Hey guys, just to begin - I want to thank everyone who's reading and helping others out. This will help me vastly to start my project.
I will have many pins as outputs and inputs, so I manipulated an example code using fors and arrays to help establish my variables to pin numbers.
I am questioning if I am doing this correctly. The variables consist of: variable[0], variable[1] and so on. The point here that I am trying to establish is trying to make the code shorter instead of doing: pinMode(doorclosed2, INPUT);
If I am doing the code wrong, please help me correct my logic. I am very new to programming and have little guidance other than you guys.
I have been told if this code won't work, I can create a .h file and insert it as a header on the top before void Setup (). Thanks again guys !
PS I have named the variables according to their pin distinction.
Akash
Code:
// Variabls to pin numbers: Pins are mapped/numbered in such a way to match pin location in Mega
int doorclosed[] = { 2, 3, 4, 5, 6 };
int motionsen[] = { 7, 8, 9, 10 };
int keyturned[] = { 11, 12, 13, 14, 15 };
int security[] = { 16, 17, 18 };
int led = 13; // TEST led
//Set each pin connected to an LED to output mode (pulling high (on) or low (off)
for(int i = 2; i < 6; i++){ //<--------- doorclosed[2] to doorclosed[6]
pinMode(doorclosed[i],INPUT); //we use this to set each LED pin to output
for(int x = 7; x < 10; x++){ //<--------- motionsen[7] to motionsen[10]
pinMode(motionsen[x],INPUT);
for(int y = 11; y < 15; y++){ // <--------- keyturned[11] to keyturned[15]
pinMode(keyturned[y],INPUT);
for(int q = 16; q < 18; q++){ // <--------- security[16] to security[18]
pinMode(security[q],INPUT);
pinMode(led, OUTPUT); // Test LED Pin Map
Close but you are confusing the contents of the array with the indexes of the contents. Each for loop should start at 0 and count until < sizeof(array), for example
for(int i = 0; i < sizeof(doorclosed); i++){
pinMode([i],INPUT);
A small point — sizeof() returns the number of bytes that the array occupies, not the number of elements in the array. It will work as long as the array elements are one byte in size, but it carries risk.
Regardless of which of the three specific variations on the idea you choose, the idea is sound.
One is code clarity; it eliminates magic numbers in your for() loops, for example.
Another is code safety if you change the size of the array, the compiler ensures you really have that number of elements in the array, but more importantly, all of your for() loops still work correctly.
For the OP:
The magic number is different than the array size, for mine it is for when the next set of variables will start taking up the next set of pins. Is that okay ?
akashroy:
Your original approach was flawed, so I'd say no.
If you store the pin numbers in the arrays, traverse the array indices, which go from zero to one less than the size of the array.
Then get the pin number that exists in each array element using the index (myArray[ i ]).
Notice that the code traversing the arrays is nearly identical below. (Not compiled; there may be typos.)
static const byte DOOR_CLOSED_SIZE = 5;
byte doorclosed[DOOR_CLOSED_SIZE] = { 2, 3, 4, 5, 6 };
static const byte MOTION_SEN_SIZE = 4;
byte motionsen[MOTION_SEN_SIZE] = { 7, 8, 9, 10 };
static const byte KEY_TURNED_SIZE = 5;
byte keyturned[KEY_TURNED_SIZE] = { 11, 12, 13, 14, 15 };
static const byte SECURITY_SIZE = 3;
byte security[SECURITY_SIZE] = { 16, 17, 18 };
for(byte i=0; i<DOOR_CLOSED_SIZE; i++)
for(byte i=0; i<MOTION_SEN_SIZE; i++)
pinMode(motionsen[i],INPUT); //we use this to set each LED pin to output
for(byte i=0; i<KEY_TURNED_SIZE; i++)
pinMode(keyturned[i],INPUT); //we use this to set each LED pin to output
for(byte i=0; i<SECURITY_SIZE; i++)
pinMode(security[i],INPUT); //we use this to set each LED pin to output
