hmc6352.cpp
// FILE: hmc6352.cpp
// AUTHOR: Rob Tillaart
// VERSION: 0.1.03
// PURPOSE: HMC6352 library for Arduino
// HISTORY:
// 0.1.00 - 2011-04-07 initial version
// 0.1.01 - 2011-04-09 quite a complete redo
// 0.1.02 - 2011-04-12 added timing, fixed a bug
// 0.1.03 - 2011-04-13 fixed small things; added getHeading()
// Released to the public domain
#include <hmc6352.h>
#include <Wire.h>
#include "WProgram.h"
/* ERROR CODES ALL FUNCTIONS
// * twi_writeTo codes (== endTransmission commands)
// 0 .. OK
// -1 .. length to long for buffer
// -2 .. address send, NACK received
// -3 .. data send, NACK received
// -4 .. other twi error (lost bus arbitration, bus error, ..)
// * requestFrom
// -10 .. not enough values returned
// * function calls
// 0 .. OK
// -20 .. error param1
// -21 .. error param2
// -22 .. error param3
hmc6352::hmc6352(uint8_t device)
Wire.begin();
_device = constrain(device, 0x10, 0xF6);
int hmc6352::getHeading()
int rv = askHeading();
if (rv != 0) return rv;
return readHeading();
// Ask the device to make a new reading
int hmc6352::askHeading()
int rv = cmd(HMC_GET_DATA);
if (rv != 0) return -rv; // problem with handshake
delay(6); // see datasheet, p8
return rv;
// read the last value from the
int hmc6352::readHeading()
int rv = Wire.requestFrom(_device, (uint8_t)2); // remove ambiguity
if (rv != 2) return -10;
rv = Wire.receive() * 256; // MSB
rv += Wire.receive(); // LSB
return rv;
// wake up from energy saving modus
int hmc6352::wakeUp()
int rv = cmd(HMC_WAKE);
delayMicroseconds(100);
return rv;
// go into energy saving modus
int hmc6352::sleep()
int rv = cmd(HMC_SLEEP);
delayMicroseconds(10);
return rv;
// values obtained from dump
int hmc6352::factoryReset()
writeRAM(0x74, 0x50); // is needed !!
writeCmd(HMC_WRITE_EEPROM, 0, 66);
writeCmd(HMC_WRITE_EEPROM, 1, 0);
writeCmd(HMC_WRITE_EEPROM, 2, 0);
writeCmd(HMC_WRITE_EEPROM, 3, 0);
writeCmd(HMC_WRITE_EEPROM, 4, 0);
writeCmd(HMC_WRITE_EEPROM, 5, 1);
writeCmd(HMC_WRITE_EEPROM, 6, 4);
writeCmd(HMC_WRITE_EEPROM, 7, 6);
writeCmd(HMC_WRITE_EEPROM, 8, 0x50);
cmd(HMC_SAVE_OP_MODE);
delayMicroseconds(125);
return 0;
// HANDLE WITH CARE - RESTART NECESSARY
// Returns Operational Mode Config Byte
int hmc6352::setOperationalModus(hmcMode m, uint8_t freq, bool periodicReset)
byte omcb = 0; // Operational Mode Control Byte
switch(freq)
case 1: break;
case 5: omcb |= 0x20; break;
case 10: omcb |= 0x40; break;
case 20: omcb |= 0x60; break;
default: return -21;
if (periodicReset) omcb |= 0x10;
switch(m)
case STANDBY: break; // omcb |= 0x00;
case QUERY: omcb |= 0x01; break;
case CONT: omcb |= 0x02; break;
default: return -20;
writeCmd(HMC_WRITE_RAM, 0x74, omcb);
return omcb;
// read the Operational Modus as byte from EEPROM
// TODO: split into 3 items
int hmc6352::getOperationalModus()
// datasheet state that at startup the OM is copied from EEPROM
// and that after writing to RAM a reboot is needed to enable new settings
// my interpretation ==> EEPROM is leading
return readCmd(HMC_READ_RAM, 0x74);
//return readCmd(HMC_READ_EEPROM, 0x08);
// Switch between normal heading and raw modes
// default = 0 ==> normal headings
// Note: after a reboot the output modus will be 0 again.
int hmc6352::setOutputModus(uint8_t om)
if (om > 4) return -20;
return writeCmd(HMC_WRITE_RAM, 0x4E, om);
// Read the output modus from RAM
int hmc6352::getOutputModus()
return readCmd(HMC_READ_RAM, 0x4E);
// NOT TESTED
int hmc6352::callibrationOn()
int rv = cmd(HMC_CALLIBRATE_ON);
return rv;
// NOT TESTED
int hmc6352::callibrationOff()
int rv = cmd(HMC_CALLIBRATE_OFF);
delay(15);
return rv;
// NOT TESTED
int hmc6352::setI2CAddress(uint8_t address)
if (address < 0x10 || address > 0xF6 ) return -20;
return writeCmd(HMC_WRITE_EEPROM, 0, address);
// returns current I2C address
int hmc6352::getI2CAddress()
return readCmd(HMC_READ_EEPROM, 0);
// NOT TESTED
// meaning time delay unknown
// therefore removed from lib for now
int hmc6352::setTimeDelay(uint8_t msec)
return writeCmd(HMC_WRITE_EEPROM, 5, msec);
int hmc6352::getTimeDelay()
return readCmd(HMC_READ_EEPROM, 5);
// NOT TESTED
// meaning measurement summing unknown
int hmc6352::setMeasurementSumming(uint8_t ms)
if (ms > 16 ) ms = 16;
return writeCmd(HMC_WRITE_EEPROM, 6, ms);
int hmc6352::getMeasurementSumming()
return readCmd(HMC_READ_EEPROM, 6);
// Makes only sense in setOperationalModus()
int hmc6352::saveOpMode()
int rv = cmd(HMC_SAVE_OP_MODE);
return rv;
// NOT TESTED
// meaning UpdateOffsets unknown
int hmc6352::updateOffsets()
int rv = cmd(HMC_UPDATE_OFFSETS);
delay(6);
return rv;
// idem
// use at own risk ...
int hmc6352::writeEEPROM(uint8_t address, uint8_t data)
return writeCmd(HMC_WRITE_EEPROM, address, data);
// idem
int hmc6352::readEEPROM(uint8_t address)
return readCmd(HMC_READ_EEPROM, address);
// idem
// Most RAM locations have an unknown meaning
int hmc6352::writeRAM(uint8_t address, uint8_t data)
return writeCmd(HMC_WRITE_RAM, address, data);
// idem
int hmc6352::readRAM(uint8_t address)
return readCmd(HMC_READ_RAM, address);
/* PRIVATE FUNCTIONS
mostly to remove redundancy in functions above
int hmc6352::cmd(uint8_t c)
Wire.beginTransmission(_device);
Wire.send(c);
int rv = Wire.endTransmission();
delay(10);
return rv;
int hmc6352::readCmd(uint8_t c, uint8_t address)
Wire.send(c);
Wire.send(address);
delayMicroseconds(70);
rv = Wire.requestFrom(_device, (uint8_t)1);
if (rv != 1) return -10;
rv = Wire.receive();
return rv;
int hmc6352::writeCmd(uint8_t c, uint8_t address, uint8_t data)
Wire.send(c);
Wire.send(address);
Wire.send(data);
return rv;
