i would like to ask if this simple code is correct, any correction will be much appreciated. many thanks!
here it goes, i connected all the 9 cathodes together and repeated the process 3times just like the ones shown in youtube;
all 27 anodes connected together forming 9 pins , 3 levels, right?
int pinarray[9] = {1,2,3,4,5,6,7,8,9); //pins 1-9 on the arduino are each connnected
// to the 9 anodes
int pin10 = 10; // pin 10 on the arduino is connected to cathode first level
int pin10 = 11; // pin 11 on the arduino is connected to cathode 2nd level
int pin10 = 12; // pin 11 on the arduino is connected cathode 3rd level
int x;
void setup(){
pinMode = (pinarray[9] , OUTPUT);{
pinMode = (10 , OUTPUT);
pinMode = (11 , OUTPUT);
pinMode = (12, OUTPUT);
void loop(){
for(x= pinarray[9]; x<10; x++);{
digitalWrite( pinarray[9], HIGH);
digitalWrite(10,HIGH);
delay(100);}
digitalWrite(11,HIGH);
delay(100);}
digitalWrite(12,HIGH);
delay(100);}
digitalWrite( pinarray[9], LOW);
digitalWrite(12,LOW);
delay(100);
digitalWrite(11,LOW);
delay(100);
digitalWrite( pinarray[9],LOW);
digitalWrite(10,LOW);
delay(100);
is this the right code to light all pins simultaneously from level 1 to level 3
and eventually turning it off? tnx
