Topic: EasyVR Shield 3 Not Recognizing Speech Commands (Read 245 times) previous topic - next topic
midhun131
I'm using an EasyVR Shield 3 with an Arduino Uno for speech recognition.
After uploading and running the EasyVRBridge program I had connected to the EasyVR Commander.
In Group1 I had added commands like 'YOUTUBE', 'GOOGLE' and 'FACEBOOK" and had trained these commands. All this while the software jumper is in the SW Mode.
Later, I had generated the code using the EasyVR Commander and in the void action() function a small on board LED blink program is added. After uploading the program, in the Serial Monitor it asks for a trigger word.
In this case after saying the trigger word ie 'ROBOT', it says :
"Say a command in group 0".
When I try to say any of the commands (after saying the trigger word) the board does not recognize the command and says :
"Timed out, try again...
The code generated from the EasyVR Commander is attached. I have also attached the serial monitor images and the EasdyVR Commander Images.
Please do help as I have tried almost a hundred times and still there's no result!!!
