I have a habit of holding the shift key down while navigating occasionally. When I do that and hit backspace, it acts like hitting the delete key, deleting in the opposite direction. It would be great if this could be toggled on/off somehow.
Same thing bothered me while ago. There is a setting in "preferences.txt" you can change.
Find this:
editor.keys.shift_backspace_is_delete=true
and change it to false.
Cheers,
Kari
Cheers GaryP, this annoyed me too.
that was odd
I know it says don't edit preferences.txt while the IDE is open
it means it
I changed the setting but it had no effect
I restarted the IDE
no change
after several times round the loop I twigged that it writes the settings back when you close the editor d'oh!
anyway - works a treat now
I second this! Has annoyed me quite a bit..
Thanks for the info tho
edit: to be less unclear, should be an option in ui
remiss:
And many other things as well should be easily change through the menus, like how the editor window behaves after restarting the program, default paths and so on....
I haven't had gourage to test the IDE 1.0, is it any different? And here I go again, more complaints about the design available, I need to shut up right here!
Cheers,
Kari
