Sanguino(atmega644) can't initialize sd card !
Hello.
I have atmega644 with sanguino bootloader. I programming it using USBasp. All peripherals like OLED and RTC works only the SD card doesen't work. I connect it as shown below:
SD --- ATMEGA
mosi--5
miso--6
sck--7
cs--4
When it starts it display cant initialize sd card (in english because i'm polish)
Here is code (with english version of text)
const int buttonPin = 8;
int buttonState = 0;
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
#include <Rtc_Pcf8563.h>
#include <SD.h>
#include <Wire.h>
#define OLED_DC A3  //OLED -- D/C
#define OLED_CS 0  //Not connect
#define OLED_CLK A4 //OLED -- SCL
#define OLED_MOSI A1 //OLED -- SDA
#define OLED_RESET A2//OLED -- RST
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
Rtc_Pcf8563 rtc;
  display.begin(SSD1306_SWITCHCAPVCC);
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.clearDisplay();
  display.display();
  rtc.initClock();
  //day, weekday, month, century, year
  rtc.setDate(26, 1, 5, 0, 14);
  //hr, min, sec
  rtc.setTime(20, 05, 20);
  pinMode(buttonPin, INPUT);
  display.setCursor(0,0);
  display.println("Loading SD card");
  display.display();
  pinMode(10, OUTPUT);
  if (!SD.begin(4)) {
    display.println("Can't Initialize SD card");
    display.display();
    while(buttonState == LOW){
      buttonState = digitalRead(buttonPin);
    buttonState = 0;
  display.println("SD card loaded");
  display.display();
  //   ---------clock--------
  display.setTextSize(2);
    display.clearDisplay();  // Clear OLED
    display.setCursor(20,20);
    display.print(rtc.formatTime());
    display.display();
  buttonState = 0;
  //         ------file #1-------
  File dataFile = SD.open("datalog.txt");
  // if the file is available, write to it:
  if (dataFile) {
    while (dataFile.available()) {
      display.write(dataFile.read());
      display.display();
    dataFile.close();
    buttonState = 0;
  // if the file isn't open, pop up an error:
  else {
    display.println("Problem with datalog.txt");
    display.display();
    buttonState = 0;
  //           ---------file #2------------
  File dataFile2 = SD.open("datalog2.txt");
  if (dataFile2) {
    while (dataFile2.available()) {
      display.write(dataFile2.read());
      display.display();
    dataFile2.close();
    buttonState = 0;
  else {
    display.println("Problem with datalog2.txt");
    display.display();
    buttonState = 0;
  //----------file #3-----------
  File dataFile3 = SD.open("datalog3.txt");
  if (dataFile3) {
    while (dataFile3.available()) {
      display.write(dataFile3.read());
      display.display();
    dataFile3.close();
    buttonState = 0;
  else {
    display.println("Problem with datalog3.txt");
    display.display();
    buttonState = 0;
i tried everything please help :frowning:
sorry problem solved :smiley: FINALLY
what was the answer?
