Shrinkify Arduino Project
CrossRoads:
What part of the Arduino functionality would you like to keep?
At a minimum you need:
the '328P
16 MHz crystral
two 22pF caps
100nF caps on VCC, AVCC pins
using analog? need 100nF cap on the Aref pin
10K reset pullup resistor
diode such as 1N4158 across the resistor (anode to reset pin, cathode to Vcc)
optional:
Header pins to connect FTDI Basic/FTDI cable, and 100nF cap to connect to Reset pin
or
header pins to connect to ICSP header for rebootloading or for installing bootloaderless sketches
place to connect 5V wallwart, or a battery, or a 5V regulator
Here's an example for a ATmega1284P type board, a '328P would use a smaller connector
This one has both FTDI and ICSP headers, but does not have the diode.
It has screw terminal for bring in 5V power from a wallwart or 4.5V from a triple-AA battery pack (I've used both)
why do we need to pull up resistor when we need to use analog ?and also the cap.
Vincent19:
CrossRoads:
the '328P
16 MHz crystral
two 22pF caps
optional:
or
ATtiny2313 doesn't have analog input :>
io53:
I've never had any problems without caps or pull-up so I left them out.
In that case, I have a tiger repelling rock to sell you.
Please send it so I can try it out first. I'm pretty sure that it will work great here in Finland, but you never know. Anyway, if I ever where to use that thing I will solder a pull-up on the back to make you happy, but not a cap! Living on the edge! :%
my bad - i saw "shrinkify" only a few hours earlier did i come across "how to shrinkify your arduino" via a youtube vid, i presumed you were using an Attiny, my bad.
well, there's plenty of options, shift registers are the best way to go if all you're doing is reading a bunch of high/low signals.
xl97:
Is it the functionality you want 'gone'.. or just simply a smaller footprint of the 'Arduino board/brain'?
Maybe using a different/smaller Arduino circuit will help?
something like this perhaps:
green one is a commercial kit (about $10 bucks or so).. lacks any voltage regulation..
the other one is my home made, DIY home brew/etched version..
Please can you send me the link for these
Ardweeny is smaller.
http://www.thekanes.org/2010/04/16/ardweeny-adventures-part-one/
Lots of places carry them.
Teensy is also smaller.
My preference is for the Teensy boards.
--- bill
bperrybap:
Ardweeny adventures, part one | NovoKane
--- bill
i would still like to use the standard atmega328p chip
www.solarbotics.com - the ardweeny originator?
"And Mr. Kimio Kosaka's "One-Chip-Arduino" project inspired us to develop the Ardweeny; the smallest Arduino you can solder yourself with through-hole components!"
Atmega328P-PU is the standard chip. The kind of board you put it on does not matter too much.
kylem:
xl97:
Ideally i think this is the one that im needing
All the advice got before this is 'correct'...
the solarbotics one is pretty neat too!..
one is 'mine' (I home brew/etched it)..
the other is one by:
Anatools.com I believe..
(he used to even sell them on ebay if I recall)
**keep in mind this one has NO VOLTAGE REGULATOR **
so it can ONLY take a regulated 5v
"so it can ONLY take a regulated 5v"
Or 3 AA batteries...
Or a 3.7V LiPo battery for 3.3V/8MHz operation...
sorry.. correct. 'up to' :slight_smile:
still there is no voltage regulator..so you must watch that it doesnt go over the max rating of 5v..
if you want to run at 8MHz.. you'll need to change out the 16MHz resonator as well.
xl97:
Hi.
Could you please send me the schematics and board design if possible :slight_smile:
@xl97 that is a cool board. If you're sharing the schematics I'd love to get a copy as well.
Thanks in advance.
kylem:
kylem:
xl97:
How about this one: arduino pro mini for sale | eBay
Under $4 for a small-footprint Mega328 device with voltage regulator, etc. It's simply not worth making your own these days...
fungus:
Totally agree with that.
If you must have a m328 then get one
of the arduino minis or nanos.
The nano might be better in this case for a few dollars more
http://www.ebay.com/itm/Nano-V3-0-Mini-USB-ATmega328-5V-16M-Micro-controller-board-Arduino-compatible-/161091236453?pt=LH_DefaultDomain_0&hash=item2581c93265
http://www.ebay.com/itm/Mini-USB-Nano-V3-0-ATmega328-5V-Micro-controller-Board-Arduino-compatible-TR-/181202223580?pt=LH_DefaultDomain_0&hash=item2a307e81dc
as the OP said he used all the pins and the nano brings out the A4 and A5 pins (plus A6 & A7)
to the dip pins along the side.
Plus the nano can connect directly to a USB connector power and
programming.
The Anatools.com one IS NOT MINE (as mentioned)..
I dont have the schematic to share.....
I posed a link to the site however.. where he DOES share the schematic (dont recall if a .brd file is there?.. or just an image of the schematic)
as for the one I made/home etched (with the voltage regulator on-board)..... why? as mentioned, now-a-days you can get a real one mini/nano for $4.00 or so..
much cheaper and easier.
