sarouje:
Try to do Serial print of 'temp' variable and see the what your function returns. Then you can identify your issue.
#include <math.h>
#include <SPI.h>
#include <SD.h>
File file;
int count = 1;
#define CSpin 4
#define RelayPin 9
pinMode(RelayPin, OUTPUT);
digitalWrite(RelayPin, LOW);
if (!SD.begin(CSpin)) {
Serial.println("No SD card or connection.");
return;
Serial.println("SD Card connected");
double Termistor(int analogRead)
double temp;
temp = log(((10240000 / analogRead) - 10000));
temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * temp * temp )) * temp );
temp = temp - 273.15;
return temp;
int value ;
double temp ;
value = analogRead(A0);
temp = Termistor(value);
if (temp > 60)
digitalWrite(RelayPin, HIGH);
save();
void save()
int value ;
double temp ;
Serial.println(temp);
file = SD.open("Log.txt", FILE_WRITE);
if (SD.exists("Log.txt")) {
file.print(count);
file.print(".minute ");
file.print("NTC temperature value:");
file.println(temp);
file.print(count);
Serial.println("Temperature value saved.");
Serial.println("Failed");
count++;
delay(60000);
this is output in serial port
SD Card connected
17.18
