[SOLVED]Only F constant couldn't be known in every procedure scope
I followed instruction how to drive 7 segment with adruino from this link: Make: Projects
Until on Programming Step, a bunch of error happened while I compiled the code. the original code is here: Make-Projects/_7_segment.pde at master · ril3y/Make-Projects · GitHub. But it showed some error, So, I tried to correct the code. here is my code.
#define A 8
#define B 9
#define C 2
#define D 3
#define E 4
#define F 5
#define G 6
void clr()
  /*Clears the LED*/
  digitalWrite(A, HIGH);
  digitalWrite(B, HIGH);
  digitalWrite(C, HIGH);
  digitalWrite(D, HIGH);
  digitalWrite(E, HIGH);
  digitalWrite(F, HIGH);
  digitalWrite(G, HIGH);
void char_A()
  digitalWrite(E, LOW);
 //digitalWrite(F, LOW);
  digitalWrite(G, LOW);
  digitalWrite(A, LOW);
  digitalWrite(B, LOW);
  digitalWrite(C, LOW);
void char_B()
  //Displays B
  digitalWrite(D, LOW);
void char_C()
  //Displays C
void char_D()
  //Displays D
void char_E()
  //Displays E
void char_F()
  //Displays F
void one()
  //Displays 1
void two()
  //Displays 2
void three()
  //Displays 3
void four()
  //Displays 4
void five()
  //Displays 5
void six()
  //Displays 6
void seven()
  //Displays 7
void eight()
  //Displays 8
void nine()
  //Displays 9
void zero()
  //Displays 0
void LoopDisplay()
  //Loop through all Chars and Numbers
  char_A();
  char_B();
  char_C();
  char_D();
  char_E();
  char_F();
  one();
  two();
  three();
  four();
  five();
  six();
  seven();
  eight();
  nine();
  zero();
  //Setup our pins
  pinMode(A, OUTPUT);
  pinMode(B, OUTPUT);
  pinMode(C, OUTPUT);
  pinMode(D, OUTPUT);
  pinMode(E, OUTPUT);
  pinMode(F, OUTPUT);
  pinMode(G, OUTPUT);
  Serial.begin(9600);  //Begin serial communcation
  Serial.println("Starting\n");
  LoopDisplay();
And strange error message always appear. here it is.
seven_segment.cpp: In function 'void clr()':
seven_segment:17: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void char_B()':
seven_segment:38: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void char_C()':
seven_segment:50: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void char_D()':
seven_segment:62: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void char_E()':
seven_segment:74: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void char_F()':
seven_segment:86: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void one()':
seven_segment:98: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void two()':
seven_segment:110: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void three()':
seven_segment:122: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void four()':
seven_segment:134: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void five()':
seven_segment:146: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void six()':
seven_segment:158: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void seven()':
seven_segment:170: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void eight()':
seven_segment:182: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void nine()':
seven_segment:194: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void zero()':
seven_segment:206: error: 'F' was not declared in this scope
seven_segment.cpp: In function 'void setup()':
seven_segment:258: error: 'F' was not declared in this scope
See, "F" was not declared in every scope????
Then, I gave comment mark (using "//") on each line which contains "F" constant. Then I compiled and upload it successfully. I assume all pin works properly except pin 5 (which I set comment each "F" code related).
Why F constant couldn't be known in every procedure scope?
I using power from my laptop ...
That's not the problem.
Under version 1.0 of the IDE the word "F" is used to indicate a string is in Flash memory. Better choose another one.
For example, if you change F to FOO it compiles OK.
F is a macro defined by the Arduino environment. Some details are available here...
I suggest using something other than "F" to avoid the conflict; maybe "sF" for "segment F".
@CB: ninja by 12 seconds!
So, it seems "F" has been one of reserved word in adruino programming environment and I should use another name. suddenly clear the problem. thanks.
Argh! Bested by an Aussie! I have a reasonable excuse. I was letting my Australian Terrier outside. She wanted to yell at the neighborhood skunk.
