I have a minimod hooked to my nano, and frankly the fix is pathetic.
Sitting in exactly the same place, I am getting readings (just from raw data) that are varying by almost 250 feet in longitude and 100 feet in latitude. The 'good fix' LED is illuminated, and I am reading back 'A' as acquired signal.
I bought this GPS because it is listed as accurate to within 9 feet, and I am thus far unimpressed.
Newsoftware serial is from here:
http://sundial.org/arduino/?page_id=61
Is there anything that I am missing? Any help is greatly appreciated.
#include <NewSoftSerial.h>
// Declarations //
NewSoftSerial SoftSer(2, 3);
boolean gpsupdate(long &lati, long &longi, long &timedec);
// Main Program //
SoftSer.begin(4800);
long latitude;
long longitude;
long timedec;
if (gpsupdate(latitude,longitude,timedec)) {
gpsprint(latitude,longitude);
// Functions Appear Below //
void gpsprint(long lati, long longi){
long dd;
long mm;
dd = lati/1000000;
mm = abs(lati - dd*1000000);
Serial.print(dd); Serial.print("."); Serial.print(mm);
Serial.print(char(9));
dd = longi/1000000;
mm = abs(longi - dd*1000000);
Serial.println("");
boolean gpsupdate(long &lati, long &longi, long &timedec){
boolean headerfound = false;
boolean linefound = false;
boolean newdata = true;
long oldlat = lati;
long oldlon = longi;
char header[6] = "GPGGA";
int verify = 1;
char newbyte;
char time[6];
char lat[9] = "";
char latdir;
char lon[10] = "";
char londir;
int posfix;
while (!linefound) {
newbyte = gpsread();
if (char(newbyte) == header[verify]){
verify++;
if(verify = 5) {headerfound = true;}
else{
verify = 0;
if (headerfound){
dumpnext(6);
keepnext(time,6);
dumpnext(4);
keepnext(lat,9);
dumpnext(1);
latdir = gpsread();
dumpnext(1);
keepnext(lon,10);
dumpnext(1);
londir = gpsread();
dumpnext(1);
posfix = gpsread();
lati = reformat(strtol(lat,NULL,10), latdir);
longi = reformat(strtol(lon,NULL,10), londir);
timedec = strtol(time,NULL,10);
linefound = true;
if (lati == oldlat && longi == oldlon){
newdata = false;
return newdata;
void dumpnext(int number){
char dumpbit;
for (int t = 0;t< number;t++){
dumpbit = gpsread();
char gpsread(){
char gpsdata;
bool notready = true;
while (notready)
if (SoftSer.available()){
gpsdata = SoftSer.read();
notready = false;
return gpsdata;
void keepnext(char *returnarray, int number){
int correction = 0;
char databit;
for(int t = 0;t<number;t++){
databit = gpsread();
returnarray[t-correction] = databit;
if (databit == '.'){
correction = 1;
long reformat(long measurement, char direc){
long dd;
long mmmmmm;
dd = measurement/1000000;
dd = dd*1000000;
mmmmmm = measurement - dd;
mmmmmm = mmmmmm/6*10;
measurement = dd+mmmmmm;
if (direc == 'S' || direc == 'W' ){
measurement = -measurement;
return measurement;
