are covered in an article in Dec 2012 Circuit Cellar Magazine. Good article with some small and clever idea's
Bob
Bob
Link?
usps://docs.house/den/magazines/stack4/box3/magazine392.mag
How do you provide a link to a magazine ...?
Online magazine articles at circuitcellar.com are apparently restricted to those
having a subscription. I think.
The thrust of the article is many Arduino boards use the miniscule SOT-223 v.regs
and these will overheat rather nastily if dissipating more than about 0.5 Watt. Of
course, this has been commented on in numerous threads on this forum.
The author's choice of workaround is to use a TO-220 7808 in the Vin line to reduce
dissipation in the SOT-223 device.
The other criticism is that the "tuning fork" style contacts used in Arduino female
header pins do not make very good contact for current driving situations, especially
when inserting circular pins.
oric_dan(333):
having a subscription. I think.The thrust of the article is many Arduino boards use the miniscule SOT-223 v.regs
course, this has been commented on in numerous threads on this forum.The author's choice of workaround is to use a TO-220 7808 in the Vin line to reduce
dissipation in the SOT-223 device.The other criticism is that the "tuning fork" style contacts used in Arduino female
Well any modern linear regulators have internal auto shutdown protection if they overheat or too much current is drawn, so I think more is made of regulator heat then really needs to. Besides an Arduino board is great at controlling stuff but is pretty poor at powering external stuff. I would only use the boards 5v pin to power pull-ups, switch contacts, etc. Anything needing any real current should not be powered externally from the arduino's +5vdc bus. And once you commit to external regulators, using linear regulators in this day of very inexpensive Asian switch mode voltage regulators makes little sense to me.
Those arduino shield connectors work great if used as they were designed, which is male .1" square header pins, not random round wires. Again the arduino is best used as a temporary prototyping board and once a circuit is proven and debugged, and you wish to keep the project, it should then move on to a standalone chip design or small carrier board where you are free to make permanent soldered connections for better long term reliability.
Lefty
The author mentions that too, saying thermal shutdown is around 175 degC = 350 degF,
and he'll be darned if he wants his Arduino board running anywheres near that hot. Ditto
for me.
Practically speaking, he computes that, for Vin = 12V, you can draw only a miniscule
70 mA off the SOT-223 v.reg before it overheats beyond what he's comfortable with.
Ditto for me.
CN - not that all over again, sheesh.
Of course, these are what everyone buys,
Computes, or measures? There is "some" heatsinking, and the reverse-protection diode, and ...
Still, that kind of thinking is why the "Freeduino" ended up using a full-sized 7805, with room to add at least some heatsink if you wanted to.
He decided that 165 degF max is all he wants "his" v.regs to go to. This is in line with
his idea that any hotter than that and he cannot hold his thumb on the part for more
than a few seconds. [this will displease people who argue for the max value from
the datasheet, 350 degF or whatever, but that's a philosophical question more than
anything else. Nothing destroys electronics like excess heat, after all, and some people
just don't like boards you can cook an egg on].
In any case, given the heating coefficients, 150 degF works out to 0.5 W dissipation.
So, I = 0.5W/(12V - 5V) = 70 mA.
And even if you're happy with your v.reg being able to boil water, you're still talking
less than 200 mA, which is a long way from the 1 Amp used in the PR notices.
The other thing about the 7808 vs a dc-dc converter from CN, he was only talking about
a quick-fix for under-designed boards.
I happened to like the article not because of its criticism of the Arduino board - we've been through those before - but because he illustrated well how various design choices impact the linear power supply. For example, one solution is to simply run a external power supply with a lower voltage into the Arduino board, i.e. 7-9VDC. The SOT223-3 package also likely regulates less than 500mA of output power under real world circumstances without getting super-hot, no matter what respective data sheets may claim.
There are already solutions for more rugged versions of the Arduino on the market - the Ruggeduino comes to mind. If you take a look at the size of the Ruggeduino regulator (DPAK?) and the land area around it, it's pretty apparent that its designers placed emphasis on keeping the thing cool. Some versions of the Freeduino also featured large LM7805's in TO-220 packages that are easy to interface with large heat sinks. I used a similar power supply to convert 24VAC to 5VDC for the RBBB and its relay board that runs a backwashing assembly in my sprinkler system. The 7805 still gets warm but thanks to the heat sink, not uncomfortably.
To me, the main takeaway was to 1) use well-regulated external power supplies. 2) minimize any power conversion on-board, if possible 3) ensure that the desired power output can be met without burning a hole in your PCB by reviewing the various parameters and figuring out ahead of time if the on-board power supply can handle applicable currents. It re-affirmed to me that using an external, well-regulated power supply for my home-grown boards is a valid design choice as it separates the heat from the MCU, its temperature-dependent ADC output, etc.
The current Arduino move towards 3.3V-based MCUs can certainly help in this regard. For one, having multiple 5V (fused!) power sources feed a given on-board regulator can be as simple as having an array of (Schottky?) diodes that feed into Vin. Secondly, post diode, the remaining voltage that has to be 'burned off' is low enough as to minimize the work that a linear regulator has to do, minimizing its heat generation and maximizing its useful life and power capacity at the same time.
I always thought that was kind of overkill, as it's easy and cheap to choose a plain old unregulated
wall-wart that is satisfactory for most jobs. 6V @ 1A, 9V @ 300mA, &etc. The output voltage of
such wall-warts drop in direct proportion to load current increasing.
OTOH, on my home-grown boards, I use a TO-220 5V @ 1A LDO v.reg [with room for a real
heatsink], feeding a DPAK 3.3V @ 800mA LDO v.reg. Will handle about anything I do, powered
by wall-wart or batteries.
Overkill? Small switch mode external power supplies are available for about $5 these days and are usually less expensive than unregulated wall-warts using standard transformers. Seems nuts to continue using the latter when the former usually offers more output at less cost and heat than the latter.
I totally hear you on your regulator choices, however. That said, the latest shields I developed feature a single 3.3V voltage regulator in a SOT223-3 form factor. However, I felt I could get away with it because the incoming voltage is 5VDC and I left plenty of land around the regulators to help dissipate the heat + I used vias to help spread the heat to the other side. Plus, my power demands are likely less than 100mA. Overkill, I guess.
We just had a long and very unhappy thread about people using such supplies, which were not
approved by Approval Agencies. So, I hope yours have all kinds of nice Approval stickers on them.
As I say - save $2, burn down the house.
3.3V SOT-223 is probably ok feeding off of 5V, and not running heavily loaded. On other threads,
people have usually used something like 0.5 watts as being the max dissipation you want in such
a package.
Not sure what approvals mean anymore in an era where such approvals are easy to fake. Just take apple 'cube' power supplies as an example. Many fakes are good enough to fool even experienced buyers unless you know what to look for and test the unit. For that reason, the reseller is actually more important than ever.
But I take your point re: the need to buy stuff that can cut the mustard. It's not about saving a few bucks though. Old school linear power supplies with hunky transformers are increasingly difficult to find.
@Dan... That thread was more concerned with the abuse of the regulators as I remember. The brunt of the thread was more about how poorly they performed when operated at max ratings. I've built and used in production switchers that had no "Approval Stamps or Stickers". The only caveat is to remember the ratings when using the device and having enough familiarity with the product to really basically remember that if it gets hot it needs a heat sink. For that matter Most of the 'reputable' CN houses will and do warn on the Ebay page that when using the device at max rating that more heat-sinking is required. I see no restriction to using a switcher to supply an Arduino for digital or analog processing at any Vref level or input level consistent with the current and present ground noise. a millivolt resolution should be readily do-able with a switcher and a little filtering. If I was real lazy I'd use a capacitance multiplier (2N3904 1 1K resistor and a 100uF cap, although a 47uF would work as well. This is applicable for any low power (under 200 mA) load from a switcher. Higher load currents force a Pi section filter possibly a 2 section (2 inductors and 3 capacitors) Pi filter for and additional 6 Db/octave roll off. Unless the analog sampling is at a multiple of the switcher simple oversampling and either some RC filtering or averaging / decimation will remove any possible switching artifacts. The biggest issue is that switchers art very poorly understood by the majority of the Arduino community I've encountered so far... However the Arduino Community is about learning, as is the Arduino Product. The real issues come about when the Arduino is used for more than digital control signals or to drive a led or two, the PCB wasn't intended to drive large loads directly...
I apologize for not providing any more information about the Circuit Cellar Article. I really thought that everyone read that magazine... It and Byte (in its early days) were my bibles for all things microprocessor and a big part of my early education.
Bob
So, from this, I assume the $5 power supplies you're using have no Approval stickers on them
at all?
What does reputable from CN even mean? If it's not stamped as approved, it's certainly not been
through the approval process - at least successfully. And as Constantin says, even if it is stamped
approved, who knows. In general, I'd be suspicious of anything coming from CN and costing very little.
I wouldn't mind using a CN dc-dc converter run off a battery, but plugging into the power mains and
then going out shopping is another story.
All of the mains-connected power supplies I buy feature multiple approvals. But in an era where such approvals are easy to fake, approvals in themselves are like the TSA - ie security theater - that can lead to a false sense of security.
Having an approval sticker/stamp/whatever by itself on a product is pretty meaningless - you have to combine a allegedly good power supply with a known good reseller to be reasonably sure that you're getting the paid-for goods you desired.
In my example above, have a look at the myriad of hosted resellers on amazon, eBay, and similar web sites selling goods that impersonate well-known products. When I had to buy additional power supplies for my Mac laptop and apple phones, I went to OWC for that reason.
Similarly, I prefer buying my power supplies and similar gear from the likes of adafruit, digikey, etc for the simple reason that the probability of paying for the real goods is higher on those sites than eBay for example.
Bottom line is that the supply chains are getting inundated with products that look like the real deal down to the point where you'd have to undo the ultrasonic welds and peek inside the product to see if it contains all the design features asked for by safety agencies. So even sourcing from adafruit or digikey may eventually lead to a dud - I just expect that probability to be lower.
I thought maybe Constantin from The Central Republic of Cantabrigia was from somewhere
in central Asia, and was buying goods shipped in from Moscow. "Da Comrade! Of course
is approvaled".
I agree with you, better to buy something with an approval sticker through digikey or similar
than to save a few dollars and buy through ebay from a noname company in CN. At least if
it blows up your house, digikey has someone to talk to about it.
Easy now. Just because some goods from Asia do not meet your standards does not mean that all products from there are junk. As with many things in life, the quality of a product has less to do with its point if origin than the care and dedication of its maker. Making jokes about pronunciation may be funny to you, it is not wise IMO.
Constantin:
I agree, I've probably made at least a fifty purchases on E-bay with Asian electronic parts and module suppliers and have yet to be disappointed with the quality of any of the items I've received. Maybe it's because I only buy if I can see a clear picture and all the specifications and or drawings in the e-bay ad that I will need to use the device, as I will say there is hardly ever any documentation sent other then what was in the E-bay ad. It's been my experience that the Asian sellers are very protective of their positive feedback ratings and I have had no problem getting them twice to send the correct item after receiving something different twice, they even said keep the original wrong items, bulk capacitor assortment and bulk resistor assortment both times, I order through hole and they sent SMD packs.
Lefty
"My" standards have nothing to do with it. You seem to have missed the part where I said
You're free to buy "unapproved" products from noname CN companies all you like, and plug into
your power mains all you like. It's your house, after all. This is all a very nice object lesson for
noobees.
It's ok, when it's about the former USSR.
