Topic: SD card write/read failure (Read 212 times) previous topic - next topic
quantumdolt
Hi everyone
I'm using Arduino v 1.8.5, & attempting to store sensor data on an SD card using a UNO board with a duinotech datalogger shield. The shield has chipselect on pin 10 and the arduino library example 'CardInfo' works correctly, producing the following messages for two SD cards I've tried:
a. card one (an old one!)
Initializing SD card...Wiring is correct and a card is present.
Card type: SD1
Volume type is FAT12
Volume size (bytes): 31080448
Volume size (Kbytes): 30352
Volume size (Mbytes): 29
Files found on the card (name, date and size in bytes):
b. card 2:  64 GB Avoca card
Card type: SDHC
Could not find FAT16/FAT32 partition.
Make sure you've formatted the card
However none of the other library examples work. Even the very basic sketch (below) that I copied from the shield datasheet does not write to either card. I have zero idea how to proceed so - bearing in mind that I am a beginner at coding - any advice would be very welcome.
#include <SPI.h>
#include <SD.h>
File f;
  SD.begin(10); //CS on pin 10;
  f = SD.open("data.txt", FILE_WRITE); //open file for writing
  f.println("Writing some data to the card..."); //output some data
  f.close(); //then close the file
Nick_Pyner
#1
Apr 27, 2018, 03:33 am Last Edit: Apr 27, 2018, 03:33 am by Nick_Pyner
What it should have said is
Make sure you've formatted the card in the proper manner
Have you done that? There is a sticky about this at the head of this forum.
