adis
October 7, 2013, 5:47pm
1
Can you please look at the attached pictures and recommend a RF Outlet Library that might work?
One thing I see is that there is no address switch or a label with the address and the libraries I know will not work.
Also I'm a bit concerned that, with no address, additional sets of outlets cannot be controlled independently.
If anyone is wondering, those are sold by Hornbach in Romania for around 10€.
Many thanks,
Adi
probono
October 14, 2013, 10:45pm
2
Can't read the text on the small chip, but have you tried this?
Using a "1pcs RF transmitter and receiver kit for Arduino project 433Mhz" from eBay you can try to listen to what the remote sends, and re-send that from the transmitter...
spch
October 15, 2013, 5:41am
3
In case RC-Switch won't work, try this lib: homewatch/arduino/libraries/NewRemoteSwitch at master · hjgode/homewatch · GitHub
I used it to control sockets which also had "Turn off all" button.
adis
October 20, 2013, 5:05pm
4
Thanks to all for suggestions.
I found a working sample on https://sites.google.com/site/arduinohomeautomation/home/unitec_eim826 and I tuned the code with my DSO to the following:
const int outPin = 8;
// 1200bps=833us/bit lng=70%=583, sht=30%=250 , cor=correction for pinset/pinclear
#define FRAMEREPEAT 15
#define cor 4
#define lng 623 - cor//583 - cor
#define sht 208 - cor//250 - cor
// Macros for PWM bit pulse
#define rfBIT_H {digitalWrite(outPin, HIGH); delayMicroseconds(sht); digitalWrite(outPin, LOW ); delayMicroseconds(lng-5);}
#define rfBIT_L {digitalWrite(outPin, HIGH); delayMicroseconds(lng); digitalWrite(outPin, LOW ); delayMicroseconds(sht-5);}
{ pinMode(outPin, OUTPUT);
}//setup
byte rfFrame = B00001;//Button 1 ON
// byte rfFrame = B00011;//Button 1 OFF
// byte rfFrame = B10001;//Button 2 ON
// byte rfFrame = B10011;//Button 2 OFF
// byte rfFrame = B01001;//Button 3 ON
// byte rfFrame = B01011;//Button 3 OFF
// byte rfFrame = B00101;//All ON
// byte rfFrame = B00111;//All OFF
for ( byte j=0;j<FRAMEREPEAT;j++) // 15 Frame repeats
for ( byte i=0;i<20;i++) {rfBIT_H} // 20 preamble bits
if (rfFrame & B00010000) {rfBIT_H} else {rfBIT_L} // ChannelBit2
if (rfFrame & B00001000) {rfBIT_H} else {rfBIT_L} // ChannelBit1
if (rfFrame & B00000100) {rfBIT_H} else {rfBIT_L} // ChannelBit0
if (rfFrame & B00000010) {rfBIT_H} else {rfBIT_L} // On Off Bit
if (rfFrame & B00000001) {rfBIT_H} else {rfBIT_H} // stopbit always 1
delayMicroseconds(5647);//4600); // interFrame delay
}//for j
}//loop
frame:
00000000000000000000 11110
0:
hi 0.208ms
low 0.623ms
1:
hi .623ms
low .208ms
frame structure :
bit25 ... bit5 bit4 bit3 bit2 bit1 bit0
preamble... preamble ch bit0 ch bit1 ch bit 2 ON/OFF
Always '1' Always '1' ON ='0' OFF='1' always '1'
Channel Bits :
Button 1, Channel 0, ch_bit0='0' , ch_bit1='0' , ch_bit2='0' ,
Button 2, Channel 1, ch_bit0='1' , ch_bit1='0' , ch_bit2='0' ,
Button 3, Channel 2, ch_bit0='0' , ch_bit1='1' , ch_bit2='0' ,
Button 4, Channel 3, ch_bit0='1' , ch_bit1='1' , ch_bit2='0' ,
Button All, Channel>=4, ch_bit0='0' , ch_bit1='0' , ch_bit2='1' ,
Unfortunately the remote and the outlets don't have an address and additional sets will share the same RF commands.
Kind regards,
Adi
