal' : Access is denied.
can any one suggest me..
matiaspisano
Hi, how can i solve this problem?:
 Thanks.
