Topic: Robot controlled by dual h bridge wont move for the life of me (Read 941 times) previous topic - next topic
FaresWheel
So i followed this tutorial of how to make a dual motor arduino robot (https://darkbluebit.com/arduino/robot-motor-control/).
It had a schematic, and I followed it. The schematic is with the SparkFun controller though, and I have the Pololu one, so some things had to be changed since the pins are different.
So I did this (schematic attached). I know the controller is sparkfun, but they don't have the pololu one, so here's a picture of the pins (https://darkbluebit.com/wp-content/uploads/2016/01/robot-hbridge3.jpg)
Code: [Select]
// Left motor
const int pinAIN1 = 5; //Direction
const int pinAIN2 = 4; //Direction
const int pinPWMA = 3; //Speed
// Right motor
const int pinBIN1 = 7;  //Direction
const int pinBIN2 = 8; //Direction
const int pinPWMB = 9;  //Speed
//H-Bridge Standby
const int pinSTBY = 6;
boolean leftMotor = 1;
boolean rightMotor = 0;
 pinMode(pinPWMA, OUTPUT);
 pinMode(pinAIN1, OUTPUT);
 pinMode(pinAIN2, OUTPUT);
 pinMode(pinPWMB, OUTPUT);
 pinMode(pinBIN1, OUTPUT);
 pinMode(pinBIN2, OUTPUT);
 pinMode(pinSTBY, OUTPUT);
 // acceleration
 for (int i = 0; i <= 255; i += 5) {
   motorDrive(leftMotor, 1, i);
   motorDrive(rightMotor, 1, i);
   delay(50);
 delay(1700);
 // turn right
 motorStop(rightMotor);
 delay(1500);
 // go ahead
 motorDrive(rightMotor, 1, 255);
 // stop
 motorStop(leftMotor);
 delay(300);
 // turn around in place
 motorDrive(leftMotor, 0, 255);
 delay(3600);
 // stop
 delay(300);
 // turn left in a circle
 motorDrive(leftMotor, 1, 180);
 delay(4000);
 // slow down
 for (int i = 255; i >= 0; i -= 5) {
   delay(55);
 // stop
 delay(10000);
 Drive a motor:
   - motorNumber: 0 left motor, 1 right motor
   - moveForward: motor direction (0 reverse, 1 forward)
   - motorSpeed: 0 to 255 ---> 0 = stop / 255 = max speed
void motorDrive(boolean motorNumber, boolean moveForward, int motorSpeed) {
 boolean pinIn1;  //Relates to AIN1 or BIN1 (depending on the motor number specified)
 // direction to turn the motor
 //   clockwise: IN1 = HIGH and IN2 = LOW
 //   counter-clockwise: IN1 = LOW and IN2 = HIGH
 if (moveForward)
   pinIn1 = LOW;
   pinIn1 = HIGH;
 // select the motor to turn, set the direction and the speed
 if (motorNumber == leftMotor) {
   digitalWrite(pinAIN1, pinIn1);
   digitalWrite(pinAIN2, !pinIn1);
   analogWrite(pinPWMA, motorSpeed);
   digitalWrite(pinBIN1, pinIn1);
   digitalWrite(pinBIN2, !pinIn1);
   analogWrite(pinPWMB, motorSpeed);
 // STBY must be high to enable motors
 digitalWrite(pinSTBY, HIGH);
// Stop the specified motor
void motorStop(boolean motorNumber) {
   digitalWrite(pinAIN1, LOW);
   digitalWrite(pinAIN2, LOW);
   digitalWrite(pinBIN1, LOW);
   digitalWrite(pinBIN2, LOW);
I clicked verify, and it doesn't work. Nothing moves and the motors don't spin. The lights are glowing on the arduino, but not a budge. The video he posted has his wires a bit different than the schematic, like the ones from the controller to the diode being in the middle of the 2 instead of the top. I know for sure that the batteries and the motors aren't faulty. The arduino is powered by USB.
Can someone please help me?
slipstick
Clicking "Verify" just compiles the code to check it. You need to click "Upload" next to it to get the code transferred into the Arduino and run. Then it might do something.
Steve
FaresWheel
I've pressed verify and upload, but still no movement
slipstick
Try putting some serial prints in to see where it gets to in the code. If it's running through the code as you expect then the connections are wrong. It's way too hard to follow that Fritzing so I'll let you sort that out.
Steve
justone
That motor driver does not need external flyback diodes so just get rid of those.
FaresWheel
Alright, sorry I didn't update in a while, but I found the solution
I just didn't solder the pins to the motor driver :smiley-confuse:
Southpark
Yep. When in doubt...... test hardware sub-systems individually, to ensure that each one is functioning properly. And when you put it all together, and something isn't working, then at least you know which locations to take measurements, to see whether the correct signals are appearing at those spots (or not). Tracing back to the first point where a signal isn't getting through, or is not at the correct level.
MarkT
That's a new one!  Lesson to learn: do a close visual inspection after constructing a circuit!
