RFID Wiegand Interface Bit Manipulation and Masks
Hi Gang
I am trying to extract serial number from a RFID bracelet using a Wiegand Interface. I have read that I need to use a combination of bit manipulation and masks. I have been able to get my head around bit manipulation but I'm having trouble with masks.
If for example I have the following raw code;
1 0110 1101 0101 1000 0011 1111 0
And I want to remove the right most bit, I simply use bit manipulation;
rawCode >> 1
This moves all bits one step to the right leaving me with;
If however I'm only interested in the remaining last 24 bits then I believe I need to use a mask;
0xFFFFFF
Specifically I need to combine bit manipulation and mask to extract the serial number;
serialNumber = (rawCode >> 1) & 0xFFFFFF
I don't understand the syntax for the mask;
0xFFFFFF
The 'F' I assume is a hexadecimal, therefore FFFFFF represents 24 bits. I don't get the 0x???
Can someone possibly explain?
Cheers
Jase :slight_smile:
literals in c/c++ use a prefix to distinguish between decimal, binary, and hexidecimal numbers.
0x is for hex
0b is for binary
decimal has no prefix.
numbers can have suffix's too denoting type,
float: 1.23f
long: 123456L
unsigned long: 123456UL
etc...
as for masks and bit manipulation, there are many articles on this exact issure here on the forums and web-wide
Hi pYro_65
Thanks for the reply. I think I understand so 0x is a prefix to the literal FFFFFF. So it's basically saying what to expect the mask to be, in this case a hexadecimal. I could alternatively write this as 0b1111 1111 1111 1111 1111 1111?
Cheers
Jase
Without the spaces.
Hi Nick
Much appreciated.
Cheers
Jason :slight_smile:
