As I mentionned, the table they provide on their site is in 5F increment. Perhaps they can give me a more complete table, or an equation I can use to calculate the temperature without havin to use a table ?
I was able to connect the thermistor to my arduino over the weekend. I got some voltage reading from a analogread sketch. The readings were in line with the table from the manufacturer. I have to admit, I made the connection to arduino, one wire to ground the other to an analog pin, without knowing which one of the sensor terminal is supposed to be ground. Since I got readings, does this matter ? Is there a chance I could damage the arduino if I use the wrong terminal. Perhaps I was just lukcy and used the proper one. One of the sensor wire had a blue line on it, this is the one I used for ground.
But my connections were all temporary, I need to think about the way I want to connect all this in a more permanent way. I used some 20awg stranded wire I had lying around (originaly used to connect my central vaccum system outlet) but I had some difficulties inserting that wire into the arduino. What do you recommend I use ?
