The Processing 2 Sketch
Displays Arduino analog pin values, Voltages and a bar graph.
I got the hypermedia.net library from here
http://ubaa.net/shared/processing/udp/udp.zip
As you can see in the code, I had to do a bit of gymnastics to work around Java's signed data types and my Mac's little endianess. It should work on Windows without modification but I have only tested on a Mac.
/* Arduino Monitor 1
Matt S 25/11/2013
A first venture in Java and Processing
Sketch to recieve Arduino DCB
sent in UDP datagram.
import hypermedia.net.*;
import java.nio.ByteOrder;
class DCB {
int pinA0 =0;
int pinA1 =0;
int pinA2 =0;
int pinA3 =0;
int pinA4 =0;
int pinA5 =0;
long timeStamp =0;
String stringData;
byte endData;
// convert Arduino 10 bit analog int to Java signed int
private int dcbShortToInt(byte dcbData[], int offset, boolean littleEndian) {
int rawPinValue = 0;
if (littleEndian) {
rawPinValue = dcbData[offset +1] << 8;
rawPinValue += dcbData[offset] & 0x00FF;
else {
rawPinValue = (short) dcbData[offset] & 0x3ff;
return rawPinValue;
//default to little Endian
private int dcbShortToInt(byte dcbData[], int offset) {
return dcbShortToInt(dcbData, offset, true);
// convert Arduino 32 bit unsigned long to Java 64 bit long
private long dcbULongToLong(byte dcbData[], int offset, boolean littleEndian) {
Integer rawValue =0;
if (littleEndian) {
rawValue = dcbData[12 +3] << 24;
rawValue += (dcbData[12 +2] & 0x00FF) << 16;
rawValue += (dcbData[12 +1] & 0x00FF) << 8;
rawValue += dcbData[12] & 0x00FF;
else {
rawValue = dcbData[12] << 24;
rawValue += (dcbData[12 +1] & 0x00FF) << 16;
rawValue += (dcbData[12 +2] & 0x00FF) << 8;
rawValue += dcbData[12 +3] & 0x00FF;
return rawValue;
private long dcbULongToLong(byte dcbData[], int offset) {
return this.dcbULongToLong(dcbData, offset, true);
//constructor does the platform conversion
public DCB(byte[] data, boolean littleEndian) {
pinA0 = dcbShortToInt(data, 0, littleEndian);
pinA1 = dcbShortToInt(data, 2, littleEndian);
pinA2 = dcbShortToInt(data, 4, littleEndian);
pinA3 = dcbShortToInt(data, 6, littleEndian);
pinA4 = dcbShortToInt(data, 8, littleEndian);
pinA5 = dcbShortToInt(data, 10, littleEndian);
timeStamp = dcbULongToLong(data, 12, littleEndian);
String cString = new String(data, 16, 32);
stringData = new String(cString.substring(0, cString.indexOf('\0')));
endData = data[16 + 32];
/* GLOBALS */
//Arduino analog voltage conversion factor (5 / 1024);
static float vFac = .0048828;
//endianess of running platform
boolean sysLittleEndian;
// IP and port to bind to
String HOST_IP = null; //listen on all network interfaces
int PORT_RX = 2000; //Arduino must send to this destination Port.
String udpData; //byte buffer for the raw datagram
DCB dcb; // class to convert datagram to something more useful
UDP udp; // UDP socket object
//initialise the application
void setup(){
sysLittleEndian = ByteOrder.nativeOrder().equals(ByteOrder.LITTLE_ENDIAN);
//bind to UDP port
udp= new UDP(this, PORT_RX);
udp.listen(true);
//Window extents
size (320, 200);
//draw the window
void draw(){
float textTop = 20;
float lineHeight = 15;
float pinTextMargin = 20;
float voltTextMargin = 100;
float barMargin = 200;
float barWidth = 100;
float barHeight = lineHeight -5;
float hFac = barWidth / (float) 1023;
int lineNum = 0;
background(51);
if (dcb != null) {
lineNum = 0;
text("Name: " + dcb.stringData, pinTextMargin, textTop + (lineHeight * lineNum));
lineNum = 1;
text("Uptime: " + String.format("%.3f ms", (float) dcb.timeStamp / 1000), pinTextMargin, textTop + (lineHeight * lineNum));
lineNum = 2;
text("A0 " + dcb.pinA0, pinTextMargin, textTop + (lineHeight * 2));
text (String.format("%.2f Volts", (dcb.pinA0 * vFac)), voltTextMargin, textTop + (lineHeight *lineNum));
rect(barMargin, (textTop + (lineHeight *lineNum)) - (textAscent() * 0.75 ) , hFac * dcb.pinA0, barHeight);
lineNum = 3;
text("A1 " + dcb.pinA1, pinTextMargin, textTop + (lineHeight * lineNum));
text (String.format("%.2f Volts", (dcb.pinA1 * vFac)), voltTextMargin, textTop + (lineHeight * lineNum));
rect(barMargin, (textTop + (lineHeight *lineNum)) - ( textAscent() * 0.75 ), hFac * dcb.pinA1, barHeight);
lineNum = 4;
text("A2 " + dcb.pinA2, pinTextMargin, textTop + (lineHeight *lineNum));
text ( String.format("%.2f Volts", (dcb.pinA2 * vFac)), voltTextMargin, textTop + (lineHeight * lineNum));
rect(barMargin, (textTop + (lineHeight *lineNum)) - ( textAscent() * 0.75 ), hFac * dcb.pinA2, barHeight);
lineNum = 5;
text("A3 " + dcb.pinA3, pinTextMargin, textTop + (lineHeight *lineNum));
text ( String.format("%.2f Volts", (dcb.pinA3 * vFac)), voltTextMargin, textTop + (lineHeight * lineNum));
rect(barMargin, (textTop + (lineHeight *lineNum)) - ( textAscent() * 0.75 ), hFac * dcb.pinA3, barHeight);
lineNum = 6;
text("A4 " + dcb.pinA4, pinTextMargin, textTop + (lineHeight *lineNum));
text ( String.format("%.2f Volts", (dcb.pinA4 * vFac)), voltTextMargin, textTop + (lineHeight * lineNum));
rect(barMargin, (textTop + (lineHeight *lineNum)) - ( textAscent() * 0.75 ), hFac * dcb.pinA4, barHeight);
lineNum = 7;
text("A5 " + dcb.pinA5, pinTextMargin, textTop + (lineHeight *lineNum));
text ( String.format("%.2f Volts", (dcb.pinA5 * vFac)), voltTextMargin, textTop + (lineHeight * lineNum));
rect(barMargin, (textTop + (lineHeight *lineNum)) - ( textAscent() * 0.75 ), hFac * dcb.pinA5, barHeight);
//callback for UDP DataAvailable event
void receive(byte[] data, String HOST_IP, int PORT_RX){
dcb = new DCB(data, sysLittleEndian);
