Topic: Perform time-based task once only, at set times per hour, every hour (Read 485 times) previous topic - next topic
brice3010
It must be nice to be psychic.
It helps.. and a good glass of wine is a start  :smiley-lol:
I didn't say alarms would necessarily be easier but all it would require is an alarm interrupt every minute. The code in loop() would look almost the same except that the alarm must be reset and there's no need to test if minute == lastMinute.
Pete
And you would need a library?
el_supremo
You've already got functions to read and set the time in the RTC. A little bit of browsing through the DS3231 datasheet would show you how to set and reset the alarms. Or you could google for code to do it.
Or use a library. No big deal.
Pete
Don't send me technical questions via Private Message.
larryd
So by the same token, if I have task A to be performed once at 3 instances per hour, is the following correct?
Code: [Select]
if((taskAflag == true && minute == 10) || (taskAflag == true && minute == 20) || (taskAflag == true && minute == 40))
taskAflag = false; //disable, do only one taskA
if((taskAflag == false && minute == (10+1)) || (taskAflag == false && minute == (20+1)) || (taskAflag == false && minute == (40+1)))
taskAflag = true; //enable taskA for next time
The good thing about the Arduino platform is you can test things out ;)
Sketch to check out algorithm.
Code: [Select]
bool taskAflag = true;
  pinMode(13, OUTPUT);
  for (int x = 0; x < 6000; x++)
    if (taskAflag == true && (x == 1000 ||  x == 2000  ||  x == 4000 ))
      //call the task
      task(x);
    if (taskAflag == false && (x == 1001 ||  x == 2001 ||  x == 4001 ))
}// END of loop()
void task(int x)
  //print test time
  Serial.println(x);
  //toggle LED
  digitalWrite(13, !digitalRead(13));
  delay(200);
Edit, updated code.
No technical PMs.
The last thing you did is where you should start looking.
brice3010
Code: [Select]
      //call the task
      task(x);
}// END of loop()
void task(int x)
  //print test time
  Serial.println(x);
  //toggle LED
  delay(200);
Edit, updated code.
Hi larryd, thanks for your input; from what I read you do not use the DS3231? Or am I confused?
larryd
The example I gave is a quick and dirty way for checking the algorithm.
Yes I do, exclusively, use the DS3231 RTCs.
They are much much better than the DS1307.
You can change the 'x' in the sample sketch to 'minute' or whatever.
If you test the code out, you should find it does what you what you asked.
No technical PMs.
