Topic: Help adding an ESP 8266 to my Arduino project (Read 2424 times) previous topic - next topic
randomgirl98
Hello, recently i created a topic about a project i am doing and some people recommended me to use the ESP 8266 Wifi module as my wireless solution. Even though i  am self taught c programmer i am having problems with the hardware part. So...
I want my Arduino to use this module to receive the IDE C programs i designed through the wireless module. Instead of uploading the program via usb the robot has a power source and i want to to be able to upload anything from the Desktop IDE to the Arduino using this module.
Any youtube video, tutorial page or forum topic for dummies that you know of, it will be great. If it includes the programming part too better so i know how it works before programming it myself. I just want something for dummies that explains everything.
Juraj
what Arduino? what esp8266 module? you want only OTA upload? you can use esp-link firmware
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
randomgirl98
Arduino uno and i have a mega but i think it doesn't matter for i want. I just want to upload my code from the IDE to the arduino wireless. The Esp 8266 is the Esp-01.
And i need something more detailed than use this firmware :S Any for dummies tutorial just to add wireless to an arduino to upload sketches will be great.
ieee488
I don't think you can wireless upload sketches to the Arduino using a ESP-01.
I would like to be proven wrong.
Juraj
#4
Feb 10, 2018, 06:02 am Last Edit: Feb 10, 2018, 06:05 am by Juraj
many solutions over Serial and SPI. (of course SPI not with 01)
it was the first purpose of the esp8266 in the Arduino world. for example see the firmware I linked
Juraj
the esp-link has a complete documentation about wiring, flashing, using
gdsports
wvmarle
Depending on your project you may be even better off by replacing the whole Arduino by an ESP8266 based board, like the NodeMCU or WeMOS mini.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
Juraj
replacing Mega in a robot with esp8266 when the robot doesn't need network connection only OTA sketch upload?
wvmarle
OP never mentions it's a robot, OP doesn't even mention anything about the project itself. OP mentioned a Mega and an Uno. Don't know which one this is about.
Nevertheless, even if it's a robot it can probably benefit from the 5x higher clock speed, the 32-bit vs 8-bit processing, and the 4 MB flash and 80 kB RAM the ESP offers as well.
An ESP8266 is a lot more than a WiFi chip. It's a very capable microprocessor in it's own right. The main limitation vs the Arduino Mega is the limited number of pins on board, so you much sooner will need to work with pin expanders.
randomgirl98
#10
Feb 10, 2018, 06:37 pm Last Edit: Feb 10, 2018, 06:42 pm by randomgirl98
The ESP modules is to be able to use a remote control connected to the laptop at a long distance. For now i just want to be able to to upload sketches wireless. So the esp 01 wont allow me to do that?
@wvmarle , yes i mentioned it and i have a thread about it. But i dont want that thread to influence this one.
wvmarle
Quote
So now you know why we want all info about a project in a single thread.
I don't think I read that thread, so didn't know this, and as a result you got useless advice. That's a waste of time. It's the same project, so of course things WILL influence one another.
randomgirl98
No no, still i just want to know how to upload sketches onto the arduino forget about the project.
The main question is, lets assume i only have the esp 8266 esp 01 and an Arduino. What do i have to upload an sketch to the Arduino using wireless.
ieee488
What makes you think you can?
I have not anything that said this was possible.
Juraj
#14
Feb 11, 2018, 10:02 pm Last Edit: Feb 13, 2018, 07:34 pm by Juraj
I tested 4 ways of OTA upload of Atmega sketch hex using esp8266. Two of them use SPI connection so they are not for the ESP-01. SPI connection can be used with esp8266 breakout boards (like Wemos D1 mini) or with boards with both MCUs on board connected with SPI (like the new board called 'red'). For now there is no esp8266 SPI connected Arduino shield.
For the serial connection of esp8266 I know the esp-link firmware and the dfu library used in WiFiLink firmware. The esp-link firmware has good  docs but the corresponding Atmega library doesn't support general networking (Client and Server implementation).
I use and maintain a copy of WiFiLink. The firmware supports OTA upload of the Atmega 328p (with Optiboot) sketch hex and the library for Atmega sketch supports general networking like the Ethernet or WiFi library. The SPI connection is supported by WFi Link and the dfu library too but it is complicated.
The simplest Atmega sketch OTA upload with esp8266 is the ESP8266AVRISP. It requires SPI and reset connection of MCUs. It can be added to any esp8266 sketch with esp8266 Arduino core. And I added it to Jiri Bilek's WiFiSpiESP firmware which supports a general networking library for SPI connected MCUs.
You can create esp8266 sketches with esp8266 Arduino core.
