OK, full disclosure: I orig. posted this in the Motors & Controllers section, thinking I was having an issue with my hardware.
I have since decided that this is not the case. First, the code:
// Motor Controls
const int PWMELPin = 10; // Enable PWM Left Motor
const int PWMERPin = 11; // Enable PWM Right Motor
const int L1Pin = 2; // L1 = Left Motor Lead 1
const int L2Pin = 3; // L2 = Left Motor Lead 2
const int L3Pin = 4; // L3 = Right Motor Lead 1
const int L4Pin = 5; // L4 = Right Motor Lead 2
const int LEDxPin = 12; // LEDx
const int LEDPin = 13; // LED
const int Duration = 1000;
pinMode(PWMELPin, OUTPUT);
pinMode(PWMERPin, OUTPUT);
pinMode(L1Pin, OUTPUT);
pinMode(L2Pin, OUTPUT);
pinMode(L3Pin, OUTPUT);
pinMode(L4Pin, OUTPUT);
pinMode(LEDPin, OUTPUT);
pinMode(LEDxPin, OUTPUT); }
//Main Loop
while (true)
MotorL(0, 1);
MotorR(0, 1);
digitalWrite(LEDPin, LOW);
delay(Duration);
MotorL(1, 1);
MotorR(1, 1);
digitalWrite(LEDPin, HIGH);
delay(Duration);
MotorL(0, 0);
MotorR(0, 0);
delay(Duration);
MotorL(1, 0);
MotorR(1, 0);
delay(Duration);
continue;
// Motor Driver Routines**************************************************
// (Direction, Speed)
// Direction
// 1=Forward
// 0= Reverse
// Speed
// 1 = High/250
// 0 = Low/50
void MotorL(int Direction, int Speed)
// Left Motor
if (Speed = 1)
analogWrite(PWMELPin, 250);
analogWrite(PWMELPin, 50);
if (Direction = 1)
digitalWrite(LEDxPin, HIGH);
digitalWrite(L1Pin, HIGH);
digitalWrite(L2Pin, LOW);
digitalWrite(LEDxPin, LOW);
digitalWrite(L1Pin, LOW);
digitalWrite(L2Pin, HIGH);
void MotorR(int Direction, int Speed)
// Left Motor
if (Speed = 1)
analogWrite(PWMERPin, 250);
analogWrite(PWMERPin, 50);
if (Direction = 1)
digitalWrite(L3Pin, HIGH);
digitalWrite(L4Pin, LOW);
digitalWrite(L3Pin, LOW);
digitalWrite(L4Pin, HIGH);
Here's the problem. Running this code does NOT produce the expected results.
I took L1, L2, L3, L3, PWMEL, and PWMER to LEDS to check...
When I run this, L1, L3, PWMEL,PWMER, and LEDx turn on and STAY on
L2, L3 never so much as flicker
LED (Pin 13) Blinks on and off, like clockwork
This tells me that, Although the main loop is running (13 flashing), the 2 Motor
Driver Functions are NOT working as intended.
I am assuming that I am doing something BASIC wrong, but I don't see it....
Help?!?!
Edit to add...
I am using the following, in general, to call the motor functions...
MotorL(0, 1);
Is passing an int "pure" (Not assigned to a variable) permitted?
