different action based on the number of times a button is pressed
I'm getting close to finishing my air raid siren ( see attached photo's ) I've written some code to alter the siren speed depending the position of a rotary switch, this took me a while using the arduino cook book, Jeremy Blum vids on youtube and here searching the forums.
My setup is RC motor and controller with BEC, 7.2v 3700mah battery, arduino uno, 6 position rotary switch with voltage divider circuit to sense position, main power on / off switch, on order two led push buttons.
I've got the siren running on this set up but would like to add 2 NO push buttons in series to start the siren. this is a safety feature to ensure both hands are on the buttons when running. ( and not in the chopper )
The first three positions on the rotary switch will be low speed cycles for indoor use for me and my kid to use. the remaining three postion will be full speed simulating WWII air raid, and fire trucks but I don't want the little guy hurting his ears so I was thinking of creating a pushing pattern to enable the high speed cycles. something like 5 short presses on the push buttons.
This is where i need some help in formating the right code into my program. my thoughts are sense the button being pressed add 1 to variable each time it's pressed then i need to add this to my else if statements but I not sure of the correct formatting.
Any help would gratefully recieved, please go gently on my code as this is the 1st arduino program I've written, I'm sure it could be more efficient, but the only other thing I've programmed is a 1970's Casio calculator for trigonometry.
Regards
Dale
#include <Servo.h>
Servo myservo1;  // create servo object to control a servo
// a maximum of eight servo objects can be created
float pos = 0;    // variable to store the rotary switch input
  myservo1.attach(9);  // attaches the servo on pin 9 to the servo object
  myservo1.write(pos);// arm speed controller
  delay(3000);
// the loop routine runs over and over again forever:
  start:
  int sensorValue = analogRead(A0);  // read the input on analog pin 0:
  if (sensorValue > 100 && sensorValue < 200) { goto servo1;}     // create jump to values
  else if (sensorValue > 300 && sensorValue < 400) { goto servo2;}
  else if (sensorValue > 500 && sensorValue < 599) { goto servo3;}
  else if (sensorValue > 600 && sensorValue < 699) { goto servo4;}
  else if (sensorValue > 800 && sensorValue < 899) { goto servo5;}
  else if (sensorValue > 900) { goto servo6;}
  servo1:
   {                                 // MAX SPEED 120
      myservo1.write(pos = 10);              // tell servo to go to position in variable 'pos'
  { goto start;}
  servo2:
     myservo1.write(pos = 13);
  { goto start;}
   servo3:
      myservo1.write(pos = 20);              // tell servo to go to position in variable 'pos'
  { goto start;}
  servo4:
      myservo1.write(pos = 25);              // tell servo to go to position in variable 'pos'
  { goto start;}
  servo5:
      myservo1.write(pos = 30);              // tell servo to go to position in variable 'pos'
  { goto start;}
  servo6:
       myservo1.write(pos = 120);              // tell servo to go to position in variable 'pos'
      //delay(700);
  { goto start;}
Start by getting rid of the "Goto" statements and never use them again. Like ever.
Also, note that if your sernsorValue is exactly 100, 200, 300, etc, it wall fall through to servo1. Which is probably not want you want.
typically you would code more like
else if ( 100 <= x && x < 200) ...
else if ( 200 <= x && x < 300)
the main point being, that on one end of your range you include the "endpoint", and on the other end you exclude the endpoint.
Cheers,
John
The value used by servo.write() is an integer which moves normal servos to the angle defined by the number or it sets the speed for continuous rotation servos. I cannot begin to imagine what it does with (pos = 13) etc.
As an aside, a continuous rotation servo is not a servo at all as far as I am concerned, but that battle was lost some time ago.
UKHeliBob:
The return value of pos = 13 would be 13, so
is functionally equivalent to
pos = 13;
myservo1.write(13);
It may be bad form, but it would actually work.
Thanks for the clarification, but I bet that the OP didn't mean to use that construction as that is not what the comments say.
UKHeliBob:
Oh, I have no doubt the OP didn't know what he was doing with that part of the code.
I am happy with my motor control, it runs, I can controller it's rise and fall with great precision. John thanks you have been most helpfull and have explained the best way to write my else if statements I did pre check the analog values before doing my else if statements 168/339/509/680/852/1023.
Kind regard
Dale
Thank you and I am glad it is running for you "so far". When it comes time to add buttons you are really going to have to take your understanding "to the next level" though!
And the first step of that will be to heed the advice above about getting rid of the gotos. If you need a better hint it would be:
   // NO start: LABEL
    int s=sensorValue;
      pos=10;
      pos=13;
// NO goto: start
}  // Arduino does it for you, back to loop
Cheers,
John
Thanks John,
Yes I do need a hint, I think understand the code you posted, I'll do a re write and post it back here.
Kind regards
Dale
A somewhat different multi-press button example -
class push_button_t
    const uint8_t   _pin;
    const uint8_t   _transition_level;
    const uint8_t   _number_of_states;
    uint8_t         _press_counter;
    uint8_t         _earlier;
public:
    push_button_t(uint8_t pin, uint8_t transition_level = LOW, uint8_t number_of_states = 2)
        : _pin(pin)
        , _transition_level(transition_level)
        , _number_of_states(number_of_states)
        , _press_counter(0)
        , _earlier(0)
    void begin()
        pinMode(_pin, INPUT);
    operator uint8_t()
        uint8_t now = digitalRead(_pin);
        if ( now != _earlier )
            if ( now == _transition_level )
                _press_counter++;
                _press_counter %= _number_of_states;
       _earlier = now;
       return _press_counter;
class led_t
    const uint8_t     _pin;
public:
    led_t(uint8_t pin) : _pin(pin)      {}
    void begin()                        { pinMode(_pin, OUTPUT); }
    uint8_t operator = (uint8_t rhs)    { digitalWrite(_pin, rhs); return rhs; }
    operator uint8_t ()                 { return ((LOW == digitalRead(_pin)) ? LOW : HIGH); }
const uint8_t   pinLED      = 33;   // chipKIT Basic I/O Shield LD1
const uint8_t   pinBUTTON   =  4;   // chipKIT Basic I/O Shield BN1
led_t           led(pinLED);
push_button_t   button(pinBUTTON, LOW, 4);
    switch ( button )
        case 0: led = 0;                    break;
        case 1: led = !led;  delay(125UL);  break;
        case 2: led = !led;  delay(250UL);  break;
        case 3: led = !led;  delay(500UL);  break;
    led.begin();
    button.begin();
lloyddean:
led_t           led(pinLED);
    switch ( button )
    led.begin();
    button.begin();
Excellent! That's what I love about C++ OO!
Thanks des,
Thats a lot above my ability right now, I think i can make out it's altering the delay of the led based on the the button couter. hard for me to understand without the comment lines.
Kind regards
Dale
The key here is in asking questions of things you don't understand now, and will never understand, until enough questions are asked, and not simply ignoring what is not currently understood.
Object oriented code, even on embedded systems, can simplify code considerably.
Thing to know learn here is classes and what conversion operators do.
I was gratfully for the post but i was beening honest in my knowlege, I will do some research on the posted code after I re write my program.
Regards
Dale.
Not offended. SImply trying to encourage curiosity and exploration.
Given that your project appears to be at its start I'll throw this one out there.
It does make use of a non-standard feature of the GCC/CPP compiler included with the Arduino IDE and thus I feel fair game but it may be non portable to other compilers - the range based 'case' statements associated with the standard 'switch'/'case' pair.
#include <Servo.h>
const uint8_t   pinSERVO    = 9;
Servo           servo;
    // ... 'analogRead' will return a value in the range 0 - 1023
    switch ( analogRead(A0) )
        case    0 ...   99:             return;
        case  200 ...  299:             return;
        case  400 ...  499:             return;
        case  700 ...  799:             return;
        case  100 ...  199: pos =  10;  break;
        case  300 ...  399: pos =  13;  break;
        case  500 ...  599: pos =  20;  break;
        case  600 ...  699: pos =  25;  break;
        case  800 ...  899: pos =  30;  break;
        case  900 ... 1023: pos = 120;  break;
    servo.write(pos);
    servo.attach(pinSERVO);
    servo.write(pos);               // arm speed controller
    delay(3000);
I've modified my code without the goto's and the program is working ok
#include <Servo.h>
  delay(3000);
    pos=10;
  else if (sensorValue > 200 && sensorValue < 400) {
    pos=13;
  else if (sensorValue > 400 && sensorValue < 600) {
    pos=14;
  else if (sensorValue > 600 && sensorValue < 700) {
    pos=15;
  else if (sensorValue > 700 && sensorValue < 900) {
    pos=16;
    pos=17;
But then I added a basic rise and fall code for the first rotary switch position but get the error:
_13_prog.cpp: In function 'void loop()':
_13_prog:44: error: 'else' without a previous 'if'
I removed the else and the code compiled, but when I tested the air raid it only ran the rise and fall code and not the other switch positions
#include <Servo.h>
  delay(3000);
    pos=12.5;
  // rise and fall code
  for(pos = 12.5; pos < 15; pos += .1)  // goes from 12.5  to 15
  {                                  // in steps of .1
    myservo1.write(pos);              // tell servo to go to position in variable 'pos'
    delay(25);                       // waits 15ms for the servo to reach the position
  delay(5000);
  for(pos = 15; pos>=12.5; pos-=.1)     // goes from 15  to 12.5
   else if (sensorValue > 200 && sensorValue < 400) // error on this line
    pos=13;
    pos=14;
    pos=15;
    pos=16;
    pos=17;
Where am I going wrong with this piece of code? Any infomation would be gratefully recieved
Regards
Dale
Dale, the simple format of if is
if (condition)
code if true
In your case you need to put everything you want to happen "if true" within those braces:
      set position
      rise code
      delay
      fall code
... etc
Keeping things indented properly helps you keep track of the braces. And the auto-format tool also. (on the Tools Menu)
Cheers,
John
Thanks John,
Code modified and running ok, much appreciated.
Hazzard thanks for the upload, I was thinking more of a count then time based, but thinking more about it, if i did go down the count method I would need to have a way to re-set the counter and time based is maybe the way to go. Hmm my hurts. I need to wire these switches to my breadboard and start experimenting.
Regards
Dale
