Hi everyone. New Arduino programmer here!
I'm having a problem with the output for my sin wave calculation. I'm getting some unexpected numbers from the program. I'm creating a program that will allow me to change the resolution of the sin wave. I'm able to monitor the serial port to get the calculated values.
Sin Fade
This code is setup to fade an LED using a Sinusoidal function.
Brightness is max at 255 and divided into 51 steps (255/5 = 51)
int led = 3; // the pin that the LED is attached to
float brightness = 0;
float halfPi = 1.5707963267949;
int divisions = 51; // Divisions
int rate = 50; // Delay date
int upArray[] = {};
int downArray[] = {};
// the setup routine runs once when you press reset:
delay(3000);
Serial.println("Program Start");
// declare pin 13 to be an output:
pinMode(led, OUTPUT);
for (int i = 0; i < (divisions + 1); i++){
upArray[i] = round(255 * sin( (halfPi / divisions) * i));
Serial.print("i:");
Serial.print(i);
Serial.print(" value = ");
Serial.println(upArray[i]);
Serial.println("upArray DONE");
for (int j = (divisions - 1); j > 0; j--){
downArray[j] = round(255 * sin( (halfPi / divisions) * j));
Serial.print("j:");
Serial.print(j);
Serial.println(downArray[j]);
//delay(5000);
//Serial.println("Ready?");
//Serial.println(upArray[5]);
//Serial.println(downArray[5]);
Serial.println("Done!");
// the loop routine runs over and over again forever:
The output shows that the calculations are working except for a few points.
Program Start
i:0 value = 0
i:1 value = 8
i:2 value = 16
i:3 value = 24
i:4 value = 31
i:5 value = 39
i:6 value = 47
i:7 value = 55
i:8 value = 62
i:9 value = 70
i:10 value = 77
i:11 value = 85
i:12 value = 92
i:13 value = 99
i:14 value = 107
i:15 value = 114
i:16 value = 121
i:17 value = 128
i:18 value = 134
i:19 value = 141
i:20 value = 147
i:21 value = 154
i:22 value = 160
i:23 value = 166
i:24 value = 172
i:25 value = 178
i:26 value = 183
i:27 value = 188
i:28 value = 194
i:29 value = 199
i:30 value = 203
i:31 value = 208
i:32 value = 213
i:33 value = 217
i:34 value = 221
i:35 value = 225
i:36 value = 228
i:37 value = 232
i:38 value = 235
i:39 value = 238
i:40 value = 241
i:41 value = 243
i:42 value = 245
i:43 value = 247
i:44 value = 249
i:45 value = 251
i:46 value = 252
i:47 value = 253
i:48 value = 254
i:49 value = 255
i:50 value = 255
i:51 value = 255
upArray DONE
j:50 value = 255
j:49 value = 255
j:48 value = 30240
j:47 value = 253
j:46 value = 252
j:45 value = 27745
j:44 value = 249
j:43 value = 247
j:42 value = 25973
j:41 value = 243
j:40 value = 241
j:39 value = 15648
j:38 value = 235
j:37 value = 232
j:36 value = 228
j:35 value = 225
j:34 value = 221
j:33 value = 217
j:32 value = 213
j:31 value = 208
j:30 value = 203
j:29 value = 199
j:28 value = 194
j:27 value = 188
j:26 value = 183
j:25 value = 178
j:24 value = 172
j:23 value = 166
j:22 value = 160
j:21 value = 154
j:20 value = 147
j:19 value = 141
j:18 value = 134
j:17 value = 128
j:16 value = 121
j:15 value = 114
j:14 value = 107
j:13 value = 99
j:12 value = 92
j:11 value = 85
j:10 value = 77
j:9 value = 70
j:8 value = 62
j:7 value = 55
j:6 value = 47
j:5 value = 39
j:4 value = 31
j:3 value = 24
j:2 value = 16
j:1 value = 8
Done!
Does anyone have any idea where these big numbers are coming from? Also, note that I'm using the round() function because without it, I was getting "ovf" as the output for some of the numbers (around i = 33) and then it would actually restart the program and loop this problem.
Thanks.
