Hello,
I'm new to all of this and have read through a few posts, and am trying to learn coding for the Arduino.
I have to admit, I'm still using a good bit of cut and paste and then modification for my hardware.
I think I have obstacle avoidance working on my tamiya tankbot but I'm sure there may be more efficient ways to write this and/or more effective.
This is what I have so far, and it seems to work semi-OK. I think I may need to lift the Parallax Ping up higher as it may be getting ground noise.
Any comments or advice would be appreciated at this point.
// TurtleDuino Obstacles Avoiding Robot By:RobDavinci Modified for Analog motors by ShawnPconst
int pingPin = 7; // pin for ping input
const int dangerThresh = 10; //threshold for obstacles (in cm)
int leftDistance, rightDistance; //distances on either side
long duration; //time it takes to recieve PING))) signal
// initialize serial communication:
//Setup Channel A
pinMode(12, OUTPUT); //Initiates Motor Channel A pin
pinMode(9, OUTPUT); //Initiates Brake Channel A pin
//Setup Channel B
pinMode(13, OUTPUT); //Initiates Motor Channel B pin
pinMode(8, OUTPUT); //Initiates Brake Channel B pin
int distanceFwd = ping(); //set distance ahead to ping distance
if (distanceFwd > dangerThresh) //if path is clear
//MOVE FORWARD
//Motor A forward
digitalWrite(12, HIGH); //Establishes forward direction of Channel A
digitalWrite(9, LOW); //Disengage the Brake for Channel A
analogWrite(3, 255); //Spins the motor on Channel A
//Motor B Forward
digitalWrite(13, HIGH); //Establishes backward direction of Channel B
digitalWrite(8, LOW); //Disengage the Brake for Channel B
analogWrite(11, 255); //Spins the motor on Channel B
else //if path is blocked
digitalWrite(9, HIGH); //Engage the Brake for Channel A
digitalWrite(8, HIGH); //Engage the Brake for Channel B
//MOVE BACK TURNING FIRST WAY
//Motor A Backwards
digitalWrite(12, LOW); //Establishes backward direction of Channel A
analogWrite(3, 175); //Spins the motor on Channel A
rightDistance = ping(); //scan to the right
//return to center
//Motor B backwards
digitalWrite(13, LOW); //Establishes backward direction of Channel B
analogWrite(11, 175); //Spins the motor on Channel B
//MOVE BACK TURNING SECOND WAY
//Motor B Backwards
leftDistance = ping(); //scan to the left
//RETURN TO CENTER
//Motor A forward
compareDistance();
void compareDistance()
if (leftDistance>rightDistance) //if left is less obstructed
//Motor A backwards
analogWrite(3, 100); //Spins the motor on Channel A
delay(2000);
else if (rightDistance>leftDistance) //if right is less obstructed
//Motor B backwards
analogWrite(11, 100); //Spins the motor on Channel B
delay(2000);
else //if they are equally obstructed
//Motor A forward
//Motor B Forward
delay(2000);
// establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long ping()
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return duration / 29 / 2;
