delay-anweisungen werden in dem eigentlichen uhrenprogramm nicht bis selten verwendet, ich habe in einer version eine für ne millisekunde drin um das multiplexen einiger LEDs zu stabilisieren, habe es in einer anderen version anders gelöst, merke aber kein unterschied. der testcode ist folgender
* TimeSerial.pde
* example code illustrating Time library set through serial port messages.
* Messages consist of the letter T followed by ten digit time (as seconds since Jan 1 1970)
* you can send the text on the next line using Serial Monitor to set the clock to noon Jan 1 2010
T1262347200
* A Processing example sketch to automatically send the messages is inclided in the download
#include <Time.h>
#define TIME_MSG_LEN 11 // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER 'T' // Header tag for serial time sync message
#define TIME_REQUEST 7 // ASCII bell character requests a time sync message
setSyncProvider( requestSync); //set function to call when sync required
Serial.println("Waiting for sync message");
void loop(){
if(Serial.available() )
processSyncMessage();
if(timeStatus()!= timeNotSet)
digitalWrite(13,timeStatus() == timeSet); // on if synced, off if needs refresh
digitalClockDisplay();
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
Serial.println();
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
void processSyncMessage() {
// if time sync available from serial port, update time and return true
while(Serial.available() >= TIME_MSG_LEN ){ // time message consists of a header and ten ascii digits
char c = Serial.read() ;
Serial.println(c);
if( c == TIME_HEADER ) {
time_t pctime = 0;
for(int i=0; i < TIME_MSG_LEN -1; i++){
c = Serial.read();
if( c >= '0' && c <= '9'){
pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
setTime(pctime); // Sync Arduino clock to the time received on the serial port
time_t requestSync()
Serial.write(TIME_REQUEST);
return 0; // the time will be sent later in response to serial mesg
und der processing sketch:
* SyncArduinoClock.
* portIndex must be set to the port connected to the Arduino
* The current time is sent in response to request message from Arduino
* or by clicking the display window
* The time message is 11 ASCII text characters; a header (the letter 'T')
* followed by the ten digit system time (unix time)
import processing.serial.*;
public static final short portIndex = 0; // select the com port, 0 is the first port
public static final char TIME_HEADER = 'T'; //header byte for arduino serial time message
public static final char TIME_REQUEST = 7; // ASCII bell character
public static final char LF = 10; // ASCII linefeed
public static final char CR = 13; // ASCII linefeed
Serial myPort; // Create object from Serial class
String[] zeilen=new String[345600];
String zeit="";
int zeile=0;
size(200, 200);
println(Serial.list());
println(" Connecting to -> " + Serial.list()[portIndex]);
myPort = new Serial(this,Serial.list()[portIndex], 9600);
void draw()
if ( myPort.available() > 0) { // If data is available,
char val = char(myPort.read()); // read it and store it in val
if(val == TIME_REQUEST){
long t = getTimeNow();
// sendTimeMessage(TIME_HEADER, t);
if(val == LF)
; //igonore
else if(val == CR) {
//zeilen = loadStrings("zeit.txt");
zeilen[zeile]=zeit;
zeile++;
if(zeile%100 ==0 )
saveStrings("zeit.txt", zeilen);
println(zeile+" - "+zeit);
/* println();
print(hour());
print(":");
print(minute());
print(":");
print(second());
print(" - ");*/
zeit=hour()+":"+minute()+":"+second()+" ";
else {
// print(val); // echo everying but time request
zeit=zeit+val;
//print(" - ");
//print(getTimeNow());
void mousePressed() {
sendTimeMessage( TIME_HEADER, getTimeNow());
void sendTimeMessage(char header, long time) {
String timeStr = String.valueOf(time);
myPort.write(header); // send header and time to arduino
myPort.write(timeStr);
long getTimeNow(){
// java time is in ms, we want secs
GregorianCalendar cal = new GregorianCalendar();
cal.setTime(new Date());
int tzo = cal.get(Calendar.ZONE_OFFSET);
int dst = cal.get(Calendar.DST_OFFSET);
long now = (cal.getTimeInMillis() / 1000) ;
now = now + (tzo/1000) + (dst/1000);
return now;
ist etwas unsauber geschrieben, sollte aber schnell gehen, daher habe ich nur die bestehenden programme abgeändert, es sollte alles starten wenn man in das fenster klickt, das synchronisiert einmal die uhr und danach wird jede sekunde die arduino-zeit und die systemzeit geloggt und in regelmäßigen abständen in eine datei geschrieben.
