I have to post this in two sets...
Public Class Arduino_Net
Private WithEvents serialPort1 As System.IO.Ports.SerialPort
Private CommandBuffer As String
Private Receiving As Boolean
Private BufferPointer As Integer
Private CBuffer(30) As Byte
Private _ComPort As String = "COM8"
Private _BaudRate As Integer = 9600
'Private WithEvents DataCheckTimer As System.Timers.Timer
Private WithEvents WatchDogTimer As System.Timers.Timer
Public Enum DigitalDirection
Input = 0
DigitalOutput = 1
PWMOutput = 2
End Enum
Public Event DigitalDataReceived(ByVal DPortNr As Integer, ByVal Value As Integer)
Public Event AnalogDataReceived(ByVal APortNr As Integer, ByVal Value As Integer)
Public Event LogMessageReceived(ByVal Message As String, ByVal DebugLevel As Integer)
Public Event WatchdogReceived()
Public Event ConnectionLost()
Public Property ComPort() As String
Get
Return _ComPort
End Get
Set(ByVal value As String)
_ComPort = value
End Set
End Property
Public Property BaudRate() As String
Get
Return _BaudRate
End Get
_BaudRate = value
End Set
End Property
Public Sub New()
'DataCheckTimer = New System.Timers.Timer(50)
'AddHandler DataCheckTimer.Elapsed, AddressOf CheckTimerElapsed
End Sub
Public Sub New(ByVal PortName As String)
Me.ComPort = PortName.Trim
End Sub
Public Function StartCommunication() As Boolean
Dim _ReturnValue As Boolean = False
Try
Dim components As System.ComponentModel.IContainer = New System.ComponentModel.Container()
serialPort1 = New System.IO.Ports.SerialPort(components)
serialPort1.PortName = _ComPort
serialPort1.BaudRate = _BaudRate
serialPort1.ReceivedBytesThreshold = 1
serialPort1.Open()
If Not serialPort1.IsOpen Then
WriteDebug("Unable to open comport...")
_ReturnValue = False
Exit Function
Else
serialPort1.DtrEnable = True
WriteDebug("Serial port is open")
System.Threading.Thread.Sleep(1000)
Dim Command As Byte() = {40, 0, 0, 0, 41, 0}
'send some empty commands to clear all buffers on Arduino
Me.SendCommand(Command)
'DataCheckTimer.Enabled = True
'DataCheckTimer.Start()
WatchDogTimer = New System.Timers.Timer(5000)
WatchDogTimer.Enabled = True
WatchDogTimer.Start()
_ReturnValue = True
End If
' callback for text coming back from the arduino
AddHandler serialPort1.DataReceived, AddressOf OnReceived
Catch ex As Exception
WriteDebug("Error opening comport...")
End Try
Return _ReturnValue
End Function
Public Sub SetDigitalDirection(ByVal Port As Integer, ByVal Direction As DigitalDirection)
'TODO check value and portnumber
Dim Command1 As Byte() = {40, 82, Port, Direction, 41, 0}
Me.SendCommand(Command1)
End Sub
Public Sub SetDigitalValue(ByVal Port As Integer, ByVal Value As Integer)
Dim Command1 As Byte() = {40, 80, Port, Value, 41, 0}
End Sub
Public Sub EnableDigitalPort(ByVal Port As Integer, ByVal Enable As Boolean)
If Enable Then
Dim Command1 As Byte() = {40, 68, Port, 1, 41, 0}
Else
Dim Command1 As Byte() = {40, 68, Port, 0, 41, 0}
End If
End Sub
Public Sub EnableAnalogPort(ByVal Port As Integer, ByVal Enable As Boolean)
If Enable Then
Dim Command1 As Byte() = {40, 65, Port, 1, 41, 0}
Else
Dim Command1 As Byte() = {40, 65, Port, 0, 41, 0}
End If
End Sub
Public Sub EnableDigitalTrigger(ByVal Port As Integer, ByVal Enable As Boolean)
If Enable Then
Dim Command1 As Byte() = {40, 84, Port, 1, 41, 0}
Else
Dim Command1 As Byte() = {40, 84, Port, 0, 41, 0}
End If
End Sub
Public Sub EnableAnalogTrigger(ByVal Port As Integer, ByVal Threshold As Integer)
Dim Command1 As Byte() = {40, 83, Port, Threshold, 41, 0}
End Sub
Public Sub GetDigitalValue(ByVal Port As Integer)
Dim Command1 As Byte() = {40, 86, Port, 0, 41, 0}
End Sub
Public Sub GetAnalogValue(ByVal Port As Integer)
Dim Command1 As Byte() = {40, 87, Port, 0, 41, 0}
End Sub
Private Sub SendCommand(ByVal Command As Byte())
Try
If Command.Length > 0 Then
If serialPort1.IsOpen Then
serialPort1.Write(Command, 0, Command.Length - 1)
End If
End If
End Try
End Sub
Private Sub OnReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs)
If Receiving = False Then
Receiving = True
ProcessSerialData()
Receiving = False
End If
End Sub
Private Sub CheckTimerElapsed(ByVal sender As Object, ByVal e As System.Timers.ElapsedEventArgs)
Receiving = True
ProcessSerialData()
Receiving = False
End If
End Sub
Private Sub ProcessSerialData()
Try
Dim BytesRead As Integer
While serialPort1.BytesToRead > 0
BytesRead = serialPort1.Read(CBuffer, BufferPointer, serialPort1.BytesToRead)
BufferPointer += BytesRead
While BufferPointer > 0
'search start of new command in buffer
Dim CommandStart As Integer = -1
For i As Short = 0 To BufferPointer
If CBuffer(i) = CByte(40) Then
CommandStart = i
Exit For
End If
Next
If CommandStart = -1 Then
'no begin of command found. this is no valid situation
ClearCBuffer()
End If
If CommandStart > 0 Then
'begin of command found somewhere in buffer. dismiss al bytes before startcharacter
LeftShiftCBuffer(CommandStart)
End If
'at this point we should have a clean commandbuffer
'search end of command in buffer
Dim Commandend As Integer = 0
If CBuffer(i) = CByte(41) Then
Commandend = i
Exit For
End If
Next
If Commandend > 0 Then
'commandend found. there should be a complete command in the buffer
Dim CommandBytes(Commandend) As Byte
For i As Integer = 0 To Commandend
CommandBytes(i) = CBuffer(i)
Next
'execute command
ProcessCommand(CommandBytes)
'reset pointer
LeftShiftCBuffer(Commandend + 1)
Else
Exit While
End If
End While
End While
End Try
End Sub
Private Sub ClearCBuffer()
For i As Integer = 0 To CBuffer.Length - 1
CBuffer(i) = 0
Next
BufferPointer = 0
End Sub
Private Sub LeftShiftCBuffer(ByVal NrOfPlaces As Integer)
For i As Integer = NrOfPlaces To CBuffer.Length - 1
CBuffer(i - NrOfPlaces) = CBuffer(i)
Next
For i As Integer = CBuffer.Length - NrOfPlaces To CBuffer.Length - 1
CBuffer(i) = 0
Next
BufferPointer -= NrOfPlaces
End Sub
