ok I've gone through all the instructions and after flashing it with the default sonoff .bin file its no longer bricked. However I also can't get it to connect, which is probably because its a TH10 and not the usual sonoff.
What i cant get to work is compiling any of the sketches that come with it. e.g: compiling: xdrv_07_home_assistant.ino gives the following errors:
Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, ck, 26 MHz, 40MHz, QIO, 1M (64K SPIFFS), 2, v2 Lower Memory, Disabled, SSL+TLS_MEM, Only Sketch, 115200"
Archiving built core (caching) in: C:\Users\ROLPHS~1\AppData\Local\Temp\arduino_cache_931258\core\core_esp8266_esp8266_generic_CpuFrequency_80,ResetMethod_ck,CrystalFreq_26,FlashFreq_40,FlashMode_qio,FlashSize_1M64,led_2,LwIPVariant_v2mss536,Debug_Disabled,DebugLevel_SSLTLS_MEM,FlashErase_none,UploadSpeed_115200_007cfbad64b6ffec161ff98b5041ce3a.a
C:\Users\ROLPHS~1\AppData\Local\Temp\arduino_build_87823/arduino.ar(core_esp8266_main.cpp.o):(.text._ZL12loop_wrapperv+0x4): undefined reference to `setup'
C:\Users\ROLPHS~1\AppData\Local\Temp\arduino_build_87823/arduino.ar(core_esp8266_main.cpp.o):(.text._ZL12loop_wrapperv+0x8): undefined reference to `loop'
C:\Users\ROLPHS~1\AppData\Local\Temp\arduino_build_87823/arduino.ar(core_esp8266_main.cpp.o): In function `loop_wrapper':
C:\Users\Rolph Segers\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/core_esp8266_main.cpp:111: undefined reference to `setup'
C:\Users\Rolph Segers\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/core_esp8266_main.cpp:111: undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Generic ESP8266 Module.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
any clue on what i'm doing wrong?
pls note that i want it eventually to work with blynk.
thank you!
