Branchement GPS - Arduino UNO
Je teste le code donné en exemple avec TinyGPS :
#include <NewSoftSerial.h>
#include <TinyGPS.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
   It requires the use of NewSoftSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 2(rx) and 3(tx).
TinyGPS gps;
NewSoftSerial nss(2, 3);
void gpsdump(TinyGPS &gps);
bool feedgps();
void printFloat(double f, int digits = 2);
  nss.begin(4800);
  Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
  Serial.println("by Mikal Hart");
  Serial.println();
  Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
  Serial.println();
  bool newdata = false;
  unsigned long start = millis();
  // Every 5 seconds we print an update
  while (millis() - start < 5000)
    if (feedgps())
      newdata = true;
  if (newdata)
    Serial.println("Acquired Data");
    Serial.println("-------------");
    gpsdump(gps);
    Serial.println();
void printFloat(double number, int digits)
  // Handle negative numbers
  if (number < 0.0)
     Serial.print('-');
     number = -number;
  // Round correctly so that print(1.999, 2) prints as "2.00"
  double rounding = 0.5;
  for (uint8_t i=0; i<digits; ++i)
    rounding /= 10.0;
  number += rounding;
  // Extract the integer part of the number and print it
  unsigned long int_part = (unsigned long)number;
  double remainder = number - (double)int_part;
  Serial.print(int_part);
  // Print the decimal point, but only if there are digits beyond
  if (digits > 0)
    Serial.print(".");
  // Extract digits from the remainder one at a time
  while (digits-- > 0)
    remainder *= 10.0;
    int toPrint = int(remainder);
    Serial.print(toPrint);
    remainder -= toPrint;
  long lat, lon;
  float flat, flon;
  unsigned long age, date, time, chars;
  int year;
  byte month, day, hour, minute, second, hundredths;
  unsigned short sentences, failed;
  gps.get_position(&lat, &lon, &age);
  Serial.print("Lat/Long(10^-5 deg): "); Serial.print(lat); Serial.print(", "); Serial.print(lon);
  Serial.print(" Fix age: "); Serial.print(age); Serial.println("ms.");
  feedgps(); // If we don't feed the gps during this long routine, we may drop characters and get checksum errors
  gps.f_get_position(&flat, &flon, &age);
  Serial.print("Lat/Long(float): "); printFloat(flat, 5); Serial.print(", "); printFloat(flon, 5);
  feedgps();
  gps.get_datetime(&date, &time, &age);
  Serial.print("Date(ddmmyy): "); Serial.print(date); Serial.print(" Time(hhmmsscc): "); Serial.print(time);
  feedgps();
  gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
  Serial.print("Date: "); Serial.print(static_cast<int>(month)); Serial.print("/"); Serial.print(static_cast<int>(day)); Serial.print("/"); Serial.print(year);
  Serial.print("  Time: "); Serial.print(static_cast<int>(hour)); Serial.print(":"); Serial.print(static_cast<int>(minute)); Serial.print(":"); Serial.print(static_cast<int>(second)); Serial.print("."); Serial.print(static_cast<int>(hundredths));
  feedgps();
  Serial.print("Alt(cm): "); Serial.print(gps.altitude()); Serial.print(" Course(10^-2 deg): "); Serial.print(gps.course()); Serial.print(" Speed(10^-2 knots): "); Serial.println(gps.speed());
  Serial.print("Alt(float): "); printFloat(gps.f_altitude()); Serial.print(" Course(float): "); printFloat(gps.f_course()); Serial.println();
  Serial.print("Speed(knots): "); printFloat(gps.f_speed_knots()); Serial.print(" (mph): ");  printFloat(gps.f_speed_mph());
  Serial.print(" (mps): "); printFloat(gps.f_speed_mps()); Serial.print(" (kmph): "); printFloat(gps.f_speed_kmph()); Serial.println();
  feedgps();
  gps.stats(&chars, &sentences, &failed);
  Serial.print("Stats: characters: "); Serial.print(chars); Serial.print(" sentences: "); Serial.print(sentences); Serial.print(" failed checksum: "); Serial.println(failed);
bool feedgps()
  while (nss.available())
    if (gps.encode(nss.read()))
      return true;
  return false;
Il m'affiche :
Testing TinyGPS library v. 10
by Mikal Hart
Sizeof(gpsobject) = 103
Mais comme apparement rien d'autre arrive, il n'affiche rien d'autre...
Déjà il est bien alimenté, la tension sur les pins VCC et GND est bien de 4.8V.
Et pour les pins TXD et RXD, je sais pas quoi tester mais j'ai déjà essayé à l'endroit, à l'envers... et toujours rien.
Sur le GPS il y aussi une prise NC et RST, il y a peut être quelquechose à y faire d'abord.
Et ca envoi qqchose même si le GPS ne capte pas ?
