Hi, I have a Duemilanove 328p, with the same settings and hardware, how come it gives me an "not in sync message" while trying to upload any sketch with Arduino Software version 1.00 or above?
But with versions below 1.00 like 0023, the sketch uploaded without problem.
ttttkk:
no can do! It didn't even upload the bareminimum sketch.
I would stick with IDE 0023, but some of the libraries doesn't work under old IDE.
Is this on the same PC with both IDE versions installed? If not and using separate PCs be sure you have the correct driver installed on the one running 1.0 for a Duemilanove board which uses a FTDI USB driver.
ttttkk:
Same pc, same cable , same everything. I just launched separate IDE to upload. Do i have to install additional drivers for the new IDE?
No, If the FTDI driver is already there and working with the older IDE then it will work with the newer IDE. I've never had a problem upgrading IDE and using existing boards starting way back at IDE 11 I think.
The FTDI driver i have is version 2.8.14.0. How can I get hold of version 2.8.28.0 or 2.8.24.0 ? I went to the FTDI web site there it shows the latest version is 2.08.28 dated Feb 2013. I tried to install it anyways, but it says my installed driver is already the latest. Then I searched through the net and found 2.8.24.0, but the file is dated April 2012, my windows says it is older than my current version.
