i am workin on a clock drived by many servos, i will need 9 for the hours, 14 for the minuts ( 5 for the decimal digits and 9 for the others ) , and they will be 2 marks on every servo ( one at the 0 degree and one on the 45 degree ), so lets say the time is
"6:45" then 6 of the 9 servos ( for the hours ) will be on 45 Dg, while the others on 0 , and 4 of the 5 will be active ( for decimals ) and then 5 out of 9.
// include libraries
#include "Wire.h"
#include "Servo.h"
Servo hour_servo1
Servo hour_servo2
Servo hour_servo3
Servo hour_servo4
Servo hour_servo5
Servo hour_servo6
Servo hour_servo7
Servo hour_servo8
Servo hour_servo9
Servo hour_servo10
#define DS1307_I2C_ADDRESS 0x68
// defining variables
int realhour = 0;
int hours = 0;
int minutes = 0;
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
void setDateDs1307(byte second,byte minute,byte hour,byte dayOfWeek,byte dayOfMonth,byte month,byte year)
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.send(0);
Wire.send(decToBcd(second)); // 0 to bit 7 starts the clock
Wire.send(decToBcd(minute));
Wire.send(decToBcd(hour));
Wire.send(decToBcd(dayOfWeek));
Wire.send(decToBcd(dayOfMonth));
Wire.send(decToBcd(month));
Wire.send(decToBcd(year));
Wire.send(0x10); // sends 0x10 (hex) 00010000 (binary) to control register - turns on square wave
Wire.endTransmission();
void getDateDs1307(byte *second, byte *minute, byte *hour, byte *dayOfWeek, byte *dayOfMonth, byte *month,byte *year)
// Reset the register pointer
Wire.send(0);
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
*second = bcdToDec(Wire.receive() & 0x7f);
*minute = bcdToDec(Wire.receive());
*hour = bcdToDec(Wire.receive() & 0x3f);
*dayOfWeek = bcdToDec(Wire.receive());
*dayOfMonth = bcdToDec(Wire.receive());
*month = bcdToDec(Wire.receive());
*year = bcdToDec(Wire.receive());
// Function to Set time
hour_servo1.attach(1);
hour_servo1.attach(2);
hour_servo1.attach(3);
hour_servo1.attach(4);
hour_servo1.attach(5);
hour_servo1.attach(6);
hour_servo1.attach(7);
hour_servo1.attach(8);
hour_servo1.attach(9);
hour_servo1.attach(10);
second = 0;
dayOfWeek = 1;
dayOfMonth = 24;
month = 5;
year = 10;
// Set up the time using the buttons then ->
setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
realhour = int(hour);
if (realhour==0) // if it is 0000h, that should be 1200h in 12 hour time
realhour=12;
if (hour>=13)
realhour=realhour-12; // convert 24h hours to 12h hours
hours=realhour*14;
minutes=minute*3;
switch(hours) {
case '1':
hour_servo1.write(45); // if active set position to 45 degree
hour_servo2.write(0); // if inactive set position to 0 degree
hour_servo3.write(0);
hour_servo4.write(0);
hour_servo5.write(0);
hour_servo6.write(0);
hour_servo7.write(0);
hour_servo8.write(0);
hour_servo9.write(0);
hour_servo10.write(0);
break;
case '2':
case '12':
break;
delay(100); // servos need time to move
switch(minutes) {
case '1':
break;
case '2':
case '60':
break;
delay(100);
1 ) - i have problems setting time with buttons ... i cant figure out how to do it ?
2 ) - As you can see the case method will be quite long, is there another way to do it ? i was reading about arrays, but can anyone show me an example, because i am not sure how to do it neither.
