Topic: Arduino UNO Wifi - http post request (JSON) (Read 3192 times) previous topic - next topic
Juraj
#15
Dec 05, 2017, 03:44 pm Last Edit: Dec 05, 2017, 03:46 pm by Juraj
not the right wifilink. use 1.1.0 from here. how did you end up with 1.0.1? have I someware in docs a wrong link?
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
suneelng
Works fine now, thanks :)
Not sure, i think i had a copy of older version before and i did not make it point to verify with the new link, my bad.
Regarding the post request, say we have the api similar to this here.
It takes below parameters and also returns the same.
  "ID": 0,
  "UserName": "string",
  "Password": "string"
Thanks
Juraj
post request
Code: [Select]
  if (client.connect(server, 80)) {
    client.println("POST /api/Users HTTP/1.1");
    client.print("Host: ");
    client.println(server);
    client.println("Connection: close");
    client.println();
    client.println(data);
Juraj
to build json string you can use ArduinoJson library (is in Library Manager with examples)
or build the string with sprintf
Code: [Select]
char data[50];
sprintf(data, "{\"i\":%i,\"t\":%lu,\"v1\":%d,\"v2\":%d,\"c\":%u}", ix, events[ix].timestamp, events[ix].value1, events[ix].value2, events[ix].count);
(it is a snippet from my project)
suneelng
Thanks it works.
Have a question,
code snippet:
  char data[100];
  DynamicJsonBuffer jsonBuffer;
  JsonObject& root = jsonBuffer.createObject();
  root["ID"] = 10;
  root["UserName"] = "user1";
  root["Password"] = "123456";
  sprintf(data, "{\"ID\":10,\"UserName\":\"user1\",\"Password\":\"123456\"}");
      Serial.println("Connected to server");
      client.println("content-type: application/json");
      client.print("content-length: ");
      client.println(strlen(data));
      client.println();
//      root.prettyPrintTo(client);
//      client.println();
1) The code works fine if i send the json object store in data.
2) But it does not work when i use the root variable. I use the below code lines to post data,
      client.println();
3) how can i extract only the data part from the response and discard other headers section.
Thanks
Juraj
      client.println();
use print not prettyprint
search for empty line in response. after that are the data.
suneelng
suneelng
@Juraj,
Is there a websocket example available for serial1 library?
I need to post data to server every 0.5 seconds. What would you recommend for the same. POST request might not be the best solution.
Thanks
Suneel
Juraj
try ArduinoHttpClient library over WiFi Link's WiFiClient. I did not use it yet, but it should work. Someone in some thread used it with WiFiEsp or WiFi Link.
suneelng
Thanks,
I did the below code and i see that the code freezes at line "wsClient.begin()".
#include <SoftwareSerial.h>
#include <Wire.h>
#include <UnoWiFiDevEdSerial1.h>
#include "WiFiLink.h"
#include "ArduinoJson.h"
#include <ArduinoHttpClient.h>
WiFiClient client;
char server[] = "fakerestapi.azurewebsites.net";
char wsServer[] = "echo.websocket.org";  // server address
int port = 80;
WebSocketClient wsClient = WebSocketClient(client, wsServer, port);
  /* Socket Connect */
  Serial.println("starting WebSocket client");
  wsClient.begin();
  Serial.println("WebSocket client connected");
  /* websocket code */
  if(wsClient.connected()){
  wsClient.beginMessage(TYPE_TEXT);
  wsClient.print("Heart Rate Standard               :");
  wsClient.println("hello");
  wsClient.endMessage();
  else{
    Serial.println("Ws not connected");
  // check if a message is available to be received
  int messageSize = wsClient.parseMessage();
  if (messageSize > 0) {
    Serial.println("Received a message:");
    Serial.println(wsClient.readString());
delay(5000);
Thanks
Juraj
and where is the usual WiFi Link initialization?
suneelng
thats done as below,
  Serial1.begin(115200);
  Serial1.resetESP();
  delay(3000); //wait while WiFiLink firmware connects to WiFi with Web Panel settings
  WiFi.init(&Serial1);
    delay(10);
  Serial.println("You're connected to the network");
  printWifiStatus();
  wsClient.begin();
Juraj
#27
Dec 15, 2017, 11:01 am Last Edit: Dec 15, 2017, 11:27 am by Juraj
please post the complete sketch in code tags
suneelng
Below is the code
Code: [Select]
#include <Wire.h>
/* Client and server details */
WiFiClient client;
int port = 80;
static void postData(void);
  /* Initialise serial comm ports */
  Serial.begin(9600);    // serial / USB port
  /* Wifi module */
  Serial1.resetESP();
    delay(10);
  printWifiStatus();
  wsClient.begin();
  postData(void);
  delay(5000);
    wsClient.print("Hello");
  else{
void printWifiStatus() {
  // print the SSID of the network you're attached to
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength
  long rssi = WiFi.RSSI();
  Serial.print("Signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
Juraj
I cant find ArduinoHtppClient example on which your sketch is based. Modify the SimpleWebSocket example for WiFi Link library with Serial1
