Topic: SD : How overwrite a file? (Read 820 times) previous topic - next topic
realmeteo
using SD EXAMPLE "ReadWrite.ino" a file test.tst is opened and if already exists, strings are joined to previous...
Code: [Select]
  SD card read/write
 This example shows how to read and write data to and from an SD card file
 The circuit:
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
 created   Nov 2010
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
    // close the file:
    myFile.close();
    Serial.println("done.");
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      Serial.write(myFile.read());
    // close the file:
    myFile.close();
  // nothing happens after setup
I like write the file on SD, but if it already exists, overwrite it.
How to?
Is correct delete it and then write or there is a better way?
Regards
"Follia รจ fare sempre la stessa cosa aspettandosi risultati diversi." Albert Einstein. (Se hai gradito il mio aiuto, grazie per un punto Karma).
PaulS
Code: [Select]
The second argument defines how to open the file. Look at the documentation, or header files, to find all the values that you can use for the second argument. O_TRUNC is one possibility.
