Topic: LCD Encoder Menu (Read 2740 times) previous topic - next topic
dizzwold
Hi dougp,
 To be honest, I can't answer that.
 The encoder library I'm using is from the PJRC website;
https://www.pjrc.com/teensy/td_libs_Encoder.html
 I'm not skilled enough to read and fully understand the actual library, and assumed that the library automatically places ISR's on both pin's a and b. Allthough I could be wrong.
 Without being disrespectful to Paul who wrote the library, to a novice, such as myself there's not a great deal of information, but enough for me to get results.
 May be I should be looking to use a different library?
 Dizzwold.
I'm not a student or a lecturer. I'm a hobbyist.
dizzwold
 For those that were interested regarding rotating the encoder fast and this having some effect on changing the LED status.
 I've soldered a 1206 0.47uf capacitor between the ground pin and pin a and another again between the ground pin and pin b.
 Unfortunately this hasn't solved the problem. It has helped to stablise it and happen's less.
 Dizzwold.
BulldogLowell
what happens less?
dizzwold
Quote
what happens less?
Sorry, this come's from previous post's #14, also I've had this thread moved by moderator as I had wrongly posted in Project Guidance.
 When the encoder is rotated fast, for some reason this is effecting the LED state when only the buit in switch should change the LED state.
 I thought it could be as I had no hardware debounce only software debounce.
 Dizzwold.
dougp
If you were to substiture enCount for IRQcounter in my snippet - not the ISR - and define arbitrary values for DIR_CW & DIR_CCW (+1, -1?) it would function correctly.  Essentially, a +1 value value given to encoderCount substitutes for the original pushbutton up keypress.  Likewise -1 for down.
So two neutrinos went into a bar.  Nothing happened.  They were just passing through.
dizzwold
Hi dougp,
 I'm not sure I fully understand you?
Code: [Select]
#define DIR_CW +1
#define DIR_CCW -1
#include <Encoder.h>
Encoder myEnc(20, 21);
int IRQActivity = myEnc.read();
volatile int encCount = 0;
 int encoderTurned = 0;  // Reset previous turned value.
  if (IRQActivity != encCount) {
    if (encCount > IRQActivity) encoderTurned = DIR_CW;
    if (encCount < IRQActivity) encoderTurned = DIR_CCW;
    IRQActivity = encCount; // reset one-shot value to be ready for next IRQ
    Serial.println(encCount);
 Dizzwold.
dizzwold
 In the current sketch, scrolling through the menu's seems to be working fine, with the exception of when rotating the encoder very fast, which sometimes change's the LED state.
 So I've omitted / commented-out the menu scroll to try and fix the "if (input == 2)", pin 53 the itergrated switch of the encoder.
 This has shown me that my toggle status isn't working as it should. It will toggle the LED on and off, but the toggle is not working on the input of the switch. The sketch in it's current state will scroll through the value's / parameter's, but I only whish to do this when the intergrated switch has been toggled.
Code: [Select]
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//Input & Button Logic
const int numOfInputs = 3;
const int inputPins[numOfInputs] = {20, 21, 53};
int inputState[numOfInputs];
int lastInputState[numOfInputs] = {LOW, LOW, LOW};
bool inputFlags[numOfInputs] = {LOW, LOW, LOW};
long lastDebounceTime[numOfInputs] = {0, 0, 0};
long debounceDelay = 10;
int backlight_pin10 = 10;
//LCD Menu Logic
const int numOfScreens = 10;
int currentScreen = 0;
const char* screens[numOfScreens][2] = {{"1Motor Voltage", "Volts"}, {"2Motor Current", "Amps"},
  {"3Motor Rated HP", "HP"}, {"4Overload Temp.", "degC"}, {"5Accel Time", "Secs"}, {"6Restart Time", "Mins"},
  {"7Analog Out. Curr.", "mA"}, {"8Input Temp.", "degC"}, {"9Run Time", "Hours"}, {"10Start Times", "times"}
//int button = 53;
int led = 13;
int dizzwold = false;
int parameters[numOfScreens];
  pinMode(backlight_pin10, OUTPUT);
  analogWrite(10, 200);
  for (int i = 0; i < numOfInputs; i++) {
    pinMode(inputPins[i], INPUT);
    digitalWrite(inputPins[i], HIGH); // pull-up 20k
  pinMode(led, OUTPUT);
  //pinMode(button, INPUT_PULLUP); // set the internal pull up resistor, unpressed button is HIGH
  lcd.begin(20, 4);
long old = 0;
  setInputFlags();
  resolveInputFlags();
void setInputFlags() {
    int reading = digitalRead(inputPins[i]);
    if (reading != lastInputState[i]) {
      lastDebounceTime[i] = millis();
      Serial.println(reading);
    if ((millis() - lastDebounceTime[i]) > debounceDelay) {
      if (reading != inputState[i]) {
        inputState[i] = reading;
        if (inputState[i] == HIGH) {
          inputFlags[i] = HIGH;
    lastInputState[i] = reading;
void resolveInputFlags() {
    if (inputFlags[i] == HIGH) {
      inputAction(i);
      inputFlags[i] = LOW;
      printScreen();
void inputAction(int input)
  long newP = myEnc.read();
    if (input == 0)
      if (newP < old)
        old = newP;
        if (currentScreen == 0 && 1)
          currentScreen = numOfScreens - 1;
          currentScreen--;
    else if (input == 1)
      if (newP > old)
        old = newP;
        if (currentScreen == numOfScreens - 1)
          currentScreen = 0;
          currentScreen++;
     if (input == 2);
      dizzwold = ! dizzwold;
      digitalWrite(led, dizzwold);
      if (newP < old)
        old = newP;
        parameterChange(1);
      if (newP > old)
        old = newP;
        parameterChange(0);
void parameterChange(int key) {
  if (key == 0) {
    parameters[currentScreen]++;
  } else if (key == 1) {
    parameters[currentScreen]--;
void printScreen() {
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print(screens[currentScreen][0]);
  lcd.setCursor(0, 1);
  lcd.print(parameters[currentScreen]);
  lcd.print(" ");
  lcd.print(screens[currentScreen][1]);
 I theory I would like to scroll through the menu's, as I can do, then input 2 / pin 53 to toggle in then out to changing the value's.
 Can I ask for your advice on how to get "input == 2" to toggle correctly?
 Dizzwold.
BulldogLowell
Why not just set a timeout that limits how fast you can update the display?
lock out the pulses from the encoder. and allow the LCD screen time to refresh
dougp
Going by the example sketch provided for the library you're using, no debouncing is needed.  At least, none is shown in the example.
Sooo, since the encoder library is doing the debouncing - this may seem radical - I'd dump the input debouncing loop.  Likewise for resolveInputFlags().  You'll still need to debounce the pushbutton and any other switch inputs but the encoder can be handled separately.
Per the example a presumably debounced value is returned in long newP = myEnc.read();.  Replacing your variable names in the snippet I posted could yield something like:
Code: [Select]
/* This code stands alone or in a function
   It is no longer a part of inputAction
long newP = myEnc.read();  //  check for encoder rotation
  if (long oldP != newP) {
    if (newP > oldP) encoderTurned = DIR_CW;
    if (newP < oldP) encoderTurned = DIR_CCW;
    oldP = newP; // set oldP equal to newP so next rotation can be detected
Now for the code within if(input == 2). This is separated and stands alone in the main code or within a function.  The test if(input == 2) goes away and the only remaining function of the revised code that was within if(input == 2) is to toggle dizzwold.  The LED code can be left in for debugging if desired.
What remains of inputAction could look like this: (untested)
Code: [Select]
void inputAction() {
  if (dizzwold == 0) // adjust screen numbers
    if (encoderTurned == DIR_CW)
      currentScreen++;
    else if (encoderTurned == DIR_CCW)
      currentScreen--;
  else if (dizzwold == 1)  //  adjust parameters
        parameter adjustment code goes here
And, finally inputAction is dormant until called by something like this:
Code: [Select]
if(encoderTurned != 0){
  inputAction();  // when encoder rotation puts a non-zero value in encoderTurned
                  // call inputAction to respond by adjusting screen or parameter
dizzwold
Quote
@BulldogLowell, that's a very good idea.
 @dougp, I've commented out the software debounce as suggested and applied some of your example code. This works to a fashion. When the encoder is rotated slowly it will count in + or - 1, but any faster it counts in 2's, ie 1,3,5,7,9 etc. So it may need a debounce.
 If I re-apply the software debounce it takes many turns of the encoder for it to count.
 Here's the current sketch;
Code: [Select]
#define DIR_CW +1
#define DIR_CCW -1
//long lastDebounceTime[numOfInputs] = {0, 0, 0};
//long debounceDelay = 10;
//LCD Menu Logic
//int button = 53;
int led = 13;
long oldP = 0;
int encoderTurned = 0 / 4;
  lcd.begin(20, 4);
  enc();
  setInputFlags();
void enc() {
  if ( oldP != newP) {
      //lastDebounceTime[i] = millis();
    //if ((millis() - lastDebounceTime[i]) > debounceDelay)
      inputAction(i);
      printScreen();
      currentScreen++;
      currentScreen--;
  if (key == 0) {
  lcd.clear();
  lcd.print(" ");
 Dizzwold.
dougp
Where is the
Code: [Select]
// etc.
part of inputAction?
dizzwold
 I've now added the rest of the code and attempted to add the encoder switch to toggle between scrolling through the menu's or changing the values.
 I've removed input 2 from the array and gone with a button on pin 53 and digital read.
 Again I don't have the switch toggling correctly. The LED will toggle correctly. The menu's will scroll and so will the value's with each toggle, but only while the switch is pressed and held pressed in each toggle state.
 Also the menu's and value's count in 2s, 2, 4, 6, 8 etc instead of 1, 2, 3, 4, 5, 6 etc.
Code: [Select]
#define DIR_CW +1
#define DIR_CCW -1
const int numOfInputs = 2;
const int inputPins[numOfInputs] = {20, 21};
int lastInputState[numOfInputs] = {LOW, LOW};
bool inputFlags[numOfInputs] = {LOW, LOW};
//long lastDebounceTime[numOfInputs] = {0, 0};
//LCD Menu Logic
int button = 53;
int led = 13;
long oldP = 0;
  lcd.begin(20, 4);
  enc();
  setInputFlags();
  if (digitalRead(button) == true)
    dizzwold = !dizzwold;
    Serial.print(dizzwold);
  while (digitalRead(button) == true);
  delay(50); // keeps a small delay
void enc() {
      inputAction(i);
      printScreen();
      currentScreen++;
      currentScreen--;
      parameterChange(0);
      parameterChange(1);
  if (key == 0) {
  lcd.clear();
  lcd.print(" ");
 Dizzwold.
dizzwold
 I've figured out the toggle switch issue. I hade true when I needed false!
 Now I need to figure why it is counting irraticaly.
Code: [Select]
#define DIR_CW +1
#define DIR_CCW -1
//LCD Menu Logic
int button = 53;
int lastbutton = false;
int led = 13;
long oldP = 0;
  lcd.begin(20, 4);
  enc();
  setInputFlags();
  if (digitalRead(button) == false)
  while (digitalRead(button) == false);
void enc() {
      inputAction(i);
      printScreen();
      currentScreen++;
      currentScreen--;
      parameterChange(0);
      parameterChange(1);
  if (key == 0) {
  lcd.clear();
  lcd.print(" ");
 Dizzwold.
dougp
Try this:
Comment out calls to  setInputFlags() and resolveInputFlags().
After call to enc() call inputAction() if encoder has turned.
dizzwold
Hi dougp,
 If I've done this correctly, all in the void loop, sorry but no joy just a blank screen.
Code: [Select]
  enc();
  for (int i = 0; i < numOfInputs; i ++)
    if (encoderTurned != 0);
      inputAction(i);
  //setInputFlags();
  //resolveInputFlags();
 With adding "inputAction();" I cot a compile error stating too few arguments (int), so I added the for i loop.
 Here's the full sketch;
Code: [Select]
#define DIR_CW +1
#define DIR_CCW -1
//LCD Menu Logic
int button = 53;
//int lastbutton = false;
int led = 13;
long oldP = 0;
  lcd.begin(20, 4);
  enc();
      inputAction(i);
  //setInputFlags();
void enc() {
      inputAction(i);
      printScreen();
        currentScreen = 0;
        currentScreen++;
      currentScreen--;
      parameterChange(0);
      parameterChange(1);
  if (key == 0) {
  lcd.clear();
  lcd.print(" ");
 Dizzwold.
