might have found a snippet for reading temp:
/* TDGino example
Sketch to send a SMS with temperature and to check the DTMF section
created 2011
by Boris Landoni
This example code is in the public domain.
http://www.open-electronics.org
http://www.futurashop.it
#include <GSM.h>
#include <OneWire.h>
#include <DallasTemperature.h>
//for enable disable debug rem or not the string #define DEBUG_PRINT
// definition of instance of GSM class
GSM gsm;
// Set pin numbers:
const int powergsm = 77;
const int ctsgsm = 39;
const int rtsgsm = 29;
const int dcdgsm = 27;
const int dtrgsm = 28;
const int reset = 35;
const int ring = 34;
const int ld1 = 25;
const int ld2 = 26;
const int stato = 76;
const int rele1 = 36;
const int rele2 = 37;
const int sda = 20;
const int scl = 21;
const int in1 = 84;
const int in2 = 83;
const int stddtmf = 14;
const int q1dtmf = 72;
const int q2dtmf = 73;
const int q3dtmf = 74;
const int q4dtmf = 75;
const int puls = 62;
const int sonda = 63;
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS sonda
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device address
DeviceAddress insideThermometer;
float tempC=0;
// set the digital pin as output:
pinMode(powergsm, OUTPUT);
pinMode(rtsgsm, OUTPUT);
pinMode(dtrgsm, OUTPUT);
pinMode(reset, OUTPUT);
pinMode(ld1, OUTPUT);
pinMode(ld2, OUTPUT);
pinMode(rele1, OUTPUT);
pinMode(rele2, OUTPUT);
pinMode(sda, OUTPUT);
pinMode(scl, OUTPUT);
// set the digital pin as input:
pinMode(ctsgsm, INPUT);
pinMode(dcdgsm, INPUT);
pinMode(ring, INPUT);
pinMode(stato, INPUT);
pinMode(in1, INPUT);
pinMode(in2, INPUT);
pinMode(stddtmf, INPUT);
pinMode(q1dtmf, INPUT);
pinMode(q2dtmf, INPUT);
pinMode(q3dtmf, INPUT);
pinMode(q4dtmf, INPUT);
pinMode(puls, INPUT);
pinMode(sonda, INPUT);
// start serial port at 9600 bps:
//Serial1.begin(115200);
Serial.println("system startup");
//gsm.InitSerLine(); //initialize serial 1
gsm.TurnOn(115200); //module power on
gsm.InitParam(PARAM_SET_1);//configure the module
gsm.Echo(1); //enable AT echo
Serial.print("Locating DS18B20 devices...");
sensors.begin();
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
// report parasite power requirements
Serial.print("Parasite power is: ");
if (sensors.isParasitePowerMode()) Serial.println("ON");
else Serial.println("OFF");
if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
// set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
sensors.setResolution(insideThermometer, 9);
Serial.print("Device 0 Resolution: ");
Serial.print(sensors.getResolution(insideThermometer), DEC);
int response=0;
char phone_num[20]; // array for the phone number string
char string[160];
int tono=0;
// if we get a valid byte, read analog ins:
if (digitalRead(puls)==0)
int tempCdec=tempC;
int tempCuni=(tempC*100)-(tempCdec*100);
sprintf(string,"Temperatura rilevata %d.%d gradi",tempCdec,tempCuni);
Serial.println(string);
response=gsm.SendSMS("+**********",string); //+********** insert your telephone number
Serial.print("response ");
Serial.println(response);
could this be put in a sub routine of some kind and be called from a main loop? would make me understand a bit better. I would then call this when temp have raised 5 degrees. of course the void setup() part should be moved to start of main loop (just a guess here)
code comes from here: http://www.open-electronics.org/tidigino-contest/
i have removed the DTMF part of the void loop() so i guess i could remove these 2 parts also from the void setup() and set pin numbers section:
