Hey peeps, i ordered a NONIN Pulse Oximeter from overseas like 5 weeks back.
Attached below is the module specs & technical information:
After knowing how to connect my Arduino Pro Mini to the Pulse Oximeter module, i realised I do not know how to connect the finger probe to the Pulse Oximeter module.
It is Page 10 under SENSOR CONNECTION. I do not know which pins to connect.
The finger probe that we will be using will be Nonin 8000J Flex to connect to the Nonin OEM module. I am uncertain of the connections for the finger probe to the OEM module.
Under SENSOR CONNECTION:
J1-01 7 Cable Shield Cable shield
J1-02 5 Coax Signal Photo diode signal
J1-04 9 Coax Shield Photo diode bias
J1-05 6 Green Sensor type #1 line
J1-06 2 Red LED drive line
J1-07 3 Black LED drive line
J1-12 1 Yellow Sensor type #2/1 wire
These are pins to connect the sensors, so I am not sure whether which pins i should connect it to...
