I built a Vu meter using the LM324 (http://4.bp.blogspot.com/_S8fE2DbYBlQ/Sbf_fcnxTBI/AAAAAAAAAJ0/Dkmfywgfoh0/s400/4LEDvumeterlm324.GIF)
But it doesnt seem to work. Without my ipod as input, it works fine; i adjust the input voltage using a pot, and the vu meter works fine, but as soon as i use an audio source, all the led light up and flicker to the beat of my music :. I have also triple checked the voltages the op amp is comparing but again when i use my ipod as a source it literally stops comparing and lights all outputs high.
Sorry i dont understand you. my ipods audio out jack serves as the input here. Seeing the voltage levels in the circuit it should work fine, but instead it lights up all the leds at once :\
Place a 22µF capacitor in-line with the audio input (series).
Or in fact any value capacitor. The bigger the value the lower the frequency response but you could even use a 0.1uF and get good results.
This is called AC coupling.
Explain what you mean by "no effect", was it the same as before you inserted it.
If so then either you have not got it in right or you have some other problem. Either way you need that capacitor in.
That's an awful graphic, hard to read. However its clear that
(1) The input must be DC coupled for the circuit to work at all.
(2) The 50k variable resistor has to be correctly adjusted.
(3) the opamp inputs must be connected the right way round, incoming signal to the inverting inputs, resistor divider string to the non-inverting inputs. A quad comparator would be better than an opamp here. Some opamps cannot tolerate large differences in voltage between inputs, note.
(4) If the source is AC-coupled then it should be applied directly to the inverting-inputs of the amps and the input terminals shorted.
I have also built a LM324 based VU Meter and while it works, an LM3914, LM3915 or LM3916 is a much better alternative giving 10 levels with only one external component required.
