Led Cube, How to Program
Hi, i try to do a Led cube whit custom routines, and i want to start each routine whit a button, i do the cube whit a tutorial, and i see this example code, but i dont know how control each rutine whit a button, how i could do that? thanks in advance.
    ledcube.pde - Example sketch for controlling an LED cube.
    Created by Gamaiel Zavala (gzip), 2009-2012
    MIT License. See accompanying LICENSE file for terms.
#include <LedCube.h>
#define SIZE 3
#define COLS (SIZE*SIZE)
byte levelPins[SIZE] = {11,12,13};
byte colPins[COLS] = {2,3,4,5,6,7,8,9,10};
LedCube cube(SIZE, levelPins, colPins);
void setup ()
void loop ()
    delay(10);
    // light each light one at a time
    for(byte level=0; level<cube.getLevels(); level++)
        for(byte col=0; col<cube.getCols(); col++)
            cube.lightPulse(level, col, 100);
    // light one level at a time, increasing speed each time
    for(byte d=25; d>2; d-=2)
        for(byte l=1; l <= cube.getLevels(); l++)
            cube.lightLevel(l, d);
    // light each row on each level
    for(byte level=1; level<=cube.getLevels(); level++)
        for(byte row=1; row<=cube.getLevels()*2; row++)
            cube.lightRow(row, level);
    // light each plane
    for(byte i=3; i; i--)
            cube.lightPlane(row, 10*i);
    // single random light at a time
    cube.randomLight(random(25,100),100);
    // random column drop
    for(byte x=0; x<=15; x++)
        cube.lightDrop(random(0,cube.getCols()), random(50,150));
    // circle around cube at a random level
    for(byte x=0; x<=5; x++)
        cube.lightPerimeter(random(0,cube.getLevels()), random(1,5), random(25,100));
    // light each face
    byte planes[] = {cube.getLevels()+1,cube.getLevels(),cube.getLevels()*2,1};
    for(byte i=5; i; i--)
        for(byte p=0; p<sizeof(planes); p++)
            cube.lightPlane(planes[p], 5*i);
    // random columns
    cube.randomColumn(25);
    // turn off a single column randomly
    cube.enableBuffer();
    for(byte c=0; c<30; c++)
        cube.fillBuffer();
        cube.invertBuffer();
        cube.randomColumn();
        cube.drawBuffer(7);
    cube.enableBuffer(false);
    // cols in and out
    for(byte c=1, d=0; c<=10; c++)
        if(c%2 == 0)
            for(d=0; d<20; d++)
                cube.lightColumn(2,1);
                cube.lightColumn(4,1);
                cube.lightColumn(6,1);
                cube.lightColumn(8,1);
        else if(c%4 == 1)
            for(d=0; d<30; d++)
                cube.lightColumn(1,1);
                cube.lightColumn(3,1);
                cube.lightColumn(7,1);
                cube.lightColumn(9,1);
            for(d=0; d<70; d++)
                cube.lightColumn(5,1);
    // diamond and box
    byte diamond[] = {0,4,  1,1, 1,3, 1,4, 1,5, 1,7,   2,4};
    byte box[] = {
        2,0, 2,1, 2,2, 2,3, 2,5, 2,6, 2,7, 2,8,
        1,0, 1,2, 1,6, 1,8,
        0,0, 0,1, 0,2, 0,3, 0,5, 0,6, 0,7, 0,8
    cube.lightSequence(box, sizeof(box), 200);
    cube.lightSequence(diamond, sizeof(diamond), 400);
    // helicopter effect
    byte topSeq[8] = {0,3,6,7,8,5,2,1};
    byte botSeq[8] = {8,5,2,1,0,3,6,7};
    for(byte loops = 0, delay = 50; loops<=8; loops++)
        for(byte s=0; s<8; s++)
            byte seq[] = {2,topSeq[s], 1,4, 0,botSeq[s]};
            cube.lightSequence(seq, sizeof(seq), delay);
        if(loops < 5) delay-=10;  else delay += 10;
    // turn off one light at a time
    cube.fillBuffer();
    cube.drawBuffer(25);
    for(byte w=0, l, c, max = cube.getNumLights(); w<max; )
        // lower bound is inclusive, upper is exclusive
        l = random(0, cube.getLevels());
        c = random(0, cube.getCols());
        if(cube.getBufferAt(l,c) == HIGH)
            cube.lightOff(l,c);
            cube.drawBuffer(5);
            w++;
please use the # button when posting code. Modify your post, select the code text and press the # button should work. (makes it more readable).
