Topic: Loop error with Interrupts (Read 480 times) previous topic - next topic
bauermatthews
Hello everyone,
I keep getting the following error:
Quote
core.a(main.cpp.o): In function `main':
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/main.cpp:43: undefined reference to `loop'
collect2: error: ld returned 1 exit status
Error compiling.
And I am not sure why. It's my first time using interrupts so I may have made a mess of it.
Code: [Select]
int timer = 500;
int hold = 1000;
int ledpin = 10;
volatile byte f1 = LOW;
volatile byte f2 = LOW;
volatile byte f3 = LOW;
volatile byte f4 = LOW;
volatile int button = 0;
int current;
int stopfloor;
  for (int ledpin = 10; ledpin<14; ledpin++){
    pinMode(ledpin, OUTPUT);
  for (int buttonpin = 2; buttonpin<6; buttonpin++){
    pinMode(buttonpin, INPUT);
void floorsetup(){
  if(digitalRead(2)==1){
    f1=HIGH;
  if(digitalRead(3)==1){
    f2=HIGH;
  if(digitalRead(4)==1){
    f3=HIGH;
  if(digitalRead(5)==1){
    f4=HIGH;
void switchfloor(int number){
  if(number == 1){
    digitalWrite(10,HIGH);
    digitalWrite(11,LOW);
    digitalWrite(12,LOW);
    digitalWrite(13,LOW);
    if(number == 2){
    digitalWrite(10,LOW);
    digitalWrite(11,HIGH);
    if(number == 3){
    digitalWrite(12,HIGH);
    if(number == 4){
    digitalWrite(13,HIGH);
void tofloor(int stopfloor, int current){
  if(stopfloor == current){
    switchfloor(stopfloor);
  if(stopfloor>current){
    while(current <= stopfloor){
      switchfloor(current);
      current = current+1;
  if(stopfloor<current){
    while(current >= stopfloor){
      delay(timer);
      current = current-1;
  delay(hold);
void floorcheck(){
  if(f1==HIGH){
    tofloor(1, current);
    current = 1;
    f1=LOW;
  if(f2==HIGH){
    tofloor(2, current);
    current = 2;
    f2=LOW;
  if(f3==HIGH){
    tofloor(3, current);
    current = 3;
    f3=LOW;
  if(f4==HIGH){
    tofloor(4, current);
    current = 4;
    f4=LOW;
void returnfloor() {
  switchfloor(1);
  attachInterrupt(2, floorcheck, HIGH);
  attachInterrupt(3, floorcheck, HIGH);
  attachInterrupt(4, floorcheck, HIGH);
  attachInterrupt(5, floorcheck, HIGH);
el_supremo
It's telling you that there's no loop() function in your sketch. There must be one and in your case it presumably should be calling one or more of those functions you've declared but which aren't being called by anything.
Pete
Don't send me technical questions via Private Message.
el_supremo
There won't be any interrupts because the function which attaches them, returnfloor(), isn't called by anything either. Attaching interrupts is usually done once and usually from setup().
Pete
bauermatthews
Thank you, that was a silly mistake. How do I incorporate an interrupt to start the "floorcheck" function if a button is pressed? I'd want it to interrupt the main loop which has been changed from returnfloor to "loop"
el_supremo
As I said, attachInterrupt should only be done once. Changing returnfloor so that it is your loop function means that those four attachInterrupt statements are going to be executed thousands of times a second.
Call the returnfloor function from setup so that the four interrupts are attached - once.
Then add a loop function
Code: [Select]
void loop(void)
Now, which Arduino are you using?
Pete
bauermatthews
Right, I'll change that. I'm using an Uno R3
el_supremo
#6
Mar 21, 2017, 04:28 am Last Edit: Mar 21, 2017, 04:28 am by el_supremo
In that case, you're going to have a problem with:
Code: [Select]
because there are only two interrupts on UNO. Pins 2 (interrupt 0) and 3 (interrupt 1) can interrupt.
See https://www.arduino.cc/en/Reference/AttachInterrupt
Pete
bauermatthews
That'll be a problem. Is there any way around this?
GoForSmoke
You don't need interrupts for what you're doing. I see the delays, you don't.
What kind of buttons are you using? Contact switches bounce, they might bounce your interrupt too.
Here is VERY GOOD information about contact switches/buttons:
http://www.gammon.com.au/switches
If your buttons are not contact switches and getting activated 1000+ times a second, then think of interrupts.
Here is VERY GOOD information about interrupts:
http://www.gammon.com.au/interrupts
And just so you know, I am not Nick Gammon but I do appreciate his site tremendously.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
sterretje
Don't use interrupts is one solution; I doubt you really need them.
Or use pinchange interrupt. In the interrupt, you can read the Arduino pins.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
bauermatthews
Okay I tried that and now have this:
Code: [Select]
int timer = 500;
int hold = 1000;
int ledpin = 10;
int current=1;
int stopfloor;
  InitialiseIO();
  InitialiseInterrupt();
void InitialiseIO(){
  pinMode(A1, INPUT);
  digitalWrite(A1, HIGH);
  pinMode(A2, INPUT);
  digitalWrite(A2, HIGH);
   pinMode(A3, INPUT);
  digitalWrite(A3, HIGH);
  pinMode(A4, INPUT);
  digitalWrite(A4, HIGH);
void InitialiseInterrupt(){
  cli();
  PCICR =0x02;
  PCMSK1 = 0b00011110;
  sei();
ISR(PCINT1_vect){
  if(digitalRead(A4)==1){
    f1=HIGH;
  if(digitalRead(A3)==1){
    f2=HIGH;
  if(digitalRead(A2)==1){
    f3=HIGH;
  if(digitalRead(A1)==1){
    f4=HIGH;
  if(number == 1){
    if(number == 2){
    if(number == 3){
    if(number == 4){
    delay(hold);
    return;
      delay(timer);
  else if(stopfloor<current){
      delay(timer);
  //tofloor(stopfloor, current);??
  delay(hold);
void loop(){
  current = 1;
  if(f1==HIGH){
    current = 1;
    f1=LOW;
  if(f2==HIGH){
    current = 2;
    f2=LOW;
  if(f3==HIGH){
    current = 3;
    f3=LOW;
  if(f4==HIGH){
    current = 4;
    f4=LOW;
  returnfloor();
  if(current==1){
    delay(hold);
    return;
  if(current>1){
    while(current>=1){
      delay(timer);
  }current = current +1;
It seems like it always lights up all LED's in sequence (1-4) no matter which button i press
sterretje
So you push a button (e.g. A4) and interrupt fires.
You check the states
A4 is LOW so f1 is not affected
A3, A2 and A1 are HIGH so f2, f3 and f4 will be set to HIGH.
You have to redesign your logic a little ;)
