I want to read numbers which go onto a string(cause readStringUntil needs a String right?) from my bluetooth module and convert them to numbers.
This is more or less the piece of code giving errors :
String SpinIN ;
unsigned int pinIN;
if (Serial.available() > 0)
SpinIN = Serial.readStringUntil('\n');
            pinIN = atoi(CpinIN);
I get the followinng error :
Sketch_Tesi.ino: In function 'void loop()':
Sketch_Tesi:119: error: cannot convert 'String' to 'const char*' for argument '1' to 'int atoi(const char*)'
Sketch_Tesi:137: error: ambiguous overload for 'operator=' in 'CmodeIN = Serial.HardwareSerial::read()'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/WString.h:86: note: candidates are: String& String::operator=(const String&)
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/WString.h:87: note: String& String::operator=(const char*)
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/WString.h:88: note: String& String::operator=(const __FlashStringHelper*)
The String class (note the uppercase 'S') does not work with character array data directly. If the largest input you expect is, say, 20 characters, try defining SpinIN as a char array:
char SpinIN[21];Â Â // Need space for null termination character
and try something like:
// whatever code is above...
int charsRead;
if (Serial.available() > 0) {
 charsRead = Serial.readBytesUntil('\n', SpinIN, 20); // Read up to 20 chars max or newline
 SpinIN[charsRead] = '\0';              // Make it a string
 pinIN = atoi(SpinIN);                // Convert to int
But that example doesn't use the read until function... I already have a lot of cases in my program and iwanted to keep it the simplest i could isn't there a way to make it work with that?
Ok I managed to fix somehow the proble, the only thing is that he doesn't wait for the terminating character but he like "gives some timme to type" so if I type slowly 3 numbers he'll get them separate, and if i type fast 123 he gets the number 123 ... lol
this is my code, and I'm using a bluetooth module connected to a smartphone to send the numbers
char CpinIN [10] ;
unsigned int pinIN =0;
 Serial.begin(9600);       Â
void loop(){
Â
 if (Serial.available() > 0){ Â
Serial.readBytesUntil('\n',CpinIN,9);
//Â Â Â Â Â Â Â Â Â Â
           Serial.println (pinIN);
Alarikka:
It tells you how to read serial input without blocking execution of the sketch. That's what it's about.
You can't have read until and do other things at the same time too.
I just read digits in as they arrive and accumulate a value without copying any of it into a buffer.
My code has the value before it hits the end of word delimiter, where convert buffered text hasn't started.
You can read text as fast as it arrives. Learn state machines. Nick shows a start on them in that blog.
Ok GoForSmoke I tried to use your advice Now this is my code :
const unsigned int MAX_INPUT = 20;
unsigned long int dataout;
void process_data (const char * data)
 dataout = atoi(data);
 Serial.println (dataout);
 } // end of process_data
Â
void processIncomingByte (const char inByte)
 static char input_line [MAX_INPUT];
 static unsigned int input_pos = 0;
 switch (inByte)
  case '\n': // end of text
   input_line [input_pos] = 0; // terminating null byte
  Â
   // terminator reached! process input_line here ...
   process_data (input_line);
  Â
   // reset buffer for next time
   input_pos = 0;Â
   break;
  case '\r': // discard carriage return
   break;
  default:
   // keep adding if not full ... allow for terminating null byte
   if (input_pos < (MAX_INPUT - 1))
    input_line [input_pos++] = inByte;
   break;
  } // end of switch
Â
 } // end of processIncomingByteÂ
 while (Serial.available () > 0)
  processIncomingByte (Serial.read ());
 Â
The problem is now that if I send up to 5 characters all goes well ( if I type 12345 I get 12345) , but when I try to type 6 or more characters it just gives me random numbers like -->> 123456 = 423476650.
What am I doing wrong?
This is more like I mean. dataout is calculated as each digit comes in, the value is interpreted before the delimiter is read, not interpret after and with no buffer or need to include string.h either. I've been coding I/O that way since the 80's when you really had to work to make fast programs.
unsigned long dataout;
 Serial.begin(115200);       Â
void processIncomingValue(const char inByte)
 switch (inByte)
 case '\n': // end of text terminator reached!
  Serial.println(dataout);
  dataout = 0;
  break;
  break;
 default:
  if ( inByte >= '0' && inByte <= '9' )
   dataout *= 10UL;
   dataout += inByte - '0';
  else // anything but '\n', '\r' or a digit ends numeric interpretation
   dataout = 0;
  break;
 } // end of switch
 if ( Serial.available() > 0 )
  processIncomingValue( Serial.read() );
