I have an arduino project where I want to control a couple of victor 884 motor controllers.
This code worked for me before but it is not working anymore. Now when the code is
setting the victors into full forward or full reverse, the victors flash thier LEDs orange
which means that they are being pulsed.
When the code is setting them to neutral, the victor's LED is solid orange.
In the full forward the Victor's LED should be Green and in full reverse it should be
red and orange when in neutral.
The only thing different is that I am tying the 3.3v line to the analog reference and
setting the analog reference to external. This shouldn't have anything to do with it
should it? This is hardwired and I would have to unsolder it where if I were to just
remove the code the arduino would have a short between 3.3v & 5 volts I think.
Anyhow, here is the simple code that I am using.
What am I going wrong?
Thanks!
victor884servo.pde - An Arduino application for controlling two victor 884 motor controllers.
#include <Wire.h>
#include <Servo.h>
// motor controller variables
int LPWM = 9; // left motor PWM
int RPWM = 10; // right motor PWM
Servo victorL;
Servo victorR;
Serial.begin (19200); // start serial monitor at 19200 bps
Wire.begin (); // join i2c bus with address 0x52
victorL.attach(LPWM); // set up left victor motor controller
victorR.attach(RPWM); // set up right victor motor controller
// Tell Arduino to use the Aref pin for the Analog voltage - don't forget to connect 3.3v to Aref pin
analogReference(EXTERNAL);
victorL.writeMicroseconds(1000); // set both victors to full reverse
victorR.writeMicroseconds(1000);
delay(5000); // delay for 5 seconds
victorL.writeMicroseconds(1500); // set both victors to neutral
victorR.writeMicroseconds(1500);
victorL.writeMicroseconds(2000); // set both victors to full forward
victorR.writeMicroseconds(2000);
} // ------------ end of loop -------------------------
