int potPin = A0; // Potentiometer output connected to analog pin 3
double potVal = 0;// Variable to store the input from the potentiometer
const int buttonPin = 2;
int greenPin = 3;
int whitePin = 11;
int bluePin = 10;
int yellowPin = 9;
int redPin = 6;
int flashPin = 5;
// Program variables
int buttonState = 0;
int greenVal = 0;
int whiteVal = 0;
int blueVal = 0;
int yellowVal = 0;
int redVal = 0;
int flashVal = 0;
int DEBUG = 1; // Set to 1 to turn on debugging output
pinMode (buttonPin, INPUT);
pinMode(greenPin, OUTPUT);
pinMode(whitePin, OUTPUT); // sets the pins as output
pinMode(bluePin, OUTPUT);
pinMode(yellowPin, OUTPUT);
pinMode(redPin, OUTPUT);
pinMode(flashPin, OUTPUT);
if (DEBUG) { // If we want to see the pin values for debugging...
Serial.begin(9600); // ...set up the serial ouput in 0004 format
// Main program
void loop(){
potVal = analogRead(potPin);
//potVal = analogRead(potPin);
if(buttonState == HIGH)
digitalWrite (greenPin, HIGH);
potVal = analogRead(potPin); // read the potentiometer value at the input pin
if (potVal < 341) // Lowest third of the potentiometer's range (0-340)
potVal = (potVal * 3) / 4; // Normalize to 0-255
whiteVal = 255; // Red from full to off
blueVal = 0; // blue from off to full
yellowVal = 0;
redVal = 0;
flashVal = 0;
else if (potVal < 682) // Middle third of potentiometer's range (341-681)
potVal = ( (potVal-341) * 3) / 4; // Normalize to 0-255
whiteVal = 255- potVal; // Red off
blueVal = potVal; // Green from full to off
yellowVal = potVal; // Blue from off to full
redVal = 0;
flashVal = 0;
else if (potVal < 900)// Upper third of potentiometer"s range (682-1023)
potVal = ( (potVal-682) * 3) / 4; // Normalize to 0-255
whiteVal = 0; // Red from off to full
blueVal = 255 - potVal; // Green off
yellowVal = 255 - potVal; // Blue from full to off
redVal = potVal;
flashVal = 0;
potVal = ( (potVal-900) * 3) / 4; // Normalize to 0-255
blueVal = 0; // Green off
yellowVal = 0; // Blue from full to off
redVal = 255l;
flashVal = potVal;
analogWrite (flashPin, flashVal);
delay(100);
flashVal = 0;
delay(100);
flashVal = potVal;
delay(100);
flashVal = 0;
delay(100);
analogWrite (whitePin, whiteVal); // Green off
analogWrite (bluePin, blueVal);
analogWrite (yellowPin, yellowVal);
analogWrite (redPin, redVal);
digitalWrite (greenPin, greenVal);
analogWrite (whitePin, 0); // Green off
analogWrite (bluePin, 0);
analogWrite (yellowPin, 0);
analogWrite (redPin, 0);
analogWrite (flashPin, 0);
digitalWrite (greenPin, LOW);
