I keep failing a programming this. 2 permanent switches: A and B. one LCD 16x2 Screen.
If switch A is pressed (and maintained), then LCD shows : A
If switch B is pressed (and maintained), then LCD shows : B
If switches A and B are pressed (and maintained), then LCD shows : A and B
If nothing is pressed, LCD shows : Free
Here is the code i did :
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int switcha = 7;
int switchb = 8;
pinMode(switcha, INPUT); // OUTPUT signifie que c'est une sortie
pinMode(switchb, INPUT); // OUTPUT signifie que c'est une sortie
lcd.begin(16,2);
if(digitalRead(switcha) == HIGH) // on regarde si notre entrée capte du courant
lcd.setCursor(0,0);
lcd.print("A");
lcd.setCursor(0,1);
lcd.print("A");
delay(1000); }
if(digitalRead(switchb) == HIGH) // on regarde si notre entrée capte du courant
lcd.setCursor(0,0);
lcd.print("B");
lcd.setCursor(0,1);
lcd.print("B");
delay(1000); }
if(digitalRead(switchb) == HIGH && digitalRead(switcha) == HIGH) // on regarde si notre entrée capte du courant
lcd.setCursor(0,0);
lcd.print("A and B");
lcd.setCursor(0,1);
delay(1000); }
if(digitalRead(switchb) == LOW && digitalRead(switcha) == LOW) // on regarde si notre entrée capte du courant
lcd.setCursor(0,0);
lcd.print("Free");
lcd.setCursor(0,1);
lcd.print("Free");
delay(1000); }
Maybe the loop is not ood, maybe nothing is good, any help will be appreciated. Thank you !
sha33:
But, what exactly do you see?
My guess is that when you try to press the two buttons together, you only see BB, or AA then BB, and only after that "A and B". If so, then it's because most humans can't really press two buttons at exactly the same time, so you'll have to figure out a smarter test...
Yup, i just did that, but the problem is the same? I am sure the problem is something in the code. Whe nothing is engaged, the screen shows AA. How would you have done it (like me, with if loops, or switch-case, or for..while)
I think in the loop function you need a while loop like this.
While ( int a = digitalRead(switcha) == HIGH || int b = digitalRead(switchb) == HIGH)) {
if ( a == b) {
Do both high code here
} else if ( a == HIGH)) {
Do a high code here
else {
Do b high code here
Do you need to define your default state as Low - Low?
Can you not just put lcd display "Free" as the first statement in the loop...then check for the other button state combinations with the if ?
