Hi experts,
I always get the verification error, no matter which sketch I use. The function seems to be ok althought I get the verification error.
I tried the bootloader from this topic (#12) but I stll get the verification error.
AVRDUDE Checksum Fail on MEGA/UNO - Microcontrollers - Arduino Forum
Any idea how I could solve this issue?
Using arduino ide 1.6.5-r2 on win7
Sketch uses 1,518 bytes (0%) of program storage space. Maximum is 253,952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8,183 bytes for local variables. Maximum is 8,192 bytes.
C:\Daten\Arduino\arduino-1.6.5-r2\hardware\tools\avr/bin/avrdude -CC:\Daten\Arduino\arduino-1.6.5-r2\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM6 -b115200 -D -Uflash:w:C:\Users\root\AppData\Local\Temp\build8996540556280751450.tmp/Blink.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Daten\Arduino\arduino-1.6.5-r2\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 43.5 us
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x1e9801
avrdude: reading input file "C:\Users\root\AppData\Local\Temp\build8996540556280751450.tmp/Blink.cpp.hex"
avrdude: writing flash (1518 bytes):
Writing | ################################################## | 100% 0.30s
avrdude: 1518 bytes of flash written
avrdude: verifying flash memory against C:\Users\root\AppData\Local\Temp\build8996540556280751450.tmp/Blink.cpp.hex:
avrdude: load data flash data from input file C:\Users\root\AppData\Local\Temp\build8996540556280751450.tmp/Blink.cpp.hex:
avrdude: input file C:\Users\root\AppData\Local\Temp\build8996540556280751450.tmp/Blink.cpp.hex contains 1518 bytes
avrdude: reading on-chip flash data:
Reading | #########################avrdude: stk500v2_recv(): checksum error
######################### | 100% 0.32s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0371
0x81 != 0x91
avrdude: verification error; content mismatch
avrdude done. Thank you.
Thanks for your help,
captblaubaer
