I am using the sharp GP2Y0A21YK IR sensor. The code below (taken from http://luckylarry.co.uk/) allows me to calculate the proximity of an object from the sensor
int IRpin = 1; // analog pin for reading the IR sensor
Serial.begin(9600); // start the serial port
float volts = analogRead(IRpin)0.0048828125; // value from sensor * (5/1024) - if running 3.3.volts then change 5 to 3.3
float distance = 65pow(volts, -1.10); // worked out from graph 65 = theretical distance / (1/Volts)S - luckylarry.co.uk
Serial.println(distance); // print the distance
delay(100); // arbitary wait time.
Now I need to calculate the speed of an object as it moves away or closer to the sensor. any help?
